[Mapbender-users] Get Raster Info and more
Schepers, Benjamin schepers at rvr-online.de
Thu Mar 30 04:29:25 PDT 2017
Hi Simone,
You asked for some hints: I really need in my application to get some info about the raster layers, in particular a legend with the color scale and some associated metadata (these raster files are the results of various processing chains performed on satellite data).
--> from my point of view the mentioned things are are to be done on the wms-server-side. (GetLegend-/GetFeatureInfo-Request), Mapbender just shows the response of the mentioned requests with Info- or legend-icon - also for raster-data.
I'm sorry that I can't help you further, because I'm not into GeoServer. But I know this could be done with UMN-Mapserver.
MapServer and GeoServer are nearly always capable to do the same things, so I would expect that this is possible with GeoServer too.
Maybe these links help:
http://docs.geoserver.org/2.7.0/user/services/wms/get_legend_graphic/legendgraphic.html
http://docs.geoserver.org/latest/en/user/services/wms/reference.html#getfeatureinfo
http://docs.geoserver.org/latest/en/user/tutorials/GetFeatureInfo/index.html#tutorials-getfeatureinfo
Cheers,
Ben
Mit freundlichen Grüßen
Im Auftrag
Benjamin Schepers
Geodaten, Stadtplanwerk, Luftbilder
Kronprinzenstraße 6
45128 Essen
Fon: +49 201 2069-232
Fax: +49 201 2069-369
Die Regionaldirektorin
Kronprinzenstraße 35
45128 Essen
Zentrale: +49 (0) 201 2069-0
Fax: +49 (0) 201 2069-500
www.metropoleruhr.de
Postfach 10 32 64
45032 Essen
Steuernummer: RVR 112/5797/0116
USt.-ldNr.: DE 173867500
Diese E-Mail koennte vertrauliche und/oder rechtlich geschuetzte Informationen enthalten.
Wenn Sie nicht der richtige Adressat sind oder diese E-Mail irrtuemlich erhalten haben, informieren Sie bitte sofort den Absender und vernichten Sie diese Mail.
Das unerlaubte Kopieren sowie die unbefugte Weitergabe dieser E-Mail sind nicht gestattet.
This e-mail may contain confidential and/or privileged information.
If you are not the intended recipient (or have received this e-mail in error) please notify the sender immediately and destroy this e-mail.
Any unauthorised copying, disclosure or distribution of the material in this e-mail is strictly forbidden.
-----Ursprüngliche Nachricht-----
Von: Mapbender_users [mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag von Simone Micozzi
Gesendet: Donnerstag, 9. März 2017 10:21
An: Astrid Emde
Cc: Mapbender User List
Betreff: Re: [Mapbender-users] Get Raster Info and more
Ciao, Astrid,
and thank you for your reply.
I noticed that you didn't mention the first point in my email.
Maybe because it is a silly question?
GetFeatureInfo from a raster layer...
Is it possible to use the metedata icon in the LayerTree panel to link to an external source (a HTML or XML document, or a DB table maybe)?
And if so, could you give me some advice about that?
Forgive my insistence, but this is really important to me.
Thank you anyway,
Simone
Il giorno 08/mar/17, alle ore 18:33, Astrid Emde ha scritto:
> Hello,
> Am 2017-03-07 02:05, schrieb Simone Micozzi:
>> Hi to all.
>> I set up a webgis application based on PostGIS, GeoServer and
>> MapBender.
>> The connections between the three components work fine:
>> the layers are regularly displayed by MapBender and when you click on
>> a feature inside the map (after having selected the FeatureInfo
>> button) a dialog box shows up displaying the related data.
>> Now, what I would like to do is to have the same result clicking on a
>> raster file, except that the info displayed would be of another kind,
>> maybe a legend and/or some related metadata.
>> Is it possible? And, if it is, could anyone point me where to find
>> some example or some guide about it?
>> Another thing I need to learn is how to style the Welcome Page and
>> also the FeatureInfo dialog box.
> Style the featureInfo Box
> Have a look at how to make your own template.
> http://doc.mapbender3.org/en/book/templates.html
> Note that the result comes from a WMS. SO maybe you have to style
> Geoserver result too.
> Style the welcome page:
> You can overwrite the manager.html.twig file.
> It works like this in Symfony.
> 1. Create the file structure to where the file is located f.e
> /app/Resources/FOMManagerBundle/views/
> 2. Copy the file from the origin location to this location
> cp fom/src/FOM/ManagerBundle/Resources/views/manager.html.twig app/
> 3. now you can add a new css to you twig
>  <link rel="stylesheet" href="{{ asset('bundles/workshopdemo/
> manager.css') }}"/>
> 4. Overwrite Information from the original style or change the twig
> structure
> You find a sample manager.css in the workshop bundle.
> https://github.com/mapbender/mapbender-workshop/tree/master/src/Worksh
> op/DemoBundle/Resources/public
> Please note. This works for Mapbender 3.0.5.3.
> Astrid
>> Thank you in advance for every possible help, Simone Micozzi
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapbender_users
> Astrid Emde
> GIS-Consultant
> FOSS Academy Winterschule 2017
> 20.-24.03.2017 in Bonn
> Alles Wichtige zur Erstellung einer GDI in nur 5 Tagen!
> Astrid Emde
> WhereGroup GmbH & Co.KG
> Eifelstraße 7
> 53119 Bonn
> Germany
> Fon: +49(0)228 90 90 38 - 22
> Fax: +49(0)228 90 90 38 - 11
> astrid.emde at wheregroup.com
> www.wheregroup.com
> Folgen Sie der WhereGroup auf twitter:
> http://twitter.com/WhereGroup_com
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Olaf Knopp, Peter Stamm
> pgp-public key:
> http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
> Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
> Signed and/or encrypted mail is highly appreciated
More information about the Mapbender_users mailing list
