[Mapbender-users] Problem WMS-Layer in Appliction einzubinden MB3.0.6.2
ivo s.koehler-katasteramt at lkspn.de
Wed Jul 26 01:23:03 PDT 2017
Hallo,
ich habe ein Problem einen WMS
(http://inspire.brandenburg.de/services/strassennetz.php?SERVICE=WMS&REQUEST=GetCapabilities)
in eine Appliction einzubinden/ /I have a problem to integrate a WMS into an
application./
Beim Versuch den Dienst auszuwählen erscheint folgende Fehlermeldung/ /When
attempting to select the service, the following error message appears/:
“Oops! An Error Occurred
The server returned a "500 Internal Server Error".
Something is broken. Please let us know what you were doing when this error
occurred. We will fix it as soon as possible. Sorry for any inconvenience
caused.”
In der MB-Logdatei steht/ /In the MB-Logfile is this/:
[2017-07-26 10:08:16] request.INFO: Matched route
"mapbender_manager_application_addinstance".
{"route_parameters":{"_controller":"Mapbender\\ManagerBundle\\Controller\\ApplicationController::addInstanceAction","slug":"test_gui","layersetId":"1","sourceId":"7","_route":"mapbender_manager_application_addinstance"},"request_uri":"https://xxxxxxxxx.de/xxxx_t/app.php/manager/application/test_gui/layerset/1/source/7/add"}
[2017-07-26 10:08:16] security.DEBUG: Read existing security token from the
session. {"key":"_security_secured_area"} []
[2017-07-26 10:08:16] security.DEBUG: User was reloaded from a user
provider.
{"username":"xxxxxxxx","provider":"Symfony\\Bridge\\Doctrine\\Security\\User\\EntityUserProvider"}
[2017-07-26 10:08:16] security.DEBUG: ACL found, permission granted. Voting
to grant access. [] []
[2017-07-26 10:08:16] request.CRITICAL: Uncaught PHP Exception
Symfony\Component\Debug\Exception\FatalErrorException: "Error: Call to a
member function getMin() on null" at
/var/www/kd/xxxxxxxxx.de/xxxx_t/mapbender/src/Mapbender/WmsBundle/Entity/WmsLayerSource.php
line 646 {"exception":"[object]
(Symfony\\Component\\Debug\\Exception\\FatalErrorException(code: 0): Error:
Call to a member function getMin() on null at
/var/www/kd/xxxxxxxxx.de/xxxx_t/mapbender/src/Mapbender/WmsBundle/Entity/WmsLayerSource.php:646)"}
[2017-07-26 10:08:16] security.DEBUG: Stored the security token in the
In der Version 3.0.6.1 funktioniert es ohne Fehler/ /In version 3.0.6.1 it
works without errors/.
Thanks for helping,
Ivo
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-WMS-Layer-in-Appliction-einzubinden-MB3-0-6-2-tp5329264.html
Sent from the mapbender-users mailing list archive at Nabble.com.
More information about the Mapbender_users mailing list
