[mapguide-commits] r1107 - in trunk/MgDev/Common: Foundation/Data
Foundation/System Geometry/Buffer MapGuideCommon/Controller
MapGuideCommon/Services PlatformBase/MapLayer PlatformBase/Services
svn_mapguide at osgeo.org
Mon Feb 12 19:17:47 EST 2007
Author: philipsharman
Date: 2007-02-12 19:17:46 -0500 (Mon, 12 Feb 2007)
New Revision: 1107
trunk/MgDev/Common/Foundation/Data/ByteReader.h
trunk/MgDev/Common/Foundation/System/ByteSourceFileImpl.h
trunk/MgDev/Common/Foundation/System/ByteSourceImpl.h
trunk/MgDev/Common/Foundation/System/ByteSourceMemoryImpl.h
trunk/MgDev/Common/Foundation/System/ByteSourceSocketStreamImpl.h
trunk/MgDev/Common/Foundation/System/ByteSourceStreamImpl.h
trunk/MgDev/Common/Foundation/System/ClassFactory.h
trunk/MgDev/Common/Foundation/System/FoundationConfigProperties.h
trunk/MgDev/Common/Foundation/System/ServerConnectionBase.h
trunk/MgDev/Common/Foundation/System/StreamReader.h
trunk/MgDev/Common/Geometry/Buffer/bufrsort.h
trunk/MgDev/Common/Geometry/Buffer/oarray.h
trunk/MgDev/Common/MapGuideCommon/Controller/HtmlController.h
trunk/MgDev/Common/MapGuideCommon/Services/DrawingDefs.h
trunk/MgDev/Common/MapGuideCommon/Services/KmlDefs.h
trunk/MgDev/Common/MapGuideCommon/Services/PrintLayout.h
trunk/MgDev/Common/MapGuideCommon/Services/RenderingDefs.h
trunk/MgDev/Common/MapGuideCommon/Services/ServerAdminDefs.h
trunk/MgDev/Common/MapGuideCommon/Services/ServerConnection.h
trunk/MgDev/Common/MapGuideCommon/Services/ServerConnectionImp.h
trunk/MgDev/Common/MapGuideCommon/Services/ServerConnectionStack.h
trunk/MgDev/Common/MapGuideCommon/Services/SiteConnection.h
trunk/MgDev/Common/MapGuideCommon/Services/TileDefs.h
trunk/MgDev/Common/PlatformBase/MapLayer/LayerBase.h
trunk/MgDev/Common/PlatformBase/MapLayer/LayerGroup.h
trunk/MgDev/Common/PlatformBase/MapLayer/MapBase.h
trunk/MgDev/Common/PlatformBase/Services/BaseServiceDefs.h
trunk/MgDev/Common/PlatformBase/Services/GwsFeatureReader.h
trunk/MgDev/Common/PlatformBase/Services/InsertFeatures.h
trunk/MgDev/Common/PlatformBase/Services/LockFeatures.h
trunk/MgDev/Common/PlatformBase/Services/LongTransactionReader.h
trunk/MgDev/Common/PlatformBase/Services/Reader.h
trunk/MgDev/Common/PlatformBase/Services/ResourceDefs.h
trunk/MgDev/Common/PlatformBase/Services/ResourceService.h
trunk/MgDev/Common/PlatformBase/Services/ServiceRegistry.h
trunk/MgDev/Common/PlatformBase/Services/SpatialContextReader.h
trunk/MgDev/Common/PlatformBase/Services/UnlockFeatures.h
trunk/MgDev/Common/PlatformBase/Services/UpdateFeatures.h
Fixed Doxygen commands in the comments. These commands
are used to generate the API Reference.
Modified: trunk/MgDev/Common/Foundation/Data/ByteReader.h
--- trunk/MgDev/Common/Foundation/Data/ByteReader.h 2007-02-12 21:17:49 UTC (rev 1106)
+++ trunk/MgDev/Common/Foundation/Data/ByteReader.h 2007-02-13 00:17:46 UTC (rev 1107)
@@ -123,7 +123,7 @@
/// MgByteReader(string content, string mimeType);
/// \htmlinclude SyntaxBottom.html
- /// \param content (string/String/string)
+ /// \param contents (string/String/string)
/// String contents for byte reader.
/// \param mimeType (string/String/string)
@@ -149,7 +149,7 @@
- /// \param content (Byte[]/byte[]/string)
+ /// \param contents (Byte[]/byte[]/string)
/// Binary contents for byte reader.
/// \param length (int/int/int)
Modified: trunk/MgDev/Common/Foundation/System/ByteSourceFileImpl.h
--- trunk/MgDev/Common/Foundation/System/ByteSourceFileImpl.h 2007-02-12 21:17:49 UTC (rev 1106)
+++ trunk/MgDev/Common/Foundation/System/ByteSourceFileImpl.h 2007-02-13 00:17:46 UTC (rev 1107)
@@ -114,7 +114,7 @@
INT64 m_size;
bool m_temporary;
-/// \endcond INTERNAL
+/// \endcond
/// Inline Methods
@@ -123,6 +123,6 @@
return m_temporary;
+/// \endcond
#endif // MG_BYTE_SOURCE_FILE_IMPL_H_
Modified: trunk/MgDev/Common/Foundation/System/ByteSourceImpl.h
--- trunk/MgDev/Common/Foundation/System/ByteSourceImpl.h 2007-02-12 21:17:49 UTC (rev 1106)
+++ trunk/MgDev/Common/Foundation/System/ByteSourceImpl.h 2007-02-13 00:17:46 UTC (rev 1107)
@@ -84,6 +84,6 @@
virtual void Rewind() = 0;
+/// \endcond
#endif // MG_BYTE_SOURCE_IMPL_H_
Modified: trunk/MgDev/Common/Foundation/System/ByteSourceMemoryImpl.h
--- trunk/MgDev/Common/Foundation/System/ByteSourceMemoryImpl.h 2007-02-12 21:17:49 UTC (rev 1106)
+++ trunk/MgDev/Common/Foundation/System/ByteSourceMemoryImpl.h 2007-02-13 00:17:46 UTC (rev 1107)
@@ -116,6 +116,6 @@
Ptr<MgByte> m_data;
INT32 m_pos;
+/// \endcond
#endif // MG_BYTE_SOURCE_MEMORY_IMPL_H_
Modified: trunk/MgDev/Common/Foundation/System/ByteSourceSocketStreamImpl.h
--- trunk/MgDev/Common/Foundation/System/ByteSourceSocketStreamImpl.h 2007-02-12 21:17:49 UTC (rev 1106)
+++ trunk/MgDev/Common/Foundation/System/ByteSourceSocketStreamImpl.h 2007-02-13 00:17:46 UTC (rev 1107)
@@ -100,6 +100,6 @@
INT32 m_blockRead;
+/// \endcond
#endif // MG_BYTE_SOURCE_SOCKET_STREAM_IMPL_H_
Modified: trunk/MgDev/Common/Foundation/System/ByteSourceStreamImpl.h
--- trunk/MgDev/Common/Foundation/System/ByteSourceStreamImpl.h 2007-02-12 21:17:49 UTC (rev 1106)
+++ trunk/MgDev/Common/Foundation/System/ByteSourceStreamImpl.h 2007-02-13 00:17:46 UTC (rev 1107)
@@ -96,6 +96,6 @@
protected:
MgStream* m_stream;
+/// \endcond
#endif
Modified: trunk/MgDev/Common/Foundation/System/ClassFactory.h
--- trunk/MgDev/Common/Foundation/System/ClassFactory.h 2007-02-12 21:17:49 UTC (rev 1106)
+++ trunk/MgDev/Common/Foundation/System/ClassFactory.h 2007-02-13 00:17:46 UTC (rev 1107)
@@ -20,14 +20,14 @@
#include <map>
-/// \cond INTERNAL
/// Typedef for class creation functions
typedef MgObject* (*ClassCreatorFunc)();
+/// \cond INTERNAL
/// INTERNAL_CLASS
-/// \cond INTERNAL
/// \brief
/// Class registration for Foundation derived applications
class MG_FOUNDATION_API MgClassFactory : public MgDisposable
@@ -82,5 +82,6 @@
std::map<int, ClassCreatorFunc> m_classCreators;
+/// \endcond
#endif
Modified: trunk/MgDev/Common/Foundation/System/FoundationConfigProperties.h
--- trunk/MgDev/Common/Foundation/System/FoundationConfigProperties.h 2007-02-12 21:17:49 UTC (rev 1106)
+++ trunk/MgDev/Common/Foundation/System/FoundationConfigProperties.h 2007-02-13 00:17:46 UTC (rev 1107)
@@ -67,6 +67,6 @@
// Common Configuration Validation Information Maps
static const MgConfigValidationInfo sm_cviGeneralProperties[];
+/// \endcond
#endif
Modified: trunk/MgDev/Common/Foundation/System/ServerConnectionBase.h
--- trunk/MgDev/Common/Foundation/System/ServerConnectionBase.h 2007-02-12 21:17:49 UTC (rev 1106)
+++ trunk/MgDev/Common/Foundation/System/ServerConnectionBase.h 2007-02-13 00:17:46 UTC (rev 1107)
@@ -44,5 +44,6 @@
virtual ~MgServerConnectionBase();
+/// \endcond
#endif
Modified: trunk/MgDev/Common/Foundation/System/StreamReader.h
--- trunk/MgDev/Common/Foundation/System/StreamReader.h 2007-02-12 21:17:49 UTC (rev 1106)
+++ trunk/MgDev/Common/Foundation/System/StreamReader.h 2007-02-13 00:17:46 UTC (rev 1107)
@@ -250,5 +250,7 @@
Ptr<MgStreamHelper> m_sHelper;
MgServerConnectionBase* m_conn; // raw pointer to avoid circular dependency
+/// \endcond
#endif // _MGSTREAMREADER_H_
Modified: trunk/MgDev/Common/Geometry/Buffer/bufrsort.h
--- trunk/MgDev/Common/Geometry/Buffer/bufrsort.h 2007-02-12 21:17:49 UTC (rev 1106)
+++ trunk/MgDev/Common/Geometry/Buffer/bufrsort.h 2007-02-13 00:17:46 UTC (rev 1107)
@@ -16,7 +16,6 @@
/// \cond INTERNAL
-/// \ingroup Geometry_Module
@@ -342,6 +341,6 @@
} // end: GetNProgressSubIntervals()
+/// \endcond
#endif
Modified: trunk/MgDev/Common/Geometry/Buffer/oarray.h
--- trunk/MgDev/Common/Geometry/Buffer/oarray.h 2007-02-12 21:17:49 UTC (rev 1106)
+++ trunk/MgDev/Common/Geometry/Buffer/oarray.h 2007-02-13 00:17:46 UTC (rev 1107)
@@ -16,7 +16,6 @@
/// \cond INTERNAL
@@ -303,4 +302,4 @@
#endif
+/// \endcond
Modified: trunk/MgDev/Common/MapGuideCommon/Controller/HtmlController.h
--- trunk/MgDev/Common/MapGuideCommon/Controller/HtmlController.h 2007-02-12 21:17:49 UTC (rev 1106)
+++ trunk/MgDev/Common/MapGuideCommon/Controller/HtmlController.h 2007-02-13 00:17:46 UTC (rev 1107)
@@ -239,6 +239,6 @@
+/// \endcond
#endif
Modified: trunk/MgDev/Common/MapGuideCommon/Services/DrawingDefs.h
--- trunk/MgDev/Common/MapGuideCommon/Services/DrawingDefs.h 2007-02-12 21:17:49 UTC (rev 1106)
+++ trunk/MgDev/Common/MapGuideCommon/Services/DrawingDefs.h 2007-02-13 00:17:46 UTC (rev 1107)
@@ -37,6 +37,6 @@
static const int EnumerateSectionResources = 0x1111EC08;
static const int GetCoordinateSpace = 0x1111EC09;
+/// \endcond
#endif
Modified: trunk/MgDev/Common/MapGuideCommon/Services/KmlDefs.h
--- trunk/MgDev/Common/MapGuideCommon/Services/KmlDefs.h 2007-02-12 21:17:49 UTC (rev 1106)
+++ trunk/MgDev/Common/MapGuideCommon/Services/KmlDefs.h 2007-02-13 00:17:46 UTC (rev 1107)
@@ -32,6 +32,6 @@
static const int GetLayerKml = 0x1111E702;
static const int GetFeaturesKml = 0x1111E703;
+/// \endcond
#endif
Modified: trunk/MgDev/Common/MapGuideCommon/Services/PrintLayout.h
--- trunk/MgDev/Common/MapGuideCommon/Services/PrintLayout.h 2007-02-12 21:17:49 UTC (rev 1106)
+++ trunk/MgDev/Common/MapGuideCommon/Services/PrintLayout.h 2007-02-13 00:17:46 UTC (rev 1107)
@@ -297,6 +297,8 @@
void GetLayoutPropertiesFromXml(MgXmlUtil* pXmlUtil);
+/// \endcond
#endif // MG_PRINT_LAYOUT_H
Modified: trunk/MgDev/Common/MapGuideCommon/Services/RenderingDefs.h
--- trunk/MgDev/Common/MapGuideCommon/Services/RenderingDefs.h 2007-02-12 21:17:49 UTC (rev 1106)
+++ trunk/MgDev/Common/MapGuideCommon/Services/RenderingDefs.h 2007-02-13 00:17:46 UTC (rev 1107)
@@ -37,6 +37,6 @@
static const int RenderDynamicOverlay = 0x1111E909;
static const int QueryFeatureProperties = 0x1111E90A;
+/// \endcond
#endif
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ServerAdminDefs.h
--- trunk/MgDev/Common/MapGuideCommon/Services/ServerAdminDefs.h 2007-02-12 21:17:49 UTC (rev 1106)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ServerAdminDefs.h 2007-02-13 00:17:46 UTC (rev 1107)
@@ -215,6 +215,6 @@
public: \
static MgObject* CreateObject();
+/// \endcond
#endif // MG_SERVER_ADMIN_DEFS_H
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ServerConnection.h
--- trunk/MgDev/Common/MapGuideCommon/Services/ServerConnection.h 2007-02-12 21:17:49 UTC (rev 1106)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ServerConnection.h 2007-02-13 00:17:46 UTC (rev 1107)
@@ -200,7 +200,8 @@
MgServerConnectionImp* m_serverConnImp;
+/// \endcond
#endif
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ServerConnectionImp.h
--- trunk/MgDev/Common/MapGuideCommon/Services/ServerConnectionImp.h 2007-02-12 21:17:49 UTC (rev 1106)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ServerConnectionImp.h 2007-02-13 00:17:46 UTC (rev 1107)
@@ -74,7 +74,7 @@
private:
ACE_SOCK_Stream* mServer;
+/// \endcond
#endif
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ServerConnectionStack.h
--- trunk/MgDev/Common/MapGuideCommon/Services/ServerConnectionStack.h 2007-02-12 21:17:49 UTC (rev 1106)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ServerConnectionStack.h 2007-02-13 00:17:46 UTC (rev 1107)
@@ -86,6 +86,6 @@
ConnectionQueue* m_queue;
ConnectionList* m_inUse;
+/// \endcond
#endif
Modified: trunk/MgDev/Common/MapGuideCommon/Services/SiteConnection.h
--- trunk/MgDev/Common/MapGuideCommon/Services/SiteConnection.h 2007-02-12 21:17:49 UTC (rev 1106)
+++ trunk/MgDev/Common/MapGuideCommon/Services/SiteConnection.h 2007-02-13 00:17:46 UTC (rev 1107)
@@ -108,7 +108,7 @@
/// Open should authenticate with MgSiteConnection::Authenticate which in turn uses the appropriate
/// helper class. A connection to the Site Server, if necessary, should be created
/// and maintained.
- /// \endcond INTERNAL
+ /// \endcond
void Open(MgUserInformation* userInformation);
@@ -144,7 +144,7 @@
/// \cond INTERNAL
/// INTERNAL:
/// GetService relies on the implementation of the bound MgSiteHelper class
+ /// \endcond
MgService* CreateService(INT32 serviceType);
@@ -186,7 +186,7 @@
/// \cond INTERNAL
/// INTERNAL:
/// Since the URL is specified, this method binds to an MgHttpProxySiteHelper.
+ /// \endcond
MgSiteConnection(CREFSTRING url);
@@ -240,7 +240,7 @@
/// \cond INTERNAL
/// Open must be called before this method will work. If we are the Site Server
/// then no connection will be returned.
+ /// \endcond
MgServerConnection* GetSiteConnection();
Modified: trunk/MgDev/Common/MapGuideCommon/Services/TileDefs.h
--- trunk/MgDev/Common/MapGuideCommon/Services/TileDefs.h 2007-02-12 21:17:49 UTC (rev 1106)
+++ trunk/MgDev/Common/MapGuideCommon/Services/TileDefs.h 2007-02-13 00:17:46 UTC (rev 1107)
@@ -31,7 +31,7 @@
static const int SetTile = 0x1111E802;
static const int ClearCache = 0x1111E803;
+/// \endcond
/// \cond INTERNAL
@@ -48,6 +48,6 @@
static const INT32 tileDPI; // assumed DPI for all tiles
static const STRING tileFormat; // image format for all tiles
+/// \endcond
#endif
Modified: trunk/MgDev/Common/PlatformBase/MapLayer/LayerBase.h
--- trunk/MgDev/Common/PlatformBase/MapLayer/LayerBase.h 2007-02-12 21:17:49 UTC (rev 1106)
+++ trunk/MgDev/Common/PlatformBase/MapLayer/LayerBase.h 2007-02-13 00:17:46 UTC (rev 1107)
@@ -96,7 +96,7 @@
/// <!-- Example (PHP) -->
/// \htmlinclude PHPExampleTop.html
- /// See \link MgMap MgMap Class \endlink.
+ /// See \link MgMapBase MgMapBase class \endlink.
/// \htmlinclude ExampleBottom.html
virtual STRING GetName(); /// __get, __set
@@ -145,7 +145,7 @@
virtual STRING GetObjectId();
@@ -191,7 +191,7 @@
/// \todo
@@ -247,7 +247,7 @@
virtual bool NeedsRefresh();
@@ -301,7 +301,7 @@
virtual bool GetVisible(); /// __get, __set
@@ -367,7 +367,7 @@
virtual bool IsVisible();
@@ -393,7 +393,7 @@
/// \todo
@@ -445,7 +445,7 @@
virtual MgResourceIdentifier* GetLayerDefinition(); /// __get
@@ -517,7 +517,7 @@
virtual bool GetDisplayInLegend(); /// __get, __set
@@ -569,7 +569,7 @@
virtual bool GetExpandInLegend(); /// __get
@@ -594,7 +594,7 @@
virtual STRING GetLegendLabel(); /// __get, __set
Modified: trunk/MgDev/Common/PlatformBase/MapLayer/LayerGroup.h
--- trunk/MgDev/Common/PlatformBase/MapLayer/LayerGroup.h 2007-02-12 21:17:49 UTC (rev 1106)
+++ trunk/MgDev/Common/PlatformBase/MapLayer/LayerGroup.h 2007-02-13 00:17:46 UTC (rev 1107)
@@ -83,7 +83,7 @@
@@ -108,7 +108,7 @@
/// \todo
@@ -158,7 +158,7 @@
virtual MgLayerGroup* GetGroup(); /// __get, __set
@@ -213,7 +213,7 @@
@@ -274,7 +274,7 @@
@@ -301,7 +301,7 @@
@@ -353,7 +353,7 @@
@@ -378,7 +378,7 @@
Modified: trunk/MgDev/Common/PlatformBase/MapLayer/MapBase.h
--- trunk/MgDev/Common/PlatformBase/MapLayer/MapBase.h 2007-02-12 21:17:49 UTC (rev 1106)
+++ trunk/MgDev/Common/PlatformBase/MapLayer/MapBase.h 2007-02-13 00:17:46 UTC (rev 1107)
@@ -278,11 +278,6 @@
/// \return
/// Returns the name of the map as a string.
- /// <!-- Example (PHP) -->
- /// \htmlinclude PHPExampleTop.html
- /// \htmlinclude ExampleBottom.html
@@ -303,11 +298,6 @@
/// \return
/// Returns the session id of the map as a string.
STRING GetSessionId(); /// __get
@@ -329,11 +319,6 @@
/// \return
/// Returns the unique identifier of this map as a string.
@@ -356,11 +341,6 @@
/// Returns an MgResourceIdentifier that specifies the location
/// of the map definition.
virtual MgResourceIdentifier* GetMapDefinition(); /// __get
@@ -382,11 +362,6 @@
/// Returns the spatial reference system in the OpenGIS \link WKT WKT \endlink
/// (Well Known Text) format as a string.
virtual STRING GetMapSRS(); /// __get
@@ -408,11 +383,6 @@
/// Returns an MgEnvelope that defines the overall extent of the
/// map.
virtual MgEnvelope* GetMapExtent(); /// __get
@@ -433,11 +403,6 @@
/// \return
/// Returns an MgLayerCollection that contains the map layers.
virtual MgLayerCollection* GetLayers();
@@ -459,11 +424,6 @@
/// Returns an MgLayerGroupCollection that contains the map
/// layer groups.
virtual MgLayerGroupCollection* GetLayerGroups();
@@ -596,11 +556,6 @@
/// \return
/// Returns an MgPoint that specifies the center of the map.
virtual MgPoint* GetViewCenter(); /// __get
@@ -621,11 +576,6 @@
/// \return
/// Returns a double that specifies the scale of the map.
virtual double GetViewScale(); /// __get
@@ -647,11 +597,6 @@
/// \return
/// Returns an MgEnvelope that defines the current data extent.
virtual MgEnvelope* GetDataExtent(); /// __get
@@ -672,11 +617,6 @@
/// \return
/// Returns the number of dots per inch of the map display.
virtual INT32 GetDisplayDpi(); /// __get
@@ -701,11 +641,6 @@
/// \return
/// Returns the width of the map display in pixels.
virtual INT32 GetDisplayWidth(); /// __get
@@ -731,11 +666,6 @@
/// \return
/// Returns the height of the map display in pixels.
virtual INT32 GetDisplayHeight(); /// __get
@@ -756,11 +686,6 @@
/// \return
/// Returns the number of finite display scales in the map.
virtual INT32 GetFiniteDisplayScaleCount(); /// __get
@@ -784,11 +709,6 @@
/// \return
/// Returns the finite display scale.
/// \exception MgOutOfRangeException if the index is invalid.
virtual double GetFiniteDisplayScaleAt(INT32 index);
Modified: trunk/MgDev/Common/PlatformBase/Services/BaseServiceDefs.h
--- trunk/MgDev/Common/PlatformBase/Services/BaseServiceDefs.h 2007-02-12 21:17:49 UTC (rev 1106)
+++ trunk/MgDev/Common/PlatformBase/Services/BaseServiceDefs.h 2007-02-13 00:17:46 UTC (rev 1107)
@@ -18,7 +18,7 @@
#ifndef MGBASESERVICEDEFS_H
#define MGBASESERVICEDEFS_H
-/// \defgroup MgServiceType
+/// \defgroup MgServiceType MgServiceType
/// \ingroup Common_Module
Modified: trunk/MgDev/Common/PlatformBase/Services/GwsFeatureReader.h
--- trunk/MgDev/Common/PlatformBase/Services/GwsFeatureReader.h 2007-02-12 21:17:49 UTC (rev 1106)
+++ trunk/MgDev/Common/PlatformBase/Services/GwsFeatureReader.h 2007-02-13 00:17:46 UTC (rev 1107)
@@ -71,4 +71,6 @@
static const INT32 m_cls_id = PlatformBase_FeatureService_GwsFeatureReader;
+/// \endcond
#endif
Modified: trunk/MgDev/Common/PlatformBase/Services/InsertFeatures.h
--- trunk/MgDev/Common/PlatformBase/Services/InsertFeatures.h 2007-02-12 21:17:49 UTC (rev 1106)
+++ trunk/MgDev/Common/PlatformBase/Services/InsertFeatures.h 2007-02-13 00:17:46 UTC (rev 1107)
@@ -18,7 +18,7 @@
#ifndef _MGINSERTFEATURES_H
#define _MGINSERTFEATURES_H
-/// \defgroup MgInsertFeatures
+/// \defgroup MgInsertFeatures MgInsertFeatures
/// \ingroup Feature_Service_classes
Modified: trunk/MgDev/Common/PlatformBase/Services/LockFeatures.h
--- trunk/MgDev/Common/PlatformBase/Services/LockFeatures.h 2007-02-12 21:17:49 UTC (rev 1106)
+++ trunk/MgDev/Common/PlatformBase/Services/LockFeatures.h 2007-02-13 00:17:46 UTC (rev 1107)
@@ -21,7 +21,7 @@
class MgLockFeatures;
template class MG_PLATFORMBASE_API Ptr<MgLockFeatures>;
-/// \defgroup MgLockFeatures
+/// \defgroup MgLockFeatures MgLockFeatures
Modified: trunk/MgDev/Common/PlatformBase/Services/LongTransactionReader.h
--- trunk/MgDev/Common/PlatformBase/Services/LongTransactionReader.h 2007-02-12 21:17:49 UTC (rev 1106)
+++ trunk/MgDev/Common/PlatformBase/Services/LongTransactionReader.h 2007-02-13 00:17:46 UTC (rev 1107)
@@ -20,7 +20,7 @@
class MgLongTransactionData;
-/// \defgroup MgLongTransactionReader
+/// \defgroup MgLongTransactionReader MgLongTransactionReader
Modified: trunk/MgDev/Common/PlatformBase/Services/Reader.h
--- trunk/MgDev/Common/PlatformBase/Services/Reader.h 2007-02-12 21:17:49 UTC (rev 1106)
+++ trunk/MgDev/Common/PlatformBase/Services/Reader.h 2007-02-13 00:17:46 UTC (rev 1107)
@@ -20,7 +20,7 @@
class MgRaster;
-/// \defgroup MgReader
+/// \defgroup MgReader MgReader
Modified: trunk/MgDev/Common/PlatformBase/Services/ResourceDefs.h
--- trunk/MgDev/Common/PlatformBase/Services/ResourceDefs.h 2007-02-12 21:17:49 UTC (rev 1106)
+++ trunk/MgDev/Common/PlatformBase/Services/ResourceDefs.h 2007-02-13 00:17:46 UTC (rev 1107)
@@ -31,7 +31,7 @@
static const STRING Path; /// Reserved characters in paths = "%*:|\?<&>=".
static const STRING WhiteSpace; /// White space characters = " t r n v f".
+/// \endcond
@@ -404,7 +404,7 @@
static const STRING Groups; /// Groups folder name
static const STRING Roles; /// Roles folder name
+/// \endcond
/// \cond INTERNAL
@@ -420,7 +420,7 @@
static const INT32 Security = 0x00000002;
static const INT32 Metadata = 0x00000004;
+/// \endcond
#define DECLARE_DYNCREATE_RESOURCE() \
public: \
Modified: trunk/MgDev/Common/PlatformBase/Services/ResourceService.h
--- trunk/MgDev/Common/PlatformBase/Services/ResourceService.h 2007-02-12 21:17:49 UTC (rev 1106)
+++ trunk/MgDev/Common/PlatformBase/Services/ResourceService.h 2007-02-13 00:17:46 UTC (rev 1107)
@@ -505,7 +505,7 @@
/// location <c>Library://World/Layers/Cities.Layer</c>.
/// Similarly, you would add Countries.Layer to <c>Library://World/Layers/Countries.Layer</c>.
/// \n
- /// 5) Set any necessary \link WorkingWithResourceData resource data \endlink.
+ /// 5) Set any necessary resource data.
/// See SetResourceData.
Modified: trunk/MgDev/Common/PlatformBase/Services/ServiceRegistry.h
--- trunk/MgDev/Common/PlatformBase/Services/ServiceRegistry.h 2007-02-12 21:17:49 UTC (rev 1106)
+++ trunk/MgDev/Common/PlatformBase/Services/ServiceRegistry.h 2007-02-13 00:17:46 UTC (rev 1107)
@@ -25,6 +25,7 @@
#endif
/// \cond INTERNAL
/// \brief
/// Enumeration for the server connection type.
@@ -37,7 +38,7 @@
sctRemoteServerToServer, /// Proxy implementation used
sctServerToHttp /// Http requests are made
+/// \endcond
#define DECLARE_CREATE_SERVICE() \
public: \
@@ -47,14 +48,13 @@
MgService* class_name::CreateService() \
{ return new class_name(); }
-/// \cond INTERNAL
typedef MgService* (*ServiceCreatorFunc)();
-/// INTERNAL_CLASS
/// \cond INTERNAL
+/// INTERNAL_CLASS
/// \brief
/// Service registration for PlatformBase derived applications
class MG_PLATFORMBASE_API MgServiceRegistry : public MgDisposable
@@ -110,7 +110,6 @@
map<ServerConnectionType, ServiceRegistry> m_serviceCreators;
/// \endcond
#endif
Modified: trunk/MgDev/Common/PlatformBase/Services/SpatialContextReader.h
--- trunk/MgDev/Common/PlatformBase/Services/SpatialContextReader.h 2007-02-12 21:17:49 UTC (rev 1106)
+++ trunk/MgDev/Common/PlatformBase/Services/SpatialContextReader.h 2007-02-13 00:17:46 UTC (rev 1107)
@@ -20,7 +20,7 @@
class MgSpatialContextData;
-/// \defgroup MgSpatialContextReader
+/// \defgroup MgSpatialContextReader MgSpatialContextReader
Modified: trunk/MgDev/Common/PlatformBase/Services/UnlockFeatures.h
--- trunk/MgDev/Common/PlatformBase/Services/UnlockFeatures.h 2007-02-12 21:17:49 UTC (rev 1106)
+++ trunk/MgDev/Common/PlatformBase/Services/UnlockFeatures.h 2007-02-13 00:17:46 UTC (rev 1107)
@@ -19,7 +19,7 @@
#define _MGUNLOCKFEATURES_H
-/// \defgroup MgUnlockFeatures
+/// \defgroup MgUnlockFeatures MgUnlockFeatures
Modified: trunk/MgDev/Common/PlatformBase/Services/UpdateFeatures.h
--- trunk/MgDev/Common/PlatformBase/Services/UpdateFeatures.h 2007-02-12 21:17:49 UTC (rev 1106)
+++ trunk/MgDev/Common/PlatformBase/Services/UpdateFeatures.h 2007-02-13 00:17:46 UTC (rev 1107)
@@ -18,7 +18,7 @@
#ifndef _MGUPDATEFEATURES_H
#define _MGUPDATEFEATURES_H
-/// \defgroup MgUpdateFeatures
+/// \defgroup MgUpdateFeatures MgUpdateFeatures
More information about the mapguide-commits
