[Mapbender-users] Add New Projection in Mapbender
wesley mezine wesleymezine at gmail.com
Wed Jun 17 03:52:40 PDT 2020
Hello Astrid,
Thank you very much for your help, I can add OSM and Bing Maps services in
the desired projection.  How can I do this ?
Regards,
Wesley
Em qua, 17 de jun de 2020 04:18, Astrid Emde (WhereGroup) <
astrid.emde at wheregroup.com> escreveu:
> Hello Weley,
> you can add more supported projections for your application by adding
> them to the map-element at the section other SRS.
> See documentation
> https://doc.mapbender.org/en/functions/basic/map.html#configuration
> Please note that Mapbender can't effect the projections that your WMS
> supports. Mapbender is only the client.
> Astrid
> Am 2020-06-16 15:10, schrieb wesley mezine:
> > Hi,
> > How do I add a new projection on the map?
> > Regards,
> > Weley
> > Mapbender_users mailing list
> > Mapbender_users at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/mapbender_users
> Mit freundlichen Grüßen
> Astrid Emde
> GIS-Consultant
>   Aufwind durch Wissen!
>   Jetzt neu: Webinare und Online-Schulungen
>   bei der www.foss-academy.com
>    Astrid Emde
>    WhereGroup GmbH
>    Eifelstraße 7
>    53119 Bonn
>    Germany
>    Fon: +49(0)228 90 90 38 - 22
>    Fax: +49(0)228 90 90 38 - 11
>    www.wheregroup.com
>    Folgen Sie der WhereGroup auf twitter:
> http://twitter.com/WhereGroup_com
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20200617/bee19e0e/attachment.html>
More information about the Mapbender_users mailing list
