[Mapbender-users] Coordinates utility
Gal Zsolt zsolt.gal at satelitnt.com
Tue Jan 7 08:09:33 PST 2020
Hello Astrid,
Thanks for your answer.
I can't resolve my previous problem with Digitizer 1.3, where I cant load picture.
Here is a Mapbender installation <http://188.27.26.211/> where you can access with user root and password root with the only teszt application.
Foto 1 tab
Select
I select a picture, the progress bar show the upload, but after end the picture is not uploaded to /web/uploads/featureTypes/... (the directory featureTypes not created )
I try several things, (like learn Symfony 2.8) but I can't find a solution.
I will apreciate, if you take a look, and tell me if the problem is from my mabender-starter installation or is a bug in digitizer 1.3.
Thank you in advance.
Zsolt
P.S.
On 7 January 2020 at 13:45:05 +02:00, Astrid Emde (WhereGroup) <astrid.emde at wheregroup.com> wrote:
> Hello Zsolt,
> thanks for sharing your observations.
> I had a look at my application and everythin works fine. Unfortunately I can not reproduce your error.
> Coordinates Utility should initialize independent from SRS SELECTOR and SCALE SELECTOR.
> Coordinates Utility gets the SRS information from the map-element. So the map-element should be loaded before Coordinates Utility.
> It looks like you can get your second application running properly with SRS SELECTOR. Hope that is ok for the moment.
> Astrid
> Am 2019-12-10 08:39, schrieb Gal Zsolt:
> > Hello list!
> > I have two application where I need to use Coordinates Utility, find
> > place on map from coordinates. The first was made before I upgrade
> > Mapbender to 3.0.8 and works OK.
> > In the second application I try to use Coordinates Utility, but I get
> > error message:
> > YOUR ELEMENT ID 671 (WIDGET MAPBENDER.MBCOORDINATESUTILITY) FAILED TO
> > INITIALIZE PROPERLY.
> > After unsuccessful attempts to eliminate the error message I add SRS
> > SELECTOR to the application and the error disappear! The Coordinates
> > Utility works fine. If I remove the SRS SELECTOR the error message
> > reappear.
> > In the first application I don't use SRS SELECTOR! But I use SCALE
> > SELECTOR.
> > I remove the SRS SELECTOR and add a SCALE SELECTOR in the second
> > application and Coordinates Utility works fine.
> > I reread Coordinate utility documentation but I don't find any
> > reference about require to use SRS Selector or Scale selector with
> > Coordinate utility.
> > Have a nice day to everybody!
> > Mapbender_users mailing list
> > Mapbender_users at lists.osgeo.org
> > <https://lists.osgeo.org/mailman/listinfo/mapbender_users>
> Mit freundlichen Grüßen
> Astrid Emde
> GIS-Consultant
> Aufwind durch Wissen!
> Qualifizierte Open-Source-Schulungen
> bei der www.foss-academy.com
> Astrid Emde
> WhereGroup GmbH
> Eifelstraße 7
> 53119 Bonn
> Germany
> Fon: +49(0)228 90 90 38 - 22
> Fax: +49(0)228 90 90 38 - 11
> <http://www.wheregroup.com>
> Folgen Sie der WhereGroup auf twitter:
> <http://twitter.com/WhereGroup_com>
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20200107/8716e7f3/attachment.html>
More information about the Mapbender_users mailing list
