[Mapbender-users] Custom element that displays the result of a SQL query
Uwe Seher uwe.seher at gmail.com
Wed May 24 01:30:27 PDT 2017
Hello!
You should provide a little more information what you want to do.
You can use different approches to solve this. In mapbender i think, you
can use something like the search or the digitizer element. These can use a
sql-query direct from mapbender. You only have to configure the database
connection. But when you use a wms layer in the behind, a getfeatureinfo is
maybe the better approach.
best regards
Uwe Seher
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20170524/ab3d5097/attachment.html>
More information about the Mapbender_users mailing list
