[Mapbender-users] Color issue when printing search results
astrid.emde at wheregroup.com astrid.emde at wheregroup.com
Fri Feb 8 08:22:36 PST 2019
Hello Tobias
Am 2019-02-07 11:01, schrieb Tobias Kraft:
> Hi List,
> I have an issue with regard to printing results from the search
> router: in the map, search results are highlighted according to the
> settings in the styleMap, but on printing, in the resulting PDF the
> highlight color is greyed out. Is there a way to keep the styleMap
> settings in the print result, i.e. to have colored highlighting in the
> PDF?
> Cheers
> Tobias
Hello Tobias,
when you define a resultstyle for your feature they will be printed with
this color you defined for styleMap. This works fine for Mapbedner
version 3.0.7.7
   styleMap:
     default:
       strokeOpacity: 0.8
       strokeWidth: 2
       fillOpacity: 0.4
       pointRadius: 10
     select:
       strokeColor: '#002647'
       strokeWidth: 6
       strokeOpacity: 0.8
       fillColor: '#002647'
       fillOpacity: 0.4
As I knwo it was support sinve a long time already.
Which version do you use?
Astrid
More information about the Mapbender_users mailing list
