[Mapbender-users] Geoportal CentropeMap
Charlotte Toma charlotte.toma at wheregroup.com
Thu Sep 29 07:02:08 PDT 2016
Hello Mapbender-User,
With this mail I want to show you CentropeMap [1], the Cross-Border
Geoportal for the Centrope Region, which
was created with Mapbender3.
The Geoportal CentropeMap and other Mapbender3
solutions can be found in the Mapbender3 gallery [2].
Introduction to CentropeMAP:
Since 2005 (and thus, one of the very pioneers) CentropeMAP is a
geoportal connecting the Centrope region by collecting web map services
from four countries (Austria, Czech Republic, Slovakia, Hungary). The
services allow the user to experience a cross-border working area with
dozens of data layers dealing with all topics which could be of interest
for regional planners and similar professions.
CentropeSTATISTICS is the only cross-border database with municipality
data and map generator.
Statistical datasets for the Centrope region can be obtained in multiple
ways, for example from the freely accessible databases of the national
statistical offices or through the EUROSTAT database. However, most of
these datasets are available on diestrict, NUTS 3 or NUTS 2 levels only,
which makes them less useful for a cross-border region where details are
important at small scale.
Almost all tables in CentropeSTATISTICS are on municipality level. To
visualise these tables, only a few mouse clicks are necessary to convert
the numbers into thematic maps which can be directly viewed in
CentropeMAP. Also, a wide range of charts is available, which can be
interactively created from the data in the cross-border database with a
few mouse clicks. CentropeSTATISTICS tables come from the topic
categories population numbers, population indicators, population
projection, citizenship, migration, education, economy/labour market,
buildings, and land use.
All components of the geoportal CentropeMAP are realised with open
source software.
[1] http://map.centropemap.org/index.php
[2] http://mapbender3.org/?q=en/gallery
== deutsch ==
Hallo Mapbender-Anwender,
ich würde Sie gerne auf das Geoportal CentropeMap[2] aufmerksam machen,
das mit Mapbender3 umgesetzt wurde, vorstellen.
Das Geoportal CentropeMap und weitere Mapbender3 Lösungen finden Sie in
der Mapbender3-Galerie [2].
Einführung in CentropeMAP:
Seit 2005 (und somit als einer der allerersten derartigen Dienste)
verbindet das Geoportal CentropeMAP die Centrope-Region durch die
gemeinsame Darstellung von Web Map Services aus vier Ländern
(Österreich, Tschechien, Ungarn, Slowakei). Die Dienste erlauben es dem
Benutzer, ein grenzüberschreitendes Betätigungsfeld zu erkunden und
dutzende Layer zu betrachten, die für Regionalplaner und verwandte
Fachbereiche von Interesse sind.
CentropeSTATISTICS ist die einzige grenzüberschreitende Datenbank mit
Gemeindedaten und Kartenerzeugung.
Statistische Daten für die Centrope-Region können auf vielfältige Weise
beschafft werden, etwa über die frei zugänglichen Datenbanken der
nationalen Statistikämter oder EUROSTAT. Jedoch sind die meisten dieser
Daten lediglich auf Bezirks-, NUTS-3- oder NUTS-2-Ebene verfügbar, was
sie für eine grenzüberschreitende Region in kleinem Maßstab wenig
brauchbar macht, da es hier auf kleinräumige Details ankommt.
Beinahe alle Tabellen in CentropeSTATISTICS sind auf Gemeindeebene
verfügbar. Zur Visualisierung sind nur wenige Mausklicks notwendig, die
daraus entstehenden Karten können direkt in CentropeMAP betrachtet
werden. Weiters kann eine Vielzahl an unterschiedlichen Arten von
Diagrammen, ebenfalls mit wenigen Klicks, erstellt werden. Die Tabellen
in CentropeSTATISTICS kommen aus den Bereichen Bevölkerungszahlen,
Bevölkerungsindikatoren, Bevölkerungsprognose, Staatsbürgerschaft,
Migration, Bildung, Wirtschaft/Arbeitsmarkt, Gebäude und Landnutzung.
Alle Komponenten des Geoportals CentropeMAP wurden mit
Open-Source-Software realisiert.
[2] http://mapbender3.org/de/galerie
Mit freundlichen Grüßen
Charlotte Toma
GIS-Consultant
INTERGEO 2016
11.- 13. Oktober 2016 in Hamburg
Treffen Sie die WhereGroup in Halle A4, Stand B4.028
www.intergeo.de
 Charlotte Toma
 WhereGroup GmbH & Co.KG
 Eifelstraße 7
 53119 Bonn
 Germany
 Fon: +49(0)228 90 90 38 - 24
 Fax: +49(0)228 90 90 38 - 11
 www.wheregroup.com
 Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
