[Mapbender-users] Fwd: MS4W version 4.0.0-beta1 available
Jeff McKenna jmckenna at gatewaygeomatics.com
Wed Feb 6 05:38:55 PST 2019
Thanks Astrid, I have also integrated 3.0.7.7 into the stable MS4W 3.3.0
release: https://ms4w.com/release/ms4w-3.3.0-setup.exe
-jeff
On 2019-02-05 2:35 AM, Astrid Emde wrote:
> Hello Jeff,
> thanks for integrating the actual Mapbender 3.0.7.7 version to the MS4W
> package. Great!
> See you Astrid
> Am 2019-02-05 02:43, schrieb Jeff McKenna:
>> Forwarding the announcement below to the Mapbender community, as
>> MS4W-4.0.0-beta1 contains a packaged Mapbender 3.0.7.7     Note that
>> MS4W-4.0.0 contains PHP 7.2.14 and its performance enhancements are
>> very noticeable.
>> (I am aware that Mapbender does not officially support PHP 7.2.x yet,
>> but this will give users and devs a Windows environment to test and
>> help improve Mapbender for PHP 7.x)
>> thanks, -jeff
>> -------- Forwarded Message --------
>> On 2019-02-04 8:46 PM, Jeff McKenna wrote:
>>> Hello everyone,
>>> Many Windows users will be very interested that MS4W-4.0.0-beta1 is
>>> available now, which will be a huge release of changes, as every library
>>> (over 200 now) has been upgraded and built with a new compiler
>>> (Visual Studio 2017), and contains many great additions overall.  You
>>> can test the beta at:
>>>   - installer:
>>> https://ms4w.com/release/experimental/ms4w-4.0.0-beta1-setup.exe
>>> (recommended)
>>>   - archive: https://ms4w.com/release/experimental/ms4w_4.0.0_beta1.zip
>>> Please see MS4W's HISTORY.txt for all of the changes, but here are
>>> some of the highlights:
>>>   - Mapbox Vector Tile output through MapServer (demo included)
>>>   - PHP7 mapscript support (using the SWIG API)
>>>   - usual mapscripts available (Java, Python, CSharp)
>>>   - embedded Python 3.7.0
>>>   - running pycsw Catalogue Server
>>>   - expanded ZOO-Project WPS support (all GDAL/OGR services, Python,
>>> PHP, CSharp, Java)
>>>   - new Matomo Analytics package
>>>   - simple map viewer on the localhost page
>>>   - GDAL 2.4.0
>>>   - MapServer 7.4.0-dev
>>>   - mod_wsgi for Apache
>>>   - and many more...
>>> You can see that MS4W-4.0.0 will be a full SDI for Windows
>>> environments, with ~40+ working mapfiles and over 1.7GB of files,
>>> empowering DevOps and organizations worldwide.  Also note that this
>>> is a major release for MS4W, meaning that some things have changed
>>> dramatically (PHPmapscript will now use the SWIG API for example), so
>>> please follow MS4W's README for specific instructions for the many
>>> plugins and mapscripts.
>>> When installing, it is very important that (if you are using the
>>> .zip) your server must have the C++ Redistributable installed on it
>>> beforehand: execute the local file /ms4w/tmp/vcredist_x86.exe
>>> (alternatively if you use MS4W's setup.exe installer this is done
>>> automatically)
>>> Please provide your 4.0.0 testing feedback through the MS4W tracker
>>> (so the feedback is not lost or forgotten): http://www.ms4w.com/trac/
>>> Thank you all for sharing your spatial information with MS4W.
>>> -jeff
Jeff McKenna
MapServer Consulting and Training Services
https://gatewaygeomatics.com/
More information about the Mapbender_users mailing list
