[Mapbender-users] I can not adjust SearchRouter. Please help
Charlotte Toma charlotte.toma at wheregroup.com
Fri Nov 11 04:19:36 PST 2016
I forgot something!
If your schema is public, the you can say "relation: public.piccad".
    *relation: picckad (это таблица public.**)* this looks wrong --> is this your table name? # Relation to select from, you can use subqueries
Am 11.11.2016 um 13:17 schrieb Charlotte Toma:
> Hello,
> the parameters.yml needs the name of the connection , like this:
> parameters.yml
> parameters:
>     *default:*
>            database_driver:   pdo_pgsql
>            database_host:     localhost
>            database_port:     5432
>            database_name:     mapbender3
>            database_path:     ~
>            database_user:     postgres
>            database_password: [don't show your passwords!]
>     *search_db*:
>            database2_driver:  pdo_pgsql
>            database2_host:    localhost
>            database2_port:    5432
>            database2_name:    search_db
>            database2_path:     ~
>            database2_user:    postgres
>            database2_password: [don't show your passwords!]
> Your connection is missing parameters:
> doc.mapbender3.org/en/bundles/Mapbender/CoreBundle/elements/search_router.html
> class: Mapbender\CoreBundle\Component\SQLSearchEngine
> class_options:
>     connection: search_db
>     attributes:
>         - picnum
>         *- gid*
>  geometry_attribute: geom
> form:
>     picnum:
>         type: text
>         options:
>             required: true
> *label: Name   compare: ilike #both sides are considered as result*
> results:
>     view: table
>     count: true
>     headers:
> *picnum: Name**** gid: ID*
>     callback:
>         event: click
>         options:
>             buffer: 10
>             minScale: null
>             maxScale: null
> Try this : )
> I hope it works now
> Am 11.11.2016 um 13:07 schrieb Den:
>> Good day!
>> I'm new to Mapbender. Learn how to create customize and publish applications
>> but can not configure the search for their data.
>> There search_db database. It table in which one field with values - picckad.
>> The values of the numbers but the field type is Text. (I tried to give the
>> field of type Integer)
>> The database was created in PgAdmin and data loaded into it from a SHP file
>> through Qgis
>> config.yml Files and parameters.yml look like
>> config.yml
>> doctrine:
>>     dbal:
>>     default_connection: default
>>     connections:
>>        default:
>>           driver:   %database_driver%
>>           host:     %database_host%
>>           port:     %database_port%
>>           dbname:   %database_name%
>>           path:     %database_path%
>>           user:     %database_user%
>>           password: %database_password%
>>           charset:  UTF8
>>           logging: %kernel.debug%
>>           profiling: %kernel.debug%
>>        search_db:
>>          driver:   %database2_driver%
>>          host:     %database2_host%
>>          port:     %database2_port%
>>          dbname:   %database2_name%
>>          path:     %database2_path%
>>          user:     %database2_user%
>>          password: %database2_password%
>>          charset:  UTF8
>> parameters.yml
>> parameters:
>>            database_port:     5432
>>            database_path:     ~
>>            database_password: n36rp21
>>            database2_path:     ~
>>            database2_password: n36rp21
>> route-configuration in the configuration area
>> class_options:
>>     relation: picckad (это таблица public.)
>>     attributes:
>>         - picnum
>> form:
>>     picnum:
>>         type: text
>>         options:
>>             required: true
>>         compare: exact
>> results:
>>     view: table
>>     count: true
>>     headers:
>>         picnum: Name
>>     callback:
>>         event: click
>>         options:
>>             buffer: 10
>>             minScale: null
>>             maxScale: null
>> The result is - No results found.
>> The debugger Google hrome found this:
>> Deprecated: Automatically populating $HTTP_RAW_POST_DATA is deprecated and
>> will be removed in a future version. To avoid this warning set
>> 'always_populate_raw_post_data' to '-1' in php.ini and use the php://input
>> stream instead. in Unknown on line 0
>> Warning: Cannot modify header information - headers already sent in Unknown
>> on line 0
>> Mapbender version 3.0.5.3
>> Failed to start the session because headers have already been sent by "" at
>> line 0.
>> What am I doing wrong?
>> View this message in context: http://osgeo-org.1560.x6.nabble.com/I-can-not-adjust-SearchRouter-Please-help-tp5295321.html
>> Sent from the mapbender-users mailing list archive at Nabble.com.
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
> Mit freundlichen Grüßen
> Charlotte Toma
> GIS-Consultant
> Where2B Konferenz 2016
> 15. Dezember 2016 in Bonn
> www.where2b-conference.com
>  Charlotte Toma
>  WhereGroup GmbH & Co.KG
>  Eifelstraße 7
>  53119 Bonn
>  Germany
>  Fon: +49(0)228 90 90 38 - 24
>  Fax: +49(0)228 90 90 38 - 11
>  www.wheregroup.com
>  Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Olaf Knopp, Peter Stamm
Charlotte Toma
GIS-Consultant
 Charlotte Toma
 Eifelstraße 7
 53119 Bonn
 Germany
 www.wheregroup.com
Komplementärin:
vertreten durch:
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20161111/b0d33ae0/attachment-0001.html>
More information about the Mapbender_users mailing list
