[mapguide-commits] r1094 - in trunk/MgDev:
Common/PlatformBase/Services Server/src/Common/Manager
Server/src/Services/Feature Server/src/Services/Resource
svn_mapguide at osgeo.org
Mon Feb 5 23:15:25 EST 2007
Author: tonyfang
Date: 2007-02-05 23:15:24 -0500 (Mon, 05 Feb 2007)
New Revision: 1094
trunk/MgDev/Common/PlatformBase/Services/ResourceDefs.cpp
trunk/MgDev/Common/PlatformBase/Services/ResourceDefs.h
trunk/MgDev/Server/src/Common/Manager/UnmanagedDataManager.cpp
trunk/MgDev/Server/src/Common/Manager/UnmanagedDataManager.h
trunk/MgDev/Server/src/Services/Feature/ServerGetSchemaMapping.cpp
trunk/MgDev/Server/src/Services/Resource/ApplicationRepositoryManager.cpp
trunk/MgDev/Server/src/Services/Resource/TagManager.cpp
trunk/MgDev/Server/src/Services/Resource/TagManager.h
MapGuide RFC 12 - Unmanaged Data API Changes
- substitute unmanaged data mappings in GetSchemaMapping API
- move SubstituteMappingTag from TagManager to UnmanagedDataManager (so it can be re-used by GetSchemaMapping)
Modified: trunk/MgDev/Common/PlatformBase/Services/ResourceDefs.cpp
--- trunk/MgDev/Common/PlatformBase/Services/ResourceDefs.cpp 2007-02-05 21:44:33 UTC (rev 1093)
+++ trunk/MgDev/Common/PlatformBase/Services/ResourceDefs.cpp 2007-02-06 04:15:24 UTC (rev 1094)
@@ -63,8 +63,6 @@
const STRING MgResourceTag::Username = L"%MG_USERNAME%";
const STRING MgResourceTag::Password = L"%MG_PASSWORD%";
const STRING MgResourceTag::DataFilePath = L"%MG_DATA_FILE_PATH%";
-const STRING MgResourceTag::MappingBegin = L"%MG_[";
-const STRING MgResourceTag::MappingEnd = L"]%";
Modified: trunk/MgDev/Common/PlatformBase/Services/ResourceDefs.h
--- trunk/MgDev/Common/PlatformBase/Services/ResourceDefs.h 2007-02-05 21:44:33 UTC (rev 1093)
+++ trunk/MgDev/Common/PlatformBase/Services/ResourceDefs.h 2007-02-06 04:15:24 UTC (rev 1094)
@@ -270,20 +270,6 @@
/// given resource. The trailing "/" is included.
static const STRING DataFilePath; ///\if INTERNAL value("%MG_DATA_FILE_PATH%") \endif
- /// \brief
- /// This tag signifies beginning of unmanaged data mapping name.
- static const STRING MappingBegin; ///\if INTERNAL value("%MG_[") \endif
- /// \brief
- /// This tag signifies end of unmanaged data mapping name.
- static const STRING MappingEnd; ///\if INTERNAL value("]%") \endif
Modified: trunk/MgDev/Server/src/Common/Manager/UnmanagedDataManager.cpp
--- trunk/MgDev/Server/src/Common/Manager/UnmanagedDataManager.cpp 2007-02-05 21:44:33 UTC (rev 1093)
+++ trunk/MgDev/Server/src/Common/Manager/UnmanagedDataManager.cpp 2007-02-06 04:15:24 UTC (rev 1094)
@@ -24,15 +24,16 @@
// Process-wide MgUnmanagedDataManager
Ptr<MgUnmanagedDataManager> MgUnmanagedDataManager::sm_unmanagedDataManager = (MgUnmanagedDataManager*)NULL;
-//Ptr<MgPropertyCollection> MgUnmanagedDataManager::m_unmanagedDataMappings = (MgPropertyCollection*)NULL;
const STRING MgUnmanagedDataManager::Folders = L"FOLDERS";
const STRING MgUnmanagedDataManager::Files = L"FILES";
const STRING MgUnmanagedDataManager::Both = L"BOTH";
const STRING MgUnmanagedDataManager::OpenSquareBracket = L"[";
const STRING MgUnmanagedDataManager::ClosedSquareBracket = L"]";
+const string MgUnmanagedDataManager::MappingBegin = "%MG_[";
+const string MgUnmanagedDataManager::MappingEnd = "]%";
/// \brief
/// Constructs the object.
@@ -395,6 +396,65 @@
/// \brief
+/// Substitutes unmanaged data mappings
+int MgUnmanagedDataManager::SubstituteMappingTag(REFSTRING doc)
+ string temp = MgUtil::WideCharToMultiByte(doc);
+ int result = SubstituteMappingTag(temp);
+ doc = MgUtil::MultiByteToWideChar(temp);
+ return result;
+/// \brief
+int MgUnmanagedDataManager::SubstituteMappingTag(string& doc)
+ int count = 0;
+ size_t startPos, endPos;
+ size_t len1 = MgUnmanagedDataManager::MappingBegin.length();
+ size_t len2 = MgUnmanagedDataManager::MappingEnd.length();
+ while (string::npos != (startPos = doc.find(MgUnmanagedDataManager::MappingBegin)))
+ // beginTag found, now look for endTag
+ while (string::npos != (endPos = doc.find(MgUnmanagedDataManager::MappingEnd)))
+ // extract out the mapping name
+ string mappingName = doc.substr(startPos + len1, endPos - startPos - len1);
+ size_t nameLen = mappingName.length();
+ // find the mapping name in the map, and then replace it
+ MgPropertyCollection* mappings = MgUnmanagedDataManager::GetInstance()->GetUnmanagedDataMappings();
+ if (mappings != NULL)
+ Ptr<MgStringProperty> stringProp = dynamic_cast<MgStringProperty*>(mappings->FindItem(MgUtil::MultiByteToWideChar(mappingName)));
+ if (stringProp != NULL)
+ STRING mappingDir = stringProp->GetValue();
+ // replace the mappingName with the actual directory
+ if (!MgFileUtil::EndsWithSlash(mappingDir))
+ MgFileUtil::AppendSlashToEndOfPath(mappingDir);
+ size_t dirLen = mappingDir.length();
+ doc.replace(startPos, len1 + nameLen + len2, MgUtil::WideCharToMultiByte(mappingDir), 0, dirLen);
+ ++count;
+ break;
+ return count;
+/// \brief
/// Returns unmanaged data
MgByteReader* MgUnmanagedDataManager::EnumerateUnmanagedData(CREFSTRING path, bool recursive, CREFSTRING select, CREFSTRING filter)
Modified: trunk/MgDev/Server/src/Common/Manager/UnmanagedDataManager.h
--- trunk/MgDev/Server/src/Common/Manager/UnmanagedDataManager.h 2007-02-05 21:44:33 UTC (rev 1093)
+++ trunk/MgDev/Server/src/Common/Manager/UnmanagedDataManager.h 2007-02-06 04:15:24 UTC (rev 1094)
@@ -56,7 +56,8 @@
static MgUnmanagedDataManager* GetInstance();
MgPropertyCollection* GetUnmanagedDataMappings();
-// static void ConvertUnmanagedDataMappingName(REFSTRING path); // TODO: remove
+ static int SubstituteMappingTag(REFSTRING data);
+ static int SubstituteMappingTag(string& data);
void Initialize();
virtual void Dispose();
@@ -76,6 +77,9 @@
static const STRING OpenSquareBracket;
static const STRING ClosedSquareBracket;
+ static const string MappingBegin;
+ static const string MappingEnd;
#endif
Modified: trunk/MgDev/Server/src/Services/Feature/ServerGetSchemaMapping.cpp
--- trunk/MgDev/Server/src/Services/Feature/ServerGetSchemaMapping.cpp 2007-02-05 21:44:33 UTC (rev 1093)
+++ trunk/MgDev/Server/src/Services/Feature/ServerGetSchemaMapping.cpp 2007-02-06 04:15:24 UTC (rev 1094)
@@ -17,6 +17,7 @@
#include "ServerFeatureServiceDefs.h"
#include "ServerGetSchemaMapping.h"
+#include "UnmanagedDataManager.h"
MgServerGetSchemaMapping::MgServerGetSchemaMapping() :
m_bytes(NULL)
@@ -39,7 +40,10 @@
// Connect to the provider
FdoPtr<FdoIConnection> fdoConnection;
- MgServerFeatureConnection msfc(providerName, partialConnString);
+ STRING data = partialConnString;
+ MgUnmanagedDataManager::SubstituteMappingTag(data);
+ MgServerFeatureConnection msfc(providerName, data);
if (( msfc.IsConnectionOpen() ) || ( msfc.IsConnectionPending() ))
fdoConnection = msfc.GetConnection();
Modified: trunk/MgDev/Server/src/Services/Resource/ApplicationRepositoryManager.cpp
--- trunk/MgDev/Server/src/Services/Resource/ApplicationRepositoryManager.cpp 2007-02-05 21:44:33 UTC (rev 1093)
+++ trunk/MgDev/Server/src/Services/Resource/ApplicationRepositoryManager.cpp 2007-02-06 04:15:24 UTC (rev 1094)
@@ -360,11 +360,9 @@
dataBindingInfo.SetLoginUsername(m_currUserInfo->GetUserName());
dataBindingInfo.SetLoginPassword(m_currUserInfo->GetPassword());
- if (resource->IsResourceTypeOf(MgResourceType::FeatureSource))
- // turn on substitute unmanaged data mappings
- dataBindingInfo.SetSubstituteUnmanagedDataMappings(true);
+ // turn on substitute unmanaged data mappings
+ dataBindingInfo.SetSubstituteUnmanagedDataMappings(
+ resource->IsResourceTypeOf(MgResourceType::FeatureSource));
byteReader = resourceContentMan->GetResource(resource,
&dataBindingInfo);
Modified: trunk/MgDev/Server/src/Services/Resource/TagManager.cpp
--- trunk/MgDev/Server/src/Services/Resource/TagManager.cpp 2007-02-05 21:44:33 UTC (rev 1093)
+++ trunk/MgDev/Server/src/Services/Resource/TagManager.cpp 2007-02-06 04:15:24 UTC (rev 1094)
@@ -323,10 +323,7 @@
if (dataBindingInfo.GetSubstituteUnmanagedDataMappings())
- count += SubstituteMappingTag(
- MgUtil::WideCharToMultiByte(MgResourceTag::MappingBegin),
- MgUtil::WideCharToMultiByte(MgResourceTag::MappingEnd),
- doc);
+ count += MgUnmanagedDataManager::SubstituteMappingTag(doc);
CheckTagStrings(doc);
@@ -368,53 +365,6 @@
return SubstituteTag(tagName, tagValue, doc);
-/// \brief
-/// Substitutes the mapping tag.
-int MgTagManager::SubstituteMappingTag(const string& beginTag, const string& endTag, string& doc)
- int count = 0;
- size_t startPos, endPos;
- size_t len1 = beginTag.length();
- size_t len2 = endTag.length();
- while (string::npos != (startPos = doc.find(beginTag)))
- // beginTag found, now look for endTag
- while (string::npos != (endPos = doc.find(endTag)))
- // extract out the mapping name
- string mappingName = doc.substr(startPos + len1, endPos - startPos - len1);
- size_t nameLen = mappingName.length();
- // find the mapping name in the map, and then replace it
- MgPropertyCollection* mappings = MgUnmanagedDataManager::GetInstance()->GetUnmanagedDataMappings();
- if (mappings != NULL)
- Ptr<MgStringProperty> stringProp = dynamic_cast<MgStringProperty*>(mappings->FindItem(MgUtil::MultiByteToWideChar(mappingName)));
- if (stringProp != NULL)
- STRING mappingDir = stringProp->GetValue();
- // replace the mappingName with the actual directory
- if (!MgFileUtil::EndsWithSlash(mappingDir))
- MgFileUtil::AppendSlashToEndOfPath(mappingDir);
- size_t dirLen = mappingDir.length();
- doc.replace(startPos, len1 + nameLen + len2, MgUtil::WideCharToMultiByte(mappingDir), 0, dirLen);
- ++count;
- break;
- return count;
/// <summary>
/// Gets the specified tag.
Modified: trunk/MgDev/Server/src/Services/Resource/TagManager.h
--- trunk/MgDev/Server/src/Services/Resource/TagManager.h 2007-02-05 21:44:33 UTC (rev 1093)
+++ trunk/MgDev/Server/src/Services/Resource/TagManager.h 2007-02-06 04:15:24 UTC (rev 1094)
@@ -58,7 +58,6 @@
int SubstituteTag(const string& name, const string& value, string& doc);
int SubstituteTag(CREFSTRING name, CREFSTRING value, string& doc);
- int SubstituteMappingTag(const string& beginMapping, const string& endMapping, string& doc);
void AddTag(CREFSTRING name, const MgTagInfo& tagInfo);
private:
More information about the mapguide-commits
