[Mapbender-users] Zoom to layer in layer tree not working properly
Sajid Pareeth spareeth at gmail.com
Tue Jun 9 11:49:57 PDT 2020
Hi Armin
Thank you, that solved the problem.
I overlooked these differences between different versions of WMS, though I
found it a bit confusing. Anyways, will be more cautious on these aspects,
when we combine WMS from different sources.
Thanks again
Regards
Sajid
On Tue, Jun 9, 2020 at 5:57 AM Armin Retterath <
armin.retterath at vermkv.rlp.de> wrote:
> hi sajid,
> maybe the bbox of the layers are not handled consistently - here are the
> crs related extracts from the capabilities docs:
> wms 1.1.1
> <SRS>EPSG:4326</SRS>
> <LatLonBoundingBox minx="75.61699436455098" miny="16.19036450771302"
> maxx="77.30248329850956" maxy="17.47232605225013"/>
> <BoundingBox SRS="EPSG:4326" minx="75.61699436455098"
> miny="16.190364507713397" maxx="77.30248329847431"
> wms 1.3.0
> ... many crs ...
> <CRS>CRS:84</CRS>
> <EX_GeographicBoundingBox>
> <westBoundLongitude>75.61699436455098</westBoundLongitude>
> <eastBoundLongitude>77.30248329850956</eastBoundLongitude>
> <southBoundLatitude>16.19036450771302</southBoundLatitude>
> <northBoundLatitude>17.47232605225013</northBoundLatitude>
> </EX_GeographicBoundingBox>
> <BoundingBox CRS="CRS:84" minx="75.61699436455098"
> miny="16.19036450771302" maxx="77.30248329850956" maxy="17.47232605225013"/>
> <CRS>EPSG:4326</CRS>
> <CRS>CRS:84</CRS>
> <BoundingBox CRS="EPSG:4326" minx="16.190364507713397"
> miny="75.61699436455098" maxx="17.47232605225013" maxy="77.30248329847431"/>
> you see, that the axis order in wms 1.3.0 is switched fom lat/lon to
> lon/lat - this is defined in the ogc standards.
> you use wms 1.1.1 for the basemap and wms 1.3.0 for your own resource -
> therefor mapbender will switch the extents i think. test to register your
> service with wms version 1.1.1 and it will work. maybe you can register
> both services with version 1.3.0 and it may also work ;-) .
> best regards
> armin
> > Sajid Pareeth <spareeth at gmail.com> hat am 8. Juni 2020 um 23:43
> geschrieben:
> > Hi list
> > I have deployed a mapbender application with many geoserver based WMS
> > layers listed.
> > But the "zoom to layer" function under each layer is not working
> properly.
> > The layer is zoomed to some where else. It seems, the BBOX x and y are
> > swapped when zoomed to layer.
> > Here is a demo app with one of my layer (bdry) under layerset called ABC,
> > displayed on top of two other base WMS layers.
> > http://www.wa-urmia.org/mapbender/application/test
> > The geoserver link to my wms layer is:
> > http://188.40.139.182:8080/geoserver/nlbc_bdry/wms
> > I am using the latest version of mapbender 3.0.8 and geoserver version is
> > 2.17.0
> > Can anyone help me with this?
> > Thanks in advance
> > Regards
> > Sajid
> > Sajid Pareeth, Ph.D
> > Researcher – Remote sensing
> > Water Science and Engineering Department
> > UNESCO-IHE Institute for Water Education
> > Delft, The Netherlands
> > Phone No.: +31 (0)15 215 2395 <+31%2015%20215%201825>
> > Skype ID: spareeth
> > Mapbender_users mailing list
> > Mapbender_users at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/mapbender_users
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20200609/1b636790/attachment-0001.html>
More information about the Mapbender_users mailing list
