[Mapbender-users] Mapbender3 Geoserver layers not visible
Astrid Emde astrid.emde at wheregroup.com
Tue Aug 30 23:36:10 PDT 2016
Hello Mike,
you could use the nightly version that willbe soon published as 3.0.5.4
Here we already made some fixed for PHP 7
http://mapbender3.org/builds/nightly/
Astrid
Am 2016-08-31 07:37, schrieb Schepers, Benjamin:
> Hi Mike,
> Your problems could be caused by misconfigured owsproxy. Maybe this
> there's also bug with owsproxy and php7? Maybe you can first try not
> to use any proxy-functions, until you properly configured this?
> Moreover I'm not sure, whether you would need any proxy settings,
> because all your stuff (MB3, services, etc.) seems to come from the
> same machine/domain.
> So I'd try this:
> Have you unchecked the Proxy-checkbox for the specific layer(s)? This
> could be done going to the application -> layerset -> edit
> layer-instance. If proxy for this layer-instance is unchecked, also
> have a look to the "vendor specific" section at the  same tab (it
> seems to me, that your error message lead to vendor-specific). If
> there are some vendor specific settings configured by you,
> delete/deactivate them, normally you would not need to pass vendor
> parameters to the wms-server or if vendor-specific is really needed,
> at least uncheck hidden (which would also make MB3 use the
> proxy-module).
> If you need to configure proxy, this should help you:
> http://doc.mapbender3.org/en/book/installation/configuration.html#configuration-files
> Regards
> Benjamin
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
FOSS Academy Sommerschule 2016
Alles Wichtige zur Erstellung einer GDI in nur 5 Tagen!
12. bis 16. September 2016 in Bonn
http://foss-academy.eu/sommerschule_2016
  Astrid Emde
  WhereGroup GmbH & Co.KG
  Eifelstraße 7
  53119 Bonn
  Germany
  Fon: +49(0)228 90 90 38 - 22
  Fax: +49(0)228 90 90 38 - 11
  www.wheregroup.com
  Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
  pgp-public key:
  http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
  Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
  Signed and/or encrypted mail is highly appreciated
More information about the Mapbender_users mailing list
