[Mapbender-users] #Mapbender #SearchRouter #PostgreSQLconnection
Jörg Thomsen (WhereGroup) joerg.thomsen at wheregroup.com
Wed Jun 8 08:05:24 PDT 2022
Hello Marcin,
thanks for your praise!
Your config looks OK, to be sure:
  - port 5433 is correct, you are using pgbouncer?
  - name of the database is dzrol? (parameters.yml)
  - name of the table is dzrol too (relation: dzrol)
What's the error you get? Using the network-tools of the browser you can
have a look at the request and results Mapbender sends and gets back
from the server. Can find any hints in the Mapbender log-files?
For testing I would use
compare: ilike (instead of exact)
To your 2nd question:
Do you know https://doc.mapbender.org/en/development/element_generate.html
You will find there how to create an own working MB-Element in general.
  The rest should be done with html/javascript, php on server-side an a
some blood, sweat and tears.
Am 08.06.22 um 16:29 schrieb Marcin Niemyjski:
> Hello there,
> I have recently started my adventure with Mapbender. From here I wanted
> to congratulate you for doing a good job in providing free geoprocessing
> solutions.
> While creating the geportal I encountered a problem. I would like to add
> a Search Router to my geportal but I am having trouble connecting to a
> PostgreSQL database. Is it enough if I change database properties in
> config parameters.yml file to properties of my database and then define
> what I want to search in the Contents tab?
> I also have a question about defining checkboxes in Mapbender. I would
> like to create a feature using FeatureInfo that displays a graph created
> based on data from columns in the database, but the graphs in the image
> would only come from columns whose names are marked with chechboxes.
> Could you please tell me how I could achieve this functionality and what
> I need to learn to do it?
> I am also uploading a text file (konfiguracja_Mapbender) showing how I
> configured the parameteres.yml, config.yml and search router
> configuration files. It would be great if you could check where there
> might be a mistake or maybe I am leaving something out.
> Best regards,
> Marcin Niemyjski
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Viele Grüße,
Jörg Thomsen
Aufwind durch Wissen!
Jetzt neu: Web-Seminare und Online-Schulungen
bei der www.foss-academy.com
Jörg Thomsen
WhereGroup GmbH
Bundesallee 23
10717 Berlin
Germany
Tel: +49 (0)30 / 5130 278 74
Fax: +49 (0)30 / 5130 278 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
More information about the Mapbender_users mailing list
