[Mapbender-users] Encountering a problem while attempting to display data from multiple dates simultaneously using the time dimension handler
Astrid Emde (WhereGroup) astrid.emde at wheregroup.com
Thu Aug 10 01:37:26 PDT 2023
Hello Marcin,
Mapbender currently only supports the min/max/resolution syntax for
defining (time) dimensions.
There is an issue discussing about "Support all syntax modes for WMS-T
Dimension" and we try to work on it for Version 4.
https://github.com/mapbender/mapbender/issues/1271#issuecomment-1607340578
If you would like to support the development you are welcome. Please
contact us.
See you Astrid Emde
Am 2023-08-07 14:06, schrieb Marcin Niemyjski:
> Hello,
>  I encountered a problem while adding a WMS containing an active time
> dimension. Specifically, I am only able to navigate along the time
> axis day by day. However, I would like to navigate using a time range,
> for example, displaying data from a weekly period. Is this possible?
>  This is my mapfile (for understanding how I configured the time
> dimension):
>  https://pastecode.io/s/hbcz3z7p
>  and WMS url:
> http://64.225.135.141.nip.io/?map=/etc/mapserver/piramida_cloudless.map
>  Also, I do not understand why in mapbender I cannot select other
> query types than nearest?
> WMS instance configuration tab:
>  https://pasteboard.co/lxatPoUo2vtL.png
>  So basically, what I want to achieve is to have ability to get data
> from multiple dates using time slider (time dimension handler).
>  Best,
>  Marcin
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
Aufwind durch Wissen!
Web-Seminare und Online-Schulungen
bei der www.foss-academy.com/
   Astrid Emde
   WhereGroup GmbH
   Eifelstraße 7
   53119 Bonn
   Germany
   Tel: +49(0)228 90 90 38 - 22
   Fax: +49(0)228 90 90 38 - 11
   www.wheregroup.com
   Meinen PGP Public-Key können Sie unter pgp.mit.edu herunterladen:
https://keys.openpgp.org/vks/v1/by-fingerprint/01F8152D36FC07C25EADDE86C5084ACC1C287CCB
   Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
   Folgen Sie der WhereGroup auf twitter:
   http://twitter.com/WhereGroup_com
   Geschäftsführer:
   Olaf Knopp, Peter Stamm
   Amtsgericht Bonn, HRB 9885
Type: application/pgp-keys
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20230810/b170bcf3/attachment.key>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20230810/b170bcf3/attachment.sig>
More information about the Mapbender_users mailing list
