[Mapbender-users] Logfile / errorfile from VMS loader
Henrik Bytoft Holm hbh at odenserenovation.dk
Thu Mar 17 05:36:35 PDT 2022
F12 is our friend..
Problem solved.... mixed ssl/non-ssl, if I run everything non-SSL it works 😊
Med venlig hilsen / Best regards
Henrik Bytoft Holm
IT-medarbejder
snapindvej 21 - 5200 Odense v - Denmark
T: +45 2446 9732
M: +45 2446 9732
@: hbh at odenserenovation.dk
-----Oprindelig meddelelse-----
Fra: Mapbender_users <mapbender_users-bounces at lists.osgeo.org> På vegne af Astrid Emde (WhereGroup)
Sendt: 17. marts 2022 13:35
Til: Mapbender User List <mapbender_users at lists.osgeo.org>
Emne: Re: [Mapbender-users] Logfile / errorfile from VMS loader
Hello Henrik,
please check via F12 and look for the Netzwork tab and the errors of the WMS map-request.
Does your WMS support the EPSG of the application?
F12 is your friend ;)
See you Astrid
Am 2022-03-17 13:12, schrieb Henrik Bytoft Holm:
> Hi,
> I have installed the mapbender package for windows. I can create ned
> applications and create baselayers with maps from OSM.
> I'm trying to load VMS laysers published from out internal GeoServer.
> I can make the connection and see the published layers from the
> geoserver in the layersets in Mapbender.
> Then I load the application, my VMS layers is "grey'ed out" (out of
> box boundary) then I pan/zoom the map into the area where the VMS
> layer is, the layer becomes red and an error occurs…. The problem is
> there is no error message/tooltip explaining the error…..
> Where can I see debug information on these errors ?
> Henrik Bytoft Holm
> _IT-medarbejder_
> T:
>  +45 2446 9732
> M:
> +45 2446 9732
> hbh at odenserenovation.dk<mailto:hbh at odenserenovation.dk>
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org<mailto:Mapbender_users at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
Aufwind durch Wissen!
Jetzt neu: Web-Seminare und Online-Schulungen bei der www.foss-academy.com<http://www.foss-academy.com>
   Astrid Emde
   WhereGroup GmbH
   Eifelstraße 7
   53119 Bonn
   Germany
   Tel: +49(0)228 90 90 38 - 22
   Fax: +49(0)228 90 90 38 - 11
   astrid.emde at wheregroup.com<mailto:astrid.emde at wheregroup.com>
   www.wheregroup.com<http://www.wheregroup.com>
   Meinen PGP Public-Key können Sie unter pgp.mit.edu herunterladen:
https://keys.openpgp.org/vks/v1/by-fingerprint/01F8152D36FC07C25EADDE86C5084ACC1C287CCB
   Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
   Folgen Sie der WhereGroup auf twitter:
   http://twitter.com/WhereGroup_com
   Geschäftsführer:
   Olaf Knopp, Peter Stamm
   Amtsgericht Bonn, HRB 9885
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20220317/9b4f6679/attachment.html>
More information about the Mapbender_users mailing list
