[Mapbender-users] Antwort: Re: Antwort: Re: Antwort: Re: Mapbender / Apache Alias
david.mueller at kaiserslautern.de david.mueller at kaiserslautern.de
Thu Sep 13 03:23:10 PDT 2018
Hallo Axel,
hier der Inhalt meiner 000-default.conf ...
Hier liegt also der Fehler?
<VirtualHost *:80>
        # The ServerName directive sets the request scheme, hostname and
port that
        # the server uses to identify itself. This is used when creating
        # redirection URLs. In the context of virtual hosts, the
ServerName
        # specifies what hostname must appear in the request's Host:
header to
        # match this virtual host. For the default virtual host (this
file) this
        # value is not decisive as it is used as a last resort host
regardless.
        # However, you must set it for any further virtual host
explicitly.
        #ServerName www.example.com
        ServerAdmin webmaster at localhost
        DocumentRoot /var/www
        <IfModule mod_rewrite.c>
                RewriteEngine On
                RewriteCond %{HTTPS} off
                RewriteRule (.*) https://%{HTTP_HOST}%{REQUEST_URI}
[R=301,L]
        </IfModule>
        # Available loglevels: trace8, ..., trace1, debug, info, notice,
warn,
        # error, crit, alert, emerg.
        # It is also possible to configure the loglevel for particular
        # modules, e.g.
        #LogLevel info ssl:warn
        ErrorLog ${APACHE_LOG_DIR}/error.log
        CustomLog ${APACHE_LOG_DIR}/access.log combined
        # For most configuration files from conf-available/, which are
        # enabled or disabled at a global level, it is possible to
        # include a line for only one particular virtual host. For example
the
        # following line enables the CGI configuration for this host only
        # after it has been globally disabled with "a2disconf".
        #Include conf-available/serve-cgi-bin.conf
</VirtualHost>
Mit freundlichem Gruß
i.A. David Müller
S t a d t v e r w a l t u n g   K a i s e r s l a u t e r n
R e f e r a t    S t a d t e n t w i c k l u n g
Abteilung Stadtvermessung
Grafische Datenverarbeitung, Kommunales Geo-Informationssystem
Willy-Brandt-Platz 1
67653 Kaiserslautern
Tel. 0631 - 3654043
Fax 0631 - 3651629
E-Mail: david.mueller at kaiserslautern.de
Internet:  www.kaiserslautern.de
Stadtplan: http://geoportal.kaiserslautern.de/
Von:    Axel Schaefer <axel.schaefer at wheregroup.com>
An:     Mapbender User List <mapbender_users at lists.osgeo.org>
Datum:  13.09.2018 10:52
Betreff:        Re: [Mapbender-users] Antwort: Re: Antwort: Re: Mapbender
/ Apache        Alias
Hi David.
david.mueller at kaiserslautern.de writes:
> bei mir liegt der "mapbender" Ordner unter var/www/
> Könnte ich irgendwo noch irrtümlich einen falschen Alias definiert
> haben?
Ich denke ja. Apache definiert seinen Default Document Root unter:
"DocumentRoot /var/www/html". Noch nichtmal /var/www. Wenn Du das so
machen möchtest, musst Du auch die Aliase so konfigurieren. Ist aber
irgendwie unschön.
Vorschlag:
Setze die Apache Konfiguration auf den Standard zurück. Lass den Default
DocumentRoot von Apache in Frieden (je nach Betriebssystem in der
000-default.conf oder manchmal auch in der der httpd.conf). Lege den
Mapbender irgendwo hin, wo der Webserver Zugriff hat und lege einen
Alias an, wie in der Doku beschrieben.
Du würdest zwar auch mit Deiner jetzigen Konfiguration weiterkommen,
aber bei einer zweiten Anwendung die Du in den Apache legen willst,
würde das schon keinen Spaß mehr machen. :D
Gruß,
Axel
Mapbender_users mailing list
Mapbender_users at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/mapbender_users
Wichtiger Hinweis
Für die rechtliche elektronische Kommunikation mit der Stadtverwaltung
Kaiserslautern steht Ihnen ausschließlich folgende E-Mail-Adresse zur
Verfügung: stv-kaiserslautern at poststelle.rlp.de
Bitte beachten Sie unsere Hinweise unter
https://www.kaiserslautern.de/ekommunikation
Der Schutz Ihrer Daten ist uns wichtig! Ihre Angaben werden stets vertraulich behandelt und nur für den von Ihnen gewählten Zweck verwendet. Mit unserer Datenschutzerklärung informieren wir Sie über die Verarbeitung Ihrer personenbezogenen Daten durch uns sowie über die Ihnen zustehenden Rechte. Eine detaillierte Ausführung der Datenschutzerklärung  finden Sie unter https://www.kaiserslautern.de/service/datenschutzerklaerung/index.html.de
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20180913/14ce4a56/attachment.html>
More information about the Mapbender_users mailing list
