[Mapbender-users] 'Feature Info' works for certain WMS only in the "WMS loader", but not when added from 'source'
Astrid Emde astrid.emde at wheregroup.com
Thu Sep 15 03:51:12 PDT 2016
Hello Henning,
I have an addition about featureInfo and "only valid".
You wrote: ‘Feature Info’ returns a ‘WMS server: no result’ for my layer
The featureInfo Element has an option "only valid"
If you activate "onbly valid" you have to make sure, that the answer
represents a valid HTML.
If you have defined text/plan as output-format, the switch only valid
must not be activated because text/plain doesn’t return valid HTML.
"Only valis" is a nice feature, as it will not open the dialog when an
empty page / no result comes back.
Read more:
http://doc.mapbender3.org/en/bundles/Mapbender/CoreBundle/elements/feature_info.html#configuration
Astrid
Am 2016-09-15 12:44, schrieb Astrid Emde:
> Hello Henning,
> looks like it has to do with the featureInfo format.
> You would like to get a featureInfo answer in text/html.
> Please go to your application-Layerset->GeoServer WMS and check the
> WMS infoformat. It should be set to text/html. Please save afterwards.
> GeoServer offers many infoformats in the getCapabilities Document.
> Mapbender chooses the first which is not always text/html.
> Astrid
> Am 2016-09-15 12:16, schrieb Henning Lorenz:
>> Mapbender v.3.0.5.3; Geoserver 2.9.1
>> Hello,
>> - I have a WMS V.1.1.1 from Geoserver that I want to add to Mapbender
>> 3
>> - I can add the WMS without problems as a source
>> - When I add layers from the WMS to a map, e.g. to one of the
>> templates that come with Mapbender3, they show up correctly but:
>>              * ‘Feature Info’ returns a ‘WMS server: no result’ for my
>> layer
>>              * ‘Feature Info’ works correctly on other WMS layers,
>> like the Mapbender3 user map
>> - When I add the very same WMS through the WMS loader, then ‘Feature
>> Info’ works just fine.
>> ———— this does not depend on the CRS, i.e. whether original or
>> projected.
>> - When I add this WMS to the same map twice, once as map layers from
>> ‘sources’ and then again through ‘WMS loader’ and query the same
>> feature  of the same layer in both WMSs with on click, i.e. at the
>> same time, then the query on the ‘WMS loader’ layer returns a correct
>> ‘Feature Info’ while the layer from ’sources’ returns ‘WMS server: no
>> result’.
>> Where is the difference between the ‘WMS loader’ and the ‘sources’?
>> I’m grateful for any hint that helps me with troubleshooting.
>> Thank you!
>> Henning
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
> Mit freundlichen Grüßen
> Astrid Emde
> GIS-Consultant
> INTERGEO 2016
> 11.- 13. Oktober 2016 in Hamburg
> Treffen Sie die WhereGroup in Halle A4, Stand B4.028
> www.intergeo.de
>  Astrid Emde
>  WhereGroup GmbH & Co.KG
>  Eifelstraße 7
>  53119 Bonn
>  Germany
>  Fon: +49(0)228 90 90 38 - 22
>  Fax: +49(0)228 90 90 38 - 11
>  www.wheregroup.com
>  Folgen Sie der WhereGroup auf twitter:
> http://twitter.com/WhereGroup_com
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Olaf Knopp, Peter Stamm
>  pgp-public key:
>  http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
>  Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
>  Signed and/or encrypted mail is highly appreciated
Astrid Emde
GIS-Consultant
INTERGEO 2016
www.intergeo.de
  Astrid Emde
  Eifelstraße 7
  53119 Bonn
  Germany
  www.wheregroup.com
Komplementärin:
vertreten durch:
  pgp-public key:
More information about the Mapbender_users mailing list
