[Mapbender-users] Load WFS in Mapbender3
Astrid Emde astrid.emde at wheregroup.com
Mon Jun 13 23:09:38 PDT 2016
Hello,
If you have a direct accees to your data via SQL in PostgreSQL I would
not recommend to use Mapbender2 parallel.
It is really fun to use the Mapbender3 digitizer and it is very powerfull.
Though if you only can use WFS-T Mapbender2 is a good choice.
Regards Astrid
Am 14.06.2016 07:44, schrieb Armin Retterath:
> hello simone,
> you may alternatively install parallel mapbender2 for the digitize via wfs-t and use mapbender3 for the presentation frontend ?
> regards
> armin
>> Astrid Emde <astrid.emde at wheregroup.com> hat am 13. Juni 2016 um 16:03 geschrieben:
>> Hello Simone,
>> you can visualize data from GeoServer via WMS.
>> If you want to add a search or digitizer to your application you can
>> can't use WFS yet.
>> Search and digitizer use SQL and access the data directly from the
>> database.
>> Read more at
>> http://doc.mapbender3.org/en/bundles/Mapbender/CoreBundle/elements/search_router.html
>> http://doc.mapbender3.org/en/bundles/Mapbender/CoreBundle/elements/digitizer.html
>> We are discussing support for WFS in the team. But there is no concreate
>> planning yet.
>> Astrid
>> Am 2016-06-13 15:42, schrieb Simone Micozzi:
>>> Hi, all.
>>> I intend to set up a web GIS application with MapBender3
>>> backed by GeoServer as layers source.
>>> I must confess I'm new of MapBender3,
>>> but in the documentation I didn't find anything
>>> about laoding WFS service in a MapBender3 application.
>>> Can anyone kindly explain me if it is possible,
>>> and, in that case, how to do that?
>>> Thank you in advance,
>>> Simone Micozzi
>>> Mapbender_users mailing list
>>> Mapbender_users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
>> Mit freundlichen Grüßen
>> Astrid Emde
>> GIS-Consultant
>> FOSSGIS Konferenz 2016 und AGIT 2016
>> 4.-6. Juli 2016 & 6.-8. Juli 2016 in Salzburg
>> http://fossgis-konferenz.de/2016/
>> http://agit.at/
>>   Astrid Emde
>>   WhereGroup GmbH & Co.KG
>>   Eifelstraße 7
>>   53119 Bonn
>>   Germany
>>   Fon: +49(0)228 90 90 38 - 22
>>   Fax: +49(0)228 90 90 38 - 11
>>   www.wheregroup.com
>>   Folgen Sie der WhereGroup auf twitter:
>> http://twitter.com/WhereGroup_com
>> Amtsgericht Bonn, HRA 6788
>> Komplementärin:
>> WhereGroup Verwaltungs GmbH
>> vertreten durch:
>> Olaf Knopp, Peter Stamm
>>   pgp-public key:
>>   http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
>>   Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
>>   Signed and/or encrypted mail is highly appreciated
> Armin Retterath
> Zentrale Stelle GDI-RP
> LVermGeo Rheinland-Pfalz
> Ferdinand-Sauerbruch-Straße 15
> 56073 Koblenz
> Telefon 0261 492-466
> Telefax 0261 492-492
> armin.retterath at vermkv.rlp.de
> http://www.geoportal.rlp.de
Astrid Emde
GIS-Consultant
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
 Astrid Emde
 Eifelstraße 7
 53119 Bonn
 Germany
 Fon: +49(0)228 90 90 38 - 19
 www.wheregroup.com
 Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
Komplementärin:
vertreten durch:
 pgp-public key:
More information about the Mapbender_users mailing list
