[Mapbender-users] Mapbender3: Handling dynamic_image/dynamic_text in print-templates
Uwe Seher uwe.seher at gmail.com
Tue Jan 10 23:25:33 PST 2017
Good Morning!
Its always the small things. I had been logged in as administrator
yesterday, so no group was detected. With the correct user the template
works fine.
But this leads me directly to the next question. Which content is choosen
by mapbender when the user belongs to several groups and can access
different maps with their own logos etc?
Thank you for your help and
Have a lot of fun!
Uwe Seher
2017-01-10 17:10 GMT+01:00 Astrid Emde <astrid.emde at wheregroup.com>:
> Hallo,
> it looks like you followed the instruction at.
> http://doc.mapbender3.org/en/bundles/Mapbender/CoreBundle/el
> ements/printclient.html#configuration-of-the-element
> Did you check the access rights for the new files on linux?
> Please send your odg file to me and I will have a look.
> Astrid
> Am 2017-01-10 14:47, schrieb Uwe Seher:
>> Hello Mapbenderlist!
>> I like to create some print templates for some projectmaps which
>> should look the same with different logos and titles.
>> I created the odg-file and the pdf and it works fine, but the elements
>> dynamic_image and dynamic_text are not filled in the resulting map.
>> What i have done:
>> - created elements in the template (copied from Northarrow and title
>> and adjusted the name to dynamic_image and dynamic_text). They are on
>> the layer with the other dynamic elements.
>> - put the file in app/Resources/MapbenderPrintBundle/images
>> - adusted the owner/rights according the other files
>> Does it matter if the groupname has an uppercase Letter at start (the
>> file is named the same)?
>> Maybe someone can give me a brief introducion what i have to do to
>> make the template work.
>> Thank you in advance
>> Uwe Seher
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
> Mit freundlichen Grüßen
> Astrid Emde
> GIS-Consultant
> FOSS Academy Winterschule 2017
> 20.-24.03.2017 in Bonn
> Alles Wichtige zur Erstellung einer GDI in nur 5 Tagen!
>  Astrid Emde
>  WhereGroup GmbH & Co.KG
>  Eifelstraße 7
>  53119 Bonn
>  Germany
>  Fon: +49(0)228 90 90 38 - 22
>  Fax: +49(0)228 90 90 38 - 11
>  www.wheregroup.com
>  Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Olaf Knopp, Peter Stamm
>  pgp-public key:
>  http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
>  Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
>  Signed and/or encrypted mail is highly appreciated
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20170111/606a3b94/attachment.html>
More information about the Mapbender_users mailing list
