[Mapbender-users] MS4W version 4.0.5 available
    Astrid Emde (WhereGroup)
    astrid.emde at wheregroup.com
    Thu Dec 17 23:04:45 PST 2020
Hello Jeff,
thanks a lot for the great news and for the MS4W release! Thanks for
integrating the brand new Mapbender 3.2.3 on MS4W.
Astrid
Am 2020-12-18 01:30, schrieb Jeff McKenna:
> Forwarding the details of today's MS4W 4.0.5 release, which the
> Mapbender community will find useful because it contains many fixes
> and upgrades for the Mapbender 3.2.x series, which affected the entire
> MS4W stack.  Indeed the MS4W 4.0.5 installer now includes Mapbender
> 3.2.3, which was also released earlier today I believe, coincidence.
> Details below...
> -------- Forwarded Message --------
> Hello everyone,
> MS4W 4.0.5 is now available, which contains many critical updates,
> such as the OpenSSL high-level security release, as well as an
> important upgrade to the PHP 7.4 series (as PHP 7.2 is no longer
> receiving security updates), into the Python 3.9 series also, plus
> rebuilds of the entire stack for the new pycsw version, Mapbender
> 3.2.x version, fast compression through Zstd for tiffs, latest PDAL,
> osm2pgsql, TinyOWS, and much more!   Get it now at https://ms4w.com
> Please see MS4W's HISTORY.txt for all of the changes, but here are
> some of the highlights:
>          - upgraded MapServer and MapScript (CSharp, Java, Python,
> PHP) to today's 7.7.0-dev
>          - upgraded PHP to 7.4.13 security release (trac ticket 243)
>          - upgraded MapCache to 1.11dev (git-master-20201214)
>          - upgraded to TinyOWS git-master-20201216
>          - modified TinyOWS config.xml to disable 'check_schema' to
> avoid HTTPS issues
>          - added content encoding declaration to TinyOWS demo template
>          - upgraded Apache HTTP Server to 2.4.46 (trac ticket 281)
>          - upgraded Python to 3.9.1 (trac ticket 245)
>          - upgraded pycsw to 2.6.0 (trac ticket 300)
>          - re-set pycsw to use Apache mod_wsgi instead of CGI (trac
> ticket 262)
>          - upgraded OpenSSL to 1.1.1i HIGH level security release
> (trac ticket 296)
>          - upgraded SWIG support to git-master-20201215
>          - rebuilt GDAL (including CSharp/Java/Python bindings,
> ECW/Oracle plugins)
>          - set PYTHONHOME in setenv.bat for the installer (trac ticket
> 285)
>          - minor updates to local.map
>          - change quickmap.php to use local.map
>          - added mention of Notepad++ syntax file into README_INSTALL
> (trac ticket 298)
>          - upgraded libjpeg-turbo support to 2.0.6 (trac ticket 294)
>          - rebuilt libTIFF support
>          - added libTIFF utilities into /tools (trac ticket 297)
>          - upgraded SQLite support to 3.34.0 (trac ticket 286)
>          - upgraded cURL support to 7.74.0 (trac ticket 279)
>          - rebuilt GeoTIFF support
>          - changed site link in README-geotiff.txt (trac ticket 283)
>          - upgraded Expat support to 2.2.10
>          - rebuilt HDF4 support
>          - rebuilt NetCDF support
>          - upgraded PostgreSQL support to 13.1 with SSL enabled (trac
> ticket 291)
>          - upgraded GEOS support to 3.9.0 (trac ticket 299)
>          - upgraded ICONV support to 1.16 (trac ticket 295)
>          - upgraded FreeXL support to 1.0.6
>          - rebuilt libxml2 support
>          - rebuilt SpatiaLite support
>          - rebuilt SpatiaLite-tools
>          - upgraded FITS support to 3.490
>          - added CFITSIO utilities into /tools
>          - upgraded Freetype support to 2.10.4
>          - rebuilt Cairo support
>          - rebuilt Poppler support
>          - upgraded Zstandard compression support (for TIFF) to 1.4.7
>          - upgraded to Oracle SDK 19.9.0.0.0
>          - rebuilt HarfBuzz support
>          - upgraded FriBidi support to 1.0.10 (trac ticket 215)
>          - rebuilt libSVG support
>          - rebuilt libSVG-Cairo support
>          - updated cURL certificates bundle
>          - rebuilt mod_fcgid
>          - rebuilt Apache H264 Streaming Module
>          - upgraded APCu to 5.1.19
>          - rebuilt php_ogr extension
>          - rebuilt mod_wsgi
>          - upgraded PDAL utilities to git-master-20201217
>          - properly enable the laz-perf library for the PDAL build
>          - upgraded osm2pgsql commandline utility to
> git-master-20201216
>          - updated the VC Redistributable in /tmp
> When installing, it is very important that (if you are using the .zip)
> your server must have the C++ Redistributable installed on it
> beforehand: execute the local file /ms4w/tmp/vcredist_x86.exe
> (alternatively if you use MS4W's setup.exe installer this is done
> automatically)
> As always please provide your requests for enhancements and issues
> through the MS4W tracker (so the feedback is not lost or forgotten):
> https://ms4w.com/trac/  You can also contact me directly for support.
> Wishing everyone a nice Christmas holiday,
> Thank you for using MS4W.
> "MS4W: open doors as well as windows"
> -jeff
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
Aufwind durch Wissen!
Web-Seminare und Online-Schulungen
bei der www.foss-academy.com
   Astrid Emde
   WhereGroup GmbH
   Eifelstraße 7
   53119 Bonn
   Germany
   Fon: +49(0)228 90 90 38 - 22
   Fax: +49(0)228 90 90 38 - 11
   www.wheregroup.com
   Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
More information about the Mapbender_users
