[Mapbender-users] sassc compiler fails on Linux 32-bit
Axel Schaefer
axel.schaefer at wheregroup.com
Wed Dec 16 05:33:01 PST 2015
Dear Mapbender3 Users and Developers.
If you use Mapbender3 on a Linux 32-bit server you might come up against
problem with the sass compiler leading to the problem that Mapbender3
doesn't show the styles. The URL
http://yourhost/mapbender3/application/manager/assets/css returns an 500
error in that case.
The problem lies in the incompatibility of the sass compiler with Linux
32-bit systems. The appropriate respository is updated[1] and we have to
put changes in Mapbender3 for Version 3.0.5.3.
As a workaround: If you use Linux 32-bit, download the sassc.x86 from
the repository and put it into
mapbender-starter/application/vendor/eslider/sasscb/dist. Rename it to
sassc (make a backup of the existing one and override it).
Best regards
Axel
[1] https://github.com/eSlider/sassc-binaries/tree/develop/dist
WhereGroup GmbH & Co. KG
Eifelstraße 7
53119 Bonn
Germany
Axel Schaefer
Projektleitung
Fon: +49 (0)228 / 90 90 38 - 31
Fax: +49 (0)228 / 90 90 38 - 11
www.meldemax.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users
