[Mapbender-users] Mapbender | Fehler bei Änderung des Passworts
Claßen, Jens Jens.Classen at erftstadt.de
Tue Oct 31 03:28:15 PDT 2023
Hallo in die Runde!
Leider erhalte ich immer den folgenden Fehler wenn ich "Passwort vergessen" auswähle:
Oops! An Error Occurred
The server returned a "404 Not Found".
Something is broken. Please let us know what you were doing when this error occurred. We will fix it as soon as possible. Sorry for any inconvenience caused.
Die prod.log sagt mit folgende Fehlermeldung:
[2023-10-31 10:10:08] request.INFO: Matched route "fom_user_password_form". {"route":"fom_user_password_form","route_parameters":{"_route":"fom_user_password_form","_controller":"FOM\\UserBundle\\Controller\\PasswordController::formAction"},"request_uri":"http://geoportal.erftstadt.intern:8008/mapbender/user/password","method":"GET"} []
[2023-10-31 10:10:08] security.INFO: Populated the TokenStorage with an anonymous Token. [] []
[2023-10-31 10:10:08] request.ERROR: Uncaught PHP Exception Symfony\Component\HttpKernel\Exception\NotFoundHttpException: "" at C:\mapbender\mapbender\src\FOM\UserBundle\Controller\AbstractEmailProcessController.php line 57 {"exception":"[object] (Symfony\\Component\\HttpKernel\\Exception\\NotFoundHttpException(code: 0):  at C:\\mapbender\\mapbender\\src\\FOM\\UserBundle\\Controller\\AbstractEmailProcessController.php:57)"} []
Im Voraus besten Dank für einen Hilfehinweis.
Viele Grüße
Jens
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20231031/12577f54/attachment.htm>
More information about the Mapbender_users mailing list
