[Mapbender-users] root pw
Birger.Boell at lbv-sh.landsh.de Birger.Boell at lbv-sh.landsh.de
Thu Sep 17 03:17:05 PDT 2020
i wanted to change my root password. Now I can't log in anymore as root. I really have no idea why. I tried the app/console reset - the console told me that it's working, but i cant login. The logs tell me:
[2020-09-17 12:33:36] request.INFO: Matched route "fom_user_password_form". {"route_parameters":{"_controller":"FOM\\UserBundle\\Controller\\PasswordController::formAction","_route":"fom_user_password_form"},"request_uri":"http://10.48.242.187/mapbender/user/password"} []
[2020-09-17 12:33:36] request.ERROR: Uncaught PHP Exception Symfony\Component\HttpKernel\Exception\NotFoundHttpException: "" at /var/www/mapbender/fom/src/FOM/UserBundle/Controller/UserControllerBase.php line 66 {"exception":"[object] (Symfony\\Component\\HttpKernel\\Exception\\NotFoundHttpException(code: 0):  at /var/www/mapbender/fom/src/FOM/UserBundle/Controller/UserControllerBase.php:66)"} []
[2020-09-17 12:34:39] request.INFO: Matched route "fom_user_password_form". {"route_parameters":{"_controller":"FOM\\UserBundle\\Controller\\PasswordController::formAction","_route":"fom_user_password_form"},"request_uri":"http://10.48.242.187/mapbender/user/password"} []
[2020-09-17 12:34:39] security.INFO: Populated the TokenStorage with an anonymous Token. [] []
[2020-09-17 12:34:39] request.ERROR: Uncaught PHP Exception Symfony\Component\HttpKernel\Exception\NotFoundHttpException: "" at /var/www/mapbender/fom/src/FOM/UserBundle/Controller/UserControllerBase.php line 66 {"exception":"[object] (Symfony\\Component\\HttpKernel\\Exception\\NotFoundHttpException(code: 0):  at /var/www/mapbender/fom/src/FOM/UserBundle/Controller/UserControllerBase.php:66)"} []
[2020-09-17 12:38:01] request.INFO: Matched route "fom_user_password_form". {"route_parameters":{"_controller":"FOM\\UserBundle\\Controller\\PasswordController::formAction","_route":"fom_user_password_form"},"request_uri":"http://10.48.242.187/mapbender/user/password"} []
[2020-09-17 12:38:01] request.ERROR: Uncaught PHP Exception Symfony\Component\HttpKernel\Exception\NotFoundHttpException: "" at /var/www/mapbender/fom/src/FOM/UserBundle/Controller/UserControllerBase.php line 66 {"exception":"[object] (Symfony\\Component\\HttpKernel\\Exception\\NotFoundHttpException(code: 0):  at /var/www/mapbender/fom/src/FOM/UserBundle/Controller/UserControllerBase.php:66)"} []
[2020-09-17 12:48:59] request.ERROR: Uncaught PHP Exception Symfony\Component\HttpKernel\Exception\NotFoundHttpException: "No route found for "GET /application/mb3-login/assets/underscore-min.map"" at /var/www/mapbender/app/cache/prod/classes.php line 2135 {"exception":"[object] (Symfony\\Component\\HttpKernel\\Exception\\NotFoundHttpException(code: 0): No route found for \"GET /application/mb3-login/assets/underscore-min.map\" at /var/www/mapbender/app/cache/prod/classes.php:2135, Symfony\\Component\\Routing\\Exception\\ResourceNotFoundException(code: 0):  at /var/www/mapbender/app/cache/prod/appProdProjectContainerUrlMatcher.php:813)"} []
Maybe anyone of you can help me?
Maybe this can help: I have more trouble with the demo database file. I'm not able to connect to another database at localhost. There is a mysql database running which i would like to use, but i can't get it to work, so im using still the demo database.
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20200917/0ef144f3/attachment.html>
More information about the Mapbender_users mailing list
