[Mapbender-users] Filtering and searching
Tjiko Schutte tjikoschutte at hotmail.com
Wed Mar 22 03:21:19 PDT 2023
Hope some can help. I have configured the search module. But I'm not sure how to implement the query.
For example if you have the url /items?f=json&limit=10&filter=adres%3D%27HEREISTHEADRES%27&.
How can i Put HEREISTHEADRES in the query? When I put q there. It doesnt do anything
A seperate question.
Is filtering also possible. For example I have a map with 9000 points.
3000 have value A, 3000 value B and 3000 value C.
Can I filter (not search) the map on only value B.
So the points on the map will be reduced to 3000 (and not 9000).
Thanks in advance.
Kind regards,
Tjiko Schutte
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20230322/73e8525f/attachment.htm>
More information about the Mapbender_users mailing list
