[Mapbender-users] MS4W version 3.2.2 available
Astrid Emde astrid.emde at wheregroup.com
Thu Jul 13 09:45:25 PDT 2017
Hello Jeff,
thanks for the great news. Version 3.0.6.1 on MS4W and fast too!
Thanks for the effort and thanks for integration Mapbender3 in MS4W.
See you in Paris at FOSS4G Europe next week.
Astrid
Am 2017-07-13 18:15, schrieb Jeff McKenna:
> Hi all!  Ready for FOSS4G-Europe, today's release of the MS4W
> installer contains many changes specifically for the Mapbender 3.0.6.1
> release, and it works super fast, give it a try!  The 3.0.6.1 package
> is also included in MS4W's setup.exe installer now.  Enjoy!!   (see
> below for more release notes)  -jeff
> -------- Forwarded Message --------
> Hello everyone,
> MS4W version 3.2.2 is now available at http://www.ms4w.com  This
> contains security releases of Apache, PHP, and upgrades to the
> MapServer 7.0.6 & GDAL 2.2.1 releases.  Several changes were also made
> to libraries for performance improvements (such as libjpeg-turbo and
> SQLite).  Several packages were upgraded for the installer including
> GeoMOOSE 3.0.0-beta (new backend engine, give it a try!), Mapbender
> 3.0.6.1 (now super fast), OpenLayers 4.2.0 (when you goto the
> OpenLayers examples page and search for "mapserver" you can find a
> local MS4W example).  This a substantial MS4W release.  Here is the
> full list of changes:
>    - upgraded MapServer and MapScript (CSharp, Java, Python, PHP) to
> 7.0.6
>    - upgraded GDAL to 2.2.1 (trac ticket 111)
>    - upgraded PHP to 5.6.31 (trac ticket 122)
>    - upgraded Apache to 2.4.27 (trac ticket 119)
>    - enabled OPcache PHP extension for Mapbender performance (trac
> ticket 63)
>    - built MapServer with support for Z geometry values (trac ticket
> 120)
>    - updated cURL certificates bundle
>    - rebuilt mod_fcgid
>    - rebuilt Apache H264 Streaming Module
>    - rebuilt MapCache
>    - rebuilt TinyOWS
>    - changed JPEG library to libjpeg-turbo (trac ticket 121)
>    - upgraded libPNG support to 1.6.29
>    - upgraded libTIFF support to 4.0.8 (trac ticket 114)
>    - upgraded GeoTIFF support to SVN-trunk-20170623
>    - rebuilt HDF4 support
>    - upgraded HDF5 support to 1.10.1
>    - upgraded PostgreSQL support to 9.6.3
>    - upgraded MySQL support to 5.7.18
>    - upgraded SQLite support to 3.19.3 (trac ticket 107)
>    - rebuilt SpatiaLite support
>    - upgraded OpenSSL support to 1.0.2l (trac ticket 116)
>    - upgraded cURL support to 7.54.1
>    - added curl.exe utility into /tools
>    - rebuilt NetCDF support
>    - upgraded Freetype support to 2.8
>    - upgraded Cairo support to 1.14.10
>    - rebuilt Poppler support
>    - upgraded to Esri File Geodatabase 1.5 API support (trac ticket
> 109)
>    - upgraded to Oracle SDK 12.2.0.1.0
>    - upgraded PCRE support to 8.40
>    - upgraded HarfBuzz support to 1.4.6
>    - rebuilt libSVG support
>    - rebuilt libSVG-Cairo support
>    - upgraded Shapelib support to 1.4.0 (trac ticket 72)
>    - rebuilt shp2tile utility
>    - renamed Apache access and error log files
> Please note that (if you are using the .zip) your server must have the
> C++ Redistributable installed on it beforehand: execute the local file
> /ms4w/tmp/vcredist_x86.exe
> Please don't be afraid to also provide feedback and requests through
> the MS4W tracker (so the comments and requests are not lost or
> forgotten): http://www.ms4w.com/trac/
> Thank you all for sharing your spatial information with MS4W.
> And happy MapServing!
> -jeff
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
FOSS Academy Sommerschule 2017
Aufbau von Geodateninfrastrukturen mit Open-Source-Software
11.-15. September 2017
www.foss-academy.com/sommerschule
  Astrid Emde
  WhereGroup GmbH & Co.KG
  Eifelstraße 7
  53119 Bonn
  Germany
  Fon: +49(0)228 90 90 38 - 22
  Fax: +49(0)228 90 90 38 - 11
  www.wheregroup.com
  Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
