[Mapbender-users] Update on mapbender-3.0.8.1, the some php and http-errors
Uwe Seher uwe.seher at gmail.com
Wed Jun 26 23:48:03 PDT 2019
Hi David!
Thank you for the answer. I have changed the entry and the error is still
there.
Does Mapbender run with PHP 7.2 or greater? This will make things much
easier.
Best regards
Uwe Seher
Am Mi., 19. Juni 2019 um 14:53 Uhr schrieb David Patzke <
david.patzke at wheregroup.com>:
> Hi Uwe,
> as far as I can see, your php-intl uses an old version of ICU. Maybe you
> can try to update this package manually
> https://software.opensuse.org/package/php7-intl .
> For the 500 error, please temporary deactivate the logging function of thr
> OWSProxy in your config.yml with
> ows_proxy3_core:    logging: false
> This is a bug in the current release and will be fixed asap.
> Best regards
> David Patzke
> On 18.06.19 10:22, Uwe Seher wrote:
> Hello Group!
> These days i did an update from version 3.0.6.1 on 3.8.0. which worked
> good for the most parts. The underlying PHP is version 7.0 which was the
> only version with all necessary modules in the repository. openSuse Leap
> 15.0 seems to ignore version 7.1.
> After the update there are some annoying errors.
> First on the login-screen mapbender/user/login apears a errormessage
> "The server returned a "500 Internal Server Error"
> in the upper part of the screen. Below that, the login is ok an works
> fine. This is bad, because everey user first sees a large errormessage and
> i have no clue where it comes from. After login, the message disappears, so
> i think it is bound to the login-screen, the logfile shows this:
> [2019-06-18 07:51:44] request.INFO: Matched route
> "mapbender_core_login_logout".
> {"route_parameters":{"_controller":"Mapbender\\CoreBundle\\Controller\\LoginController::logoutAction","_route":"mapbender_core_login_logout"},"request_uri":"
> https://intranet.ib-kauppert.de/mb3/user/logout"} []
> [2019-06-18 07:51:44] request.CRITICAL: Uncaught PHP Exception
> Symfony\Component\Debug\Exception\FatalThrowableError: "Call to a member
> function getUser() on null" at
> /srv/www/htdocs/mapbender-starter-v3.0.8.1/owsproxy/src/OwsProxy3/CoreBundle/EventListener/LoggingListener.php
> line 57 {"exception":"[object]
> (Symfony\\Component\\Debug\\Exception\\FatalThrowableError(code: 0): Call
> to a member function getUser() on null at
> /srv/www/htdocs/mapbender-starter-v3.0.8.1/owsproxy/src/OwsProxy3/CoreBundle/EventListener/LoggingListener.php:57)"}
> [2019-06-18 07:51:49] request.INFO: Matched route
> "mapbender_core_login_login".
> {"route_parameters":{"_controller":"Mapbender\\CoreBundle\\Controller\\LoginController::loginAction","_route":"mapbender_core_login_login"},"request_uri":"
> https://intranet.ib-kauppert.de/mb3/user/login"} []
> [2019-06-18 07:51:49] request.CRITICAL: Uncaught PHP Exception
> Maybe this is problem is related to the next one:
> I have probably a Problem loading the php-etension intl. When I start php
> on the console it shows the message
> PHP Warning:  PHP Startup: Unable to load dynamic library
> '/usr/lib64/php7/extensions/intl.so' - /usr/lib64/php7/extensions/intl.so:
> undefined symbol: _ZNK8icu_57_117StringEnumeration5cloneEv in Unknown on
> line 0
> This seems to cause a Problem in the Print-Client, which causes the map
> not to load and show also an
> The server returned a "500 Internal Server Error".
> The logfile shows this error:
> [2019-06-18 08:04:10] request.INFO: Matched route
> "mapbender_core_application_application".
> {"route_parameters":{"_format":"html","_controller":"Mapbender\\CoreBundle\\Controller\\ApplicationController::applicationAction","slug":"mittelrhein","_route":"mapbender_core_application_application"},"request_uri":"
> https://intranet.ib-kauppert.de/mb3/application/mittelrhein"} []
> [2019-06-18 08:04:10] request.CRITICAL: Uncaught PHP Exception
> Symfony\Component\Debug\Exception\UndefinedFunctionException: "Attempted to
> call function "locale_get_default" from the global namespace." at
> /srv/www/htdocs/mapbender-starter-v3.0.8.1/mapbender/src/Mapbender/PrintBundle/Element/PrintClient.php
> line 155 {"exception":"[object]
> (Symfony\\Component\\Debug\\Exception\\UndefinedFunctionException(code: 0):
> Attempted to call function \"locale_get_default\" from the global
> namespace. at
> /srv/www/htdocs/mapbender-starter-v3.0.8.1/mapbender/src/Mapbender/PrintBundle/Element/PrintClient.php:155)"}
> If i deactivate the Printclient everything works fine.
> So my first question is, can this be caused by the problem with the
> php7-intl.so library and how can I handle this error  (i have no clue about
> php)? If not, the second question is, where does it come from and how can i
> get them handled. The printclient is not so important, but an error-message
> on the login-screen is really annoying.
> If you need more logs or other info please tell me.
> Thank you very much in advance
> Uwe Seher
> Mapbender_users mailing listMapbender_users at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/mapbender_users
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20190627/2cbaca54/attachment.html>
More information about the Mapbender_users mailing list
