[Mapbender-users] Mapbender installation PHP configuration
Walter White Jr. whitejrdot at gmail.com
Sat Jan 9 07:39:28 PST 2021
Hi Astrid,
thank you for your response.
The quick installation using the MS4W-Installer is just for testing and not
for a productive env right?
So, for the productive version I suppose I need to install and configurate
all elements separately.
(1)   I have checked the vars in the php.ini-development file:
; Directory where the temporary files should be placed.
; Defaults to the system default (see sys_get_temp_dir)
; sys_temp_dir = "/tmp"
; Temporary directory for HTTP uploaded files (will use system default if
not
; specified).
; http://php.net/upload-tmp-dir
;upload_tmp_dir =
[Date]
; Defines the default timezone used by the date functions
; http://php.net/date.timezone
;date.timezone =
For
upload_tmp_dir
date.timezone
vars no dir are set.
Which dir should be set?
(2)   After the php installation there is NO bin folder so I cannot set the
env var path for this. Or should I just add an empty bin folder to PHP and
add this path to the new env var?
(3)   In the php.ini-development file there are more sections with
extensions, e.g.:
; Notes for Windows environments :
; - Many DLL files are located in the extensions/ (PHP 4) or ext/ (PHP 5+)
;   extension folders as well as the separate PECL DLL download (PHP 5+).
;   Be sure to appropriately set the extension_dir directive.
;extension=bz2
;extension=curl
;extension=fileinfo
;extension=gd2
;extension=gettext
;extension=gmp
;extension=intl
;extension=imap
;extension=interbase
;extension=ldap
;extension=mbstring
;extension=exif      ; Must be after mbstring as it depends on it
;extension=mysqli
;extension=oci8_12c  ; Use with Oracle Database 12c Instant Client
;extension=odbc
;extension=openssl
;extension=pdo_firebird
;extension=pdo_mysql
;extension=pdo_oci
;extension=pdo_odbc
;extension=pdo_pgsql
;extension=pdo_sqlite
;extension=pgsql
;extension=shmop
               Are these the dynamic extensions? Or where exactly should I
paste these?
 Thank you again for your help.
Kind regards
Walter
Am Mo., 4. Jan. 2021 um 09:28 Uhr schrieb Astrid Emde (WhereGroup) <
astrid.emde at wheregroup.com>:
> Hello Walter,
> you also could take MS4W to install Mapbender.
> https://ms4w.com/
> Elso you should find the information at:
> https://doc.mapbender.org/en/installation/installation_windows.html
> Am 2021-01-03 22:24, schrieb Walter White Jr.:
> > Hi folks,
> > I want to install Mapbender 3.0.8 on Windows 10 to launch an own
> > web-gis app on my website but have some problems with the PHP
> > installation. I already have installed PHP 7.2.33, Apache 2.4 and
> > PostgreSQL 9 but have some problems with the PHP configuration.
> > (1) It needs to be checked if the following variables (php.ini) are
> > set correctly:
> > sys_temp_dir
> > upload_tmp_dir
> > date.timezone
> > Where should I check this? In the cmd, one of the php.exe files?
> You have to check this in the php.ini file
> > (2)   “the path from PHP-bin directory to the PATH-variable (Windows
> > environment variable) needs to be set”
> > There is no PHP-bin directory in the PHP file after installation so
> > how can I add the PHP-bin path as another Win environment var?
> Go to the environment variables.
> Here you find a description how it works:
> https://support.shotgunsoftware.com/hc/en-us/articles/114094235653-Setting-global-environment-variables-on-Windows
> > (3)   “activate the required PHP extensions in the php.ini
> > configuration file:”
> > # php.ini
> > extension=php_curl.dll
> > extension=php_fileinfo.dll
> > extension=php_gd2.dll
> > extension=php_intl.dll
> > extension=php_pdo_pgsql.dll
> > extension=php_pdo_sqlite.dll
> > extension=php_pgsql.dll
> > extension=php_openssl.dll
> > extension=php_mbstring.dll
> > extension=php_zip.dll
> > extension=php_bz2.dll
> > Should I just add these lines into the php.ini file or what should I
> > do?
> In the php.ini file you find a section with extensions. There you can
> activate the mentioned extension.
> Do not forget to restart your Apache Service afterwards.
> In the Mapbender installation we do  not describe how to install apache
> or PHP. You find information about that online.
> Hope my comments help.
> Best regards
> Astrid
> > I want to emphasize I am not a web developer so I suppose these are
> > elementary questions but since Mapbender promises to create map apps
> > without a single line of code I was hoping I can manage that on my own
> > (have some knowledge about GDI). I was not able to find something
> > helpful on the internet so I hope you can help me with this. Would
> > appreciate any help.
> > Many thanks in advance!
> >                [1]
> >               Virenfrei. www.avast.com [1]
> > Links:
> > [1]
> https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail
> > Mapbender_users mailing list
> > Mapbender_users at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/mapbender_users
> Mit freundlichen Grüßen
> Astrid Emde
> GIS-Consultant
> Das WhereGroup-Team wünscht Ihnen
> ein frohes Weihnachtsfest und
> einen guten Start ins Jahr 2021!
>    Astrid Emde
>    WhereGroup GmbH
>    Eifelstraße 7
>    53119 Bonn
>    Germany
>    Fon: +49(0)228 90 90 38 - 22
>    Fax: +49(0)228 90 90 38 - 11
>    www.wheregroup.com
>    Folgen Sie der WhereGroup auf twitter:
> http://twitter.com/WhereGroup_com
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20210109/40e38487/attachment-0001.html>
More information about the Mapbender_users mailing list
