[Mapbender-users] Mapbender don´t show map
Jörg Thomsen (WhereGroup) joerg.thomsen at wheregroup.com
Wed Sep 20 02:43:11 PDT 2017
Hello Teresa,
well, the layers should be configured as visible, but that's the default.
I would add a layertree to the app, so I could see whether the wms are
really added to the application. Next step, or anhother check, would be
to check the browser request press F12 in your browser, reload the
application and have a lok at the traffic-tab, you should see, among
many other requests, the getmap-request.
Is it possible to have a look at your application via internet?
Jörg
Am 20.09.2017 um 11:20 schrieb Teresa Graßl:
> Hello Jörg,
> thank you for your fast response.
> Yes, I did add the WMS to my layersets within the application and the
> layersets to the map-element.
> But they are not shown when I view the application. Do I have to
> consider other configurations within mapbender?
> Regards,
> Teresa
> 2017-09-20 10:57 GMT+02:00 Jörg Thomsen (WhereGroup)
> <joerg.thomsen at wheregroup.com <mailto:joerg.thomsen at wheregroup.com>>:
>     Hello Teresa,
>     I would do the first Mapbender-steps with a provided template, when you
>     know what you are doing you can switch to your own template.
>     Are the WMSs only added as a source? You also have to add them to a
>     layerset within your application and add the Layerset to the map-element
>     of your app.
>     Regards, Jörg
>     Am 20.09.2017 um 10:44 schrieb Teresa Graßl:
>     > Hello,
>     > I´m new in mapbender3 and can not show a map or any other elements
>     in a
>     > new application. I read through the mapbender documenation and
>     tutorial,
>     > but nothing worked.
>     > I´m working on a Windows Server 2012 2R with WAPP (php, Apache,
>     > PostgreSQL/PostGIS,..), Mapserver from MS4W and mapbender3.
>     > My aim is to built a simple application with a map and points. My main
>     > map should be the terrestris OSM
>     (http://ows.terrestris.de/osm/service
>     <http://ows.terrestris.de/osm/service>?)
>     > and my points are saved as geodatabase in PostGIS. I can request my
>     > point geometries as GetCapabilities and GetMap-Request. So
>     MapServer is
>     > working. Mapbender is working too, but if I include my database as WMS
>     > or the terrestris WMS (as element main map), then they can not be
>     loaded
>     > (I can only see a white "map"-window). Unfortunetly no error
>     massage is
>     > shown. My points are saved as epsg:4326. The same I´m using in my
>     > application. Both WMSs are defined and added in the sources. As
>     Template
>     > I used the pre-configurated Full Screen Template.
>     > My problem is, that I´m not in programming or using php commands. I´ve
>     > also tried to create a new template
>     > (https://doc.mapbender3.org/de/book/templates.html
>     <https://doc.mapbender3.org/de/book/templates.html>) and follwed the
>     > tutorial, but unfortunetly the tutorial uses linux-commands and for me
>     > it didn´t worked.
>     > Has anyone configurated mapbender3 on a windows server and created
>     a new
>     > application yet?
>     > I´m very grateful about any advice or help!
>     > Cheers
>     > Teresa
>     > _______________________________________________
>     > Mapbender_users mailing list
>     > Mapbender_users at lists.osgeo.org
>     <mailto:Mapbender_users at lists.osgeo.org>
>     > https://lists.osgeo.org/mailman/listinfo/mapbender_users
>     <https://lists.osgeo.org/mailman/listinfo/mapbender_users>
>     Viele Grüße,
>     Jörg Thomsen
>     INTERGEO 2017
>     26.-28. September 2017 in Berlin
>     Treffen Sie die WhereGroup in Halle 3.1, Stand A3.053
>     www.intergeo.de <http://www.intergeo.de>
>     Jörg Thomsen
>     WhereGroup GmbH & Co. KG
>     Gillweg 3
>     14193 Berlin
>     Germany
>     Fon: +49 (0)30 / 5130 278 74
>     <tel:%2B49%20%280%2930%20%2F%205130%20278%2074>
>     Fax: +49 (0)30 / 89 09 53 21
>     <tel:%2B49%20%280%2930%20%2F%2089%2009%2053%2021>
>     www.wheregroup.com <http://www.wheregroup.com>
>     Amtsgericht Bonn, HRA 6788
>     Komplementärin:
>     WhereGroup Verwaltungs GmbH
>     vertreten durch:
>     Olaf Knopp, Peter Stamm
>     Folgen Sie der WhereGroup auf twitter:
>     http://twitter.com/WhereGroup_com <http://twitter.com/WhereGroup_com>
>     Mapbender_users at lists.osgeo.org <mailto:Mapbender_users at lists.osgeo.org>
Viele Grüße,
Jörg Thomsen
INTERGEO 2017
www.intergeo.de
Jörg Thomsen
Gillweg 3
14193 Berlin
Germany
www.wheregroup.com
Komplementärin:
vertreten durch:
Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
More information about the Mapbender_users mailing list
