[Mapbender-users] #WMS #Mapbender #Tiles
Astrid Emde (WhereGroup) astrid.emde at wheregroup.com
Mon Jun 20 08:08:39 PDT 2022
Hello Marcin,
what version of Mapbender do you use?
There was a bug, that Mapbender does not send the parameter
TRANSPARENT=TRUE in upper case in the getMap-Request. Some services
ignore the parameter, when it is in lower case.
Image png is fine for a layer with transparency
Please check your getMap-Request and modify it. If TRANSPARENT=TRUE
solves the problem you can go to the Mapbender code and fix it.
You find a desciption here:
https://github.com/mapbender/mapbender/issues/1418
https://github.com/mapbender/mapbender/pull/1419/files
The fix will also be available in the next version.
See you Astrid
Am 2022-06-20 16:51, schrieb Marcin Niemyjski:
> Hello,
> I'm back with some questions about MapBender. I created a WMS layer
> which after uploading to QGIS or Mapbender looks like this:
> https://pasteboard.co/vM3SKvRZ5krL.png
>  I need the displayed wms not to cover other layers. The WMS comes
> from mapcache, and the tiles are transparent when checked in another
> program.
> When I win this way to QGIS https://pasteboard.co/IU3LV6yB57Kv.png [1]
> I get the effect I wanted https://pasteboard.co/ojWVBug6yDLC.png [2]
> Could you please advise me how I could achieve such state of things in
> MapBender?
> The source paths that are shown by qgis when adding a new wms layer
> (the one with the black background and the good one with the
> transparent one) differ only in tileMatrixSet=.
>  Best regards,
> Marcin
> Links:
> [1] https://pasteboard.co/IU3LV6yB57Kv.png
> [2] https://pasteboard.co/ojWVBug6yDLC.png
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
Aufwind durch Wissen!
Jetzt neu: Web-Seminare und Online-Schulungen
bei der www.foss-academy.com
   Astrid Emde
   WhereGroup GmbH
   Eifelstraße 7
   53119 Bonn
   Germany
   Tel: +49(0)228 90 90 38 - 22
   Fax: +49(0)228 90 90 38 - 11
   www.wheregroup.com
   Meinen PGP Public-Key können Sie unter pgp.mit.edu herunterladen:
https://keys.openpgp.org/vks/v1/by-fingerprint/01F8152D36FC07C25EADDE86C5084ACC1C287CCB
   Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
   Folgen Sie der WhereGroup auf twitter:
   http://twitter.com/WhereGroup_com
   Geschäftsführer:
   Olaf Knopp, Peter Stamm
   Amtsgericht Bonn, HRB 9885
Type: application/pgp-keys
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20220620/3cf86bd5/attachment.key>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20220620/3cf86bd5/attachment.sig>
More information about the Mapbender_users mailing list
