[Mapbender-users] Mapbender App Publishing (disable localhost)
Walter White Jr. whitejrdot at gmail.com
Wed Jun 10 02:29:12 PDT 2020
Hello Jörg, hello David,
many thanks for your helpful responses.
Walter
Am Di., 2. Juni 2020 um 09:26 Uhr schrieb David Patzke <
david.patzke at wheregroup.com>:
> Hello Walter.
> Jörgs' answer might not be wrong but I think this is not exactly what
> you are hoping for.
> Your question is not exactly Mapbender related more a general question
> about webpages and hosting.
> You should research a little bit about how a webpage comes into the
> internet e.G. here
> https://studywebdevelopment.com/web-development-basics-for-beginners.html
> David
> On 02.06.20 09:17, Jörg Thomsen (WhereGroup) wrote:
> > Hello Walter,
> > you have to know the ip-address of your vm and the network for the vm
> > has to be enabled (you can access websites or external WMS from within
> > your vm).
> > try 'ifconfig' in the vm's terminal and then use the shown ip-address in
> > the browser in your host, this should shw the start-page of the
> osgeo-live.
> > Jörg
> > Am 01.06.20 um 00:15 schrieb Walter White Jr.:
> >> Hello community,
> >> this is surely an elementary question but I am new in the Mapbender
> >> world. Using OsGeoLive 13 on the Oracle VM Virtual Box, I have created a
> >> WMS (1.3.0) in Geoserver (2.15.1). In Mapbender (3.0.8.1), I have
> >> created a new application and did all of the necessary configuration,
> >> defined the layersets and the layouts. The problem is I see the app just
> >> as localhost (also in Geoserver) so I cannot call the app from another
> >> computer. My aim is to publish the app for the broad public and not just
> >> as localhost. Can you please tell me how to do that or which settings
> >> are necessary? I don´t know if this has something to do with the
> >> Virtuall Machine itself or if I need to do something in
> >> Geoserver/Mapbender. Or is this in OsGeoLive in general not possible and
> >> do I need to install Geoserver and Mapbender manually? I am not sure if
> >> the OsGeoLive cointains automatically after installation the Apache or
> >> no (maybe this could be the issue). I know how to create the WMS layer
> >> incl. styles etc. or configure the app in Mapbender but I don´t know to
> >> publish is as an open web-service for everyone...
> >> Many thanks for your help.
> >> Walter Jr.
> >> _______________________________________________
> >> Mapbender_users mailing list
> >> Mapbender_users at lists.osgeo.org
> >> https://lists.osgeo.org/mailman/listinfo/mapbender_users
> > Viele Grüße,
> > Jörg Thomsen
> Aufwind durch Wissen!
> Qualifizierte Open-Source-GIS-Schulungen
> bei der www.foss-academy.com
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20200610/833ae00f/attachment.html>
More information about the Mapbender_users mailing list
