[Mapbender-users] Fwd: Installation issues + Uncaught PHP Exception Twig\Error\RuntimeError (code 0)
Astrid Emde (WhereGroup) astrid.emde at wheregroup.com
Fri May 17 03:57:50 PDT 2024
Hello Norbert,
as Connor mentioned you should try the app_dev.php developer modus? It
will give you extra information.
http://localhost/mapbender/app_dev.php
You can also check on the console whether everything is fine
cd mapbender
app/console mapbender:config:check
Best regards Astrid
Am 2024-05-17 12:01, schrieb Härtel:
> Hi Norbert,
> which version of symfony are you using? The error of the session
> failing to start seems to occur in the class
> “vendor/symfony/symfony/src/Symfony/Component/HttpFoundation/Session/Storage/NativeSessionStorage.php”
> (line 193), I suspect during the call to the start() function, which
> eventually calls the php function “session_start()”.
> You can check the source code on your system yourself for the real
> cause, though.
> It is possible, that the error is caused by missing write permissions
> on the directory or sub-directories of app/cache/ or var/cache/,
> depending on your Symfony version.
> You can also try to call the app_dev.php instead of app.php, maybe the
> logs for dev environment give you another indication of what is
> causing the error.
> Best regards,
> Connor
> Von: Mapbender_users <mapbender_users-bounces at lists.osgeo.org> Im
> Auftrag von Norbert Farago via Mapbender_users
> Gesendet: Donnerstag, 16. Mai 2024 10:23
> An: mapbender_users at lists.osgeo.org
> Cc: Norbert Farago <norbert.farago at gmail.com>
> Betreff: [Mapbender-users] Fwd: Installation issues + Uncaught PHP
> Dear Mapbender Team,
> last week I asked for a little help on the mail list, but
> unfortunately, I didn't get a response until now. Since then, together
> with the administrators, we solved the .htaccess and Apache problems,
> but the ones with code 0 remained. I copied here the error lines from
> prod.log, I am sure it will provide some extra hint for you
> (definitely it did not for me).
> [2024-05-15 23:12:52] request.INFO: Matched route "mapbender_start".
> {"route":"mapbender_start","route_parameters":{"_route":"mapbender_start","_controller":"Mapbender\\CoreBundle\\Controller\\WelcomeController::listAction"},"request_uri":"https://(...)/","method":"GET"}
> [2024-05-15 23:12:52] security.INFO: Populated the TokenStorage with
> an anonymous Token. [] []
> [2024-05-15 23:12:54] request.CRITICAL: Uncaught PHP Exception
> Twig\Error\RuntimeError: "An exception has been thrown during the
> rendering of a template ("Failed to start the session.")." at
> /afs/(...)/mapbender/mapbender/src/Mapbender/ManagerBundle/Resources/views/manager.html.twig
> line 19 {"exception":"[object] (Twig\\Error\\RuntimeError(code: 0): An
> exception has been thrown during the rendering of a template (\"Failed
> to start the session.\"). at
> /afs/(...)/mapbender/mapbender/src/Mapbender/ManagerBundle/Resources/views/manager.html.twig:19,
> RuntimeException(code: 0): Failed to start the session. at
> /afs/(...)/mapbender/vendor/symfony/symfony/src/Symfony/Component/HttpFoundation/Session/Storage/NativeSessionStorage.php:193)"}
> [2024-05-15 23:12:55] request.ERROR: Uncaught PHP Exception
> Symfony\Component\HttpKernel\Exception\NotFoundHttpException: "No
> route found for "GET /favicon.ico" (from "https://(...)")" at
> /afs/(...)/mapbender/vendor/symfony/symfony/src/Symfony/Component/HttpKernel/EventListener/RouterListener.php
> line 136 {"exception":"[object]
> (Symfony\\Component\\HttpKernel\\Exception\\NotFoundHttpException(code:
> 0): No route found for \"GET /favicon.ico\" (from \"https://(....)")
> at
> /afs/(...)/mapbender/vendor/symfony/symfony/src/Symfony/Component/HttpKernel/EventListener/RouterListener.php:136,
> Symfony\\Component\\Routing\\Exception\\ResourceNotFoundException(code:
> 0): No routes found for \"/favicon.ico/\". at
> /afs/(...)/mapbender/vendor/symfony/symfony/src/Symfony/Component/Routing/Matcher/Dumper/CompiledUrlMatcherTrait.php:70)"}
> Thank you in advance!
> Best
> Norbert Faragó
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
Aufwind durch Wissen!
Web-Seminare und Online-Schulungen
bei der www.foss-academy.com
   Astrid Emde
   WhereGroup GmbH
   Eifelstraße 7
   53119 Bonn
   Germany
   Tel: +49(0)228 90 90 38 - 22
   Fax: +49(0)228 90 90 38 - 11
   www.wheregroup.com
   Meinen PGP Public-Key können Sie unter pgp.mit.edu herunterladen:
https://keys.openpgp.org/vks/v1/by-fingerprint/01F8152D36FC07C25EADDE86C5084ACC1C287CCB
   Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
   Folgen Sie der WhereGroup auf twitter:
   http://twitter.com/WhereGroup_com
   Geschäftsführer:
   Olaf Knopp, Peter Stamm
   Amtsgericht Bonn, HRB 9885
Type: application/pgp-keys
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20240517/8c0a640d/attachment-0001.key>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20240517/8c0a640d/attachment-0001.sig>
More information about the Mapbender_users mailing list
