[Mapbender-users] User-Name as an attribute in the digitizer
Astrid Emde (WhereGroup) astrid.emde at wheregroup.com
Mon Oct 26 05:38:05 PDT 2020
Hello Uwe,
with Mapbender 3.0.8.1 you can not use this feature.
It is likely that Mapbender 3.2.2 is release in some weeks. YOu can try
it with that version. But I can not assure it.
Astrid
Am 2020-10-26 12:11, schrieb Uwe Seher:
> Hello again!
> If i read you right, with Mapbender 3.0.8.1 i can not use this feature
> as long as i update in a couple of weeks.
> Thank you for your help
> best regards
> Uwe Seher
> Am Do., 22. Okt. 2020 um 12:35 Uhr schrieb Astrid Emde (WhereGroup)
> <astrid.emde at wheregroup.com>:
>> Hello,
>> the definition is in the feature section and the user name is
>> referred
>> via $user and groups as $userRoles (which is an array):
>> featureType:
>> connection: geodata_db
>> table: poi
>> uniqueId: gid
>> geomType: point
>> geomField: geom_25832
>> srid: 25832
>> filter: 'st_isempty(geom_25832)
>> false'
>> events:
>> onBeforeSave:
>> $feature->setAttribute('abstract', 'MAPS');
>> $feature->setAttribute('user_name', $user
>> );$feature->setAttribute('group', implode(',', $userRoles));
>> But it looks like this feature is not working with the actual
>> Mapbender
>> 3.0.8.6 which uses digitizer 1.1.x. It works with digitzer 1.3
>> version.
>> To change to the 1.3 version you have install Mapbender via Github
>> and
>> change in composer.json to "mapbender/digitizer": "dev-release/1.3",
>> Then you can build your own mapbender with digitizer 1.3.
>> Astrid
>> Best regards Astrid
>> Am 2020-10-22 08:58, schrieb Toma, Charlotte:
>>> Hello Uwe,
>>> you can use the „events“ to add predefined attributes from the
>>> mapbender database, e.g. the groupname or the username. You can
>> use
>>> the example in the documentation
> (https://doc.mapbender3.org/en/functions/editing/digitizer.html#events
>>> [1]) and add the „onBeforeSafe“ event. Furthermore you need a
>>> coulumn in your table to save the information.
>>> Greetings from Wiesbaden
>>> Charly
>>> Mit freundlichen Grüßen
>>> im Auftrag
>>> Charlotte Toma
>>> Landeshauptstadt Wiesbaden
>>> -Der Magistrat-
>>> Stadtplanungsamt
>>> -610230-
>>> Gustav-Stresemann-Ring 15
>>> 65189 Wiesbaden
>>> Tel.: 0611 31-3436
>>> Fax: 0611 31-3917
>>> E-Mail: 61GIS at wiesbaden.de
>>> Internet: www.wiesbaden.de [1] [2]
>>> Jede nicht gedruckte Seite spart Holz, Wasser und Strom.
>>> Von: Mapbender_users
>> [mailto:mapbender_users-bounces at lists.osgeo.org]
>>> Im Auftrag von Uwe Seher
>>> Gesendet: Donnerstag, 22. Oktober 2020 08:14
>>> An: Mapbender User List <mapbender_users at lists.osgeo.org>
>>> Betreff: [Mapbender-users] User-Name as an attribute in the
>> digitizer
>>> Hello!
>>> I want to log, when a feature has been changed by the digitizer.
>> Is
>>> there a possibillity to use the logged in username as an attribute
>> in
>>> the digitizer form or store it otherways in the edited feature?
>>> Thank you in advance
>>> Uwe Seher
>>> Links:
>>> [1]
>>> [2] http://www.wiesbaden.de/
>>> Mapbender_users mailing list
>>> Mapbender_users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/mapbender_users
>> Astrid Emde
>> GIS-Consultant
>> Aufwind durch Wissen!
>> Jetzt neu: Web-Seminare und Online-Schulungen
>> bei der www.foss-academy.com [2]
>> Astrid Emde
>> WhereGroup GmbH
>> Eifelstraße 7
>> 53119 Bonn
>> Germany
>> Fon: +49(0)228 90 90 38 - 22
>> Fax: +49(0)228 90 90 38 - 11
>> www.wheregroup.com [3]
>> Folgen Sie der WhereGroup auf twitter:
>> http://twitter.com/WhereGroup_com
>> Geschäftsführer:
>> Olaf Knopp, Peter Stamm
>> Amtsgericht Bonn, HRB 9885
> Links:
> [1] http://www.wiesbaden.de
> [2] http://www.foss-academy.com
> [3] http://www.wheregroup.com
Astrid Emde
GIS-Consultant
   Astrid Emde
   WhereGroup GmbH
   Eifelstraße 7
   53119 Bonn
   Germany
   www.wheregroup.com
Geschäftsführer:
More information about the Mapbender_users mailing list
