[Mapbender-users] Mapbender installation
Jörg Thomsen (WhereGroup) joerg.thomsen at wheregroup.com
Thu Jan 16 08:12:36 PST 2020
Hello Siline,
you can create / reset the root user from the command-line:
https://doc.mapbender.org/en/installation/configuration.html#creating-the-administrative-user
Cheers, Jörg
Am 09.01.20 um 10:00 schrieb Srun Siline:
> Hi
> Successfully installed the mapbender using using MySQL and using
> existing XAMPP webserve.
> but i can not login using user: root password root
> I check on mySQL database there is no record in table fom_user
> could you please help?
> Thanks,
> Siline
> On Thu, 9 Jan 2020 at 15:37, Srun Siline <srunsiline at gmail.com
> <mailto:srunsiline at gmail.com>> wrote:
>     Dear All,
>     I am trying to install mapbender using MySQL and using existing
>     XAMPP webserver.
>     I got stuck on: configuration database:
>     C:\xampp\php>php.exe c:/mapbender/app/console doctrine:fixtures:load
>     --fixtures=./mapbender/src/Mapbender/CoreBundle/DataFixtures/ORM/Epsg/
>     --append
>       [InvalidArgumentException]
>       Could not find any fixtures to load in:
>       - ./mapbender/src/Mapbender/CoreBundle/DataFixtures/ORM/Epsg/
>     Thanks
>     Siline
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Viele Grüße,
Jörg Thomsen
Aufwind durch Wissen!
Qualifizierte Open-Source-Schulungen
bei der www.foss-academy.com
Jörg Thomsen
WhereGroup GmbH
Bundesallee 23
10717 Berlin
Germany
Fon: +49 (0)30 / 5130 278 74
Fax: +49 (0)30 / 5130 278 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
More information about the Mapbender_users mailing list
