[mapguide-commits] r1112 - trunk/MgDev/Common/CoordinateSystem
svn_mapguide at osgeo.org
Fri Feb 16 15:51:40 EST 2007
Author: philipsharman
Date: 2007-02-16 15:51:40 -0500 (Fri, 16 Feb 2007)
New Revision: 1112
trunk/MgDev/Common/CoordinateSystem/CoordSys.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSys.h
trunk/MgDev/Common/CoordinateSystem/CoordSysCatalog.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysCatalog.h
trunk/MgDev/Common/CoordinateSystem/CoordSysCategory.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysCategory.h
trunk/MgDev/Common/CoordinateSystem/CoordSysCategoryCollection.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysCategoryCollection.h
trunk/MgDev/Common/CoordinateSystem/CoordSysCommon.h
trunk/MgDev/Common/CoordinateSystem/CoordSysComputationFailedException.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysComputationFailedException.h
trunk/MgDev/Common/CoordinateSystem/CoordSysConversionFailedException.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysConversionFailedException.h
trunk/MgDev/Common/CoordinateSystem/CoordSysDimension.h
trunk/MgDev/Common/CoordinateSystem/CoordSysEnvelope.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysEnvelope.h
trunk/MgDev/Common/CoordinateSystem/CoordSysException.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysException.h
trunk/MgDev/Common/CoordinateSystem/CoordSysFactory.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysFactory.h
trunk/MgDev/Common/CoordinateSystem/CoordSysIncludes.h
trunk/MgDev/Common/CoordinateSystem/CoordSysInformation.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysInformation.h
trunk/MgDev/Common/CoordinateSystem/CoordSysInitializationFailedException.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysInitializationFailedException.h
trunk/MgDev/Common/CoordinateSystem/CoordSysInvalidArgumentException.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysInvalidArgumentException.h
trunk/MgDev/Common/CoordinateSystem/CoordSysInvalidCoordinateSystemException.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysInvalidCoordinateSystemException.h
trunk/MgDev/Common/CoordinateSystem/CoordSysInvalidCoordinateSystemTypeException.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysInvalidCoordinateSystemTypeException.h
trunk/MgDev/Common/CoordinateSystem/CoordSysInvalidCoordinateSystemUnitsException.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysInvalidCoordinateSystemUnitsException.h
trunk/MgDev/Common/CoordinateSystem/CoordSysMeasure.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysMeasure.h
trunk/MgDev/Common/CoordinateSystem/CoordSysMeasureFailedException.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysMeasureFailedException.h
trunk/MgDev/Common/CoordinateSystem/CoordSysNullArgumentException.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysNullArgumentException.h
trunk/MgDev/Common/CoordinateSystem/CoordSysNullReferenceException.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysNullReferenceException.h
trunk/MgDev/Common/CoordinateSystem/CoordSysOutOfMemoryException.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysOutOfMemoryException.h
trunk/MgDev/Common/CoordinateSystem/CoordSysTransform.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysTransform.h
trunk/MgDev/Common/CoordinateSystem/CoordSysTransformFailedException.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysTransformFailedException.h
trunk/MgDev/Common/CoordinateSystem/CoordSysTransformation.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysTransformation.h
trunk/MgDev/Common/CoordinateSystem/CoordSysType.h
trunk/MgDev/Common/CoordinateSystem/CoordSysUtil.h
trunk/MgDev/Common/CoordinateSystem/CoordinateSystem.rc
trunk/MgDev/Common/CoordinateSystem/CriticalSection.h
trunk/MgDev/Common/CoordinateSystem/Dll.cpp
trunk/MgDev/Common/CoordinateSystem/stdafx.h
Updated the copyright date to 2007.
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSys.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSys.cpp 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSys.cpp 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
-// Copyright (C) 2004-2006 Autodesk, Inc.
+// Copyright (C) 2004-2007 by Autodesk, Inc.
// This library is free software; you can redistribute it and/or
// modify it under the terms of version 2.1 of the GNU Lesser
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSys.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSys.h 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSys.h 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysCatalog.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysCatalog.cpp 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysCatalog.cpp 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysCatalog.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysCatalog.h 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysCatalog.h 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysCategory.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysCategory.cpp 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysCategory.cpp 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysCategory.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysCategory.h 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysCategory.h 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysCategoryCollection.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysCategoryCollection.cpp 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysCategoryCollection.cpp 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysCategoryCollection.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysCategoryCollection.h 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysCategoryCollection.h 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysCommon.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysCommon.h 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysCommon.h 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysComputationFailedException.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysComputationFailedException.cpp 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysComputationFailedException.cpp 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysComputationFailedException.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysComputationFailedException.h 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysComputationFailedException.h 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysConversionFailedException.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysConversionFailedException.cpp 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysConversionFailedException.cpp 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysConversionFailedException.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysConversionFailedException.h 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysConversionFailedException.h 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysDimension.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysDimension.h 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysDimension.h 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysEnvelope.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysEnvelope.cpp 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysEnvelope.cpp 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysEnvelope.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysEnvelope.h 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysEnvelope.h 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysException.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysException.cpp 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysException.cpp 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysException.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysException.h 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysException.h 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysFactory.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysFactory.cpp 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysFactory.cpp 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysFactory.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysFactory.h 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysFactory.h 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysIncludes.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysIncludes.h 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysIncludes.h 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysInformation.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysInformation.cpp 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysInformation.cpp 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysInformation.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysInformation.h 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysInformation.h 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysInitializationFailedException.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysInitializationFailedException.cpp 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysInitializationFailedException.cpp 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysInitializationFailedException.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysInitializationFailedException.h 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysInitializationFailedException.h 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysInvalidArgumentException.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysInvalidArgumentException.cpp 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysInvalidArgumentException.cpp 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysInvalidArgumentException.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysInvalidArgumentException.h 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysInvalidArgumentException.h 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysInvalidCoordinateSystemException.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysInvalidCoordinateSystemException.cpp 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysInvalidCoordinateSystemException.cpp 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysInvalidCoordinateSystemException.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysInvalidCoordinateSystemException.h 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysInvalidCoordinateSystemException.h 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysInvalidCoordinateSystemTypeException.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysInvalidCoordinateSystemTypeException.cpp 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysInvalidCoordinateSystemTypeException.cpp 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysInvalidCoordinateSystemTypeException.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysInvalidCoordinateSystemTypeException.h 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysInvalidCoordinateSystemTypeException.h 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysInvalidCoordinateSystemUnitsException.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysInvalidCoordinateSystemUnitsException.cpp 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysInvalidCoordinateSystemUnitsException.cpp 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysInvalidCoordinateSystemUnitsException.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysInvalidCoordinateSystemUnitsException.h 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysInvalidCoordinateSystemUnitsException.h 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysMeasure.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysMeasure.cpp 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysMeasure.cpp 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysMeasure.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysMeasure.h 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysMeasure.h 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysMeasureFailedException.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysMeasureFailedException.cpp 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysMeasureFailedException.cpp 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysMeasureFailedException.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysMeasureFailedException.h 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysMeasureFailedException.h 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysNullArgumentException.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysNullArgumentException.cpp 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysNullArgumentException.cpp 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysNullArgumentException.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysNullArgumentException.h 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysNullArgumentException.h 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysNullReferenceException.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysNullReferenceException.cpp 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysNullReferenceException.cpp 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysNullReferenceException.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysNullReferenceException.h 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysNullReferenceException.h 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysOutOfMemoryException.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysOutOfMemoryException.cpp 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysOutOfMemoryException.cpp 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysOutOfMemoryException.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysOutOfMemoryException.h 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysOutOfMemoryException.h 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysTransform.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysTransform.cpp 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysTransform.cpp 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysTransform.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysTransform.h 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysTransform.h 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysTransformFailedException.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysTransformFailedException.cpp 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysTransformFailedException.cpp 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysTransformFailedException.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysTransformFailedException.h 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysTransformFailedException.h 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysTransformation.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysTransformation.cpp 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysTransformation.cpp 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysTransformation.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysTransformation.h 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysTransformation.h 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysType.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysType.h 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysType.h 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysUtil.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysUtil.h 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysUtil.h 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordinateSystem.rc
--- trunk/MgDev/Common/CoordinateSystem/CoordinateSystem.rc 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CoordinateSystem.rc 2007-02-16 20:51:40 UTC (rev 1112)
@@ -67,7 +67,7 @@
VALUE "FileDescription", "CoordinateSystem Dynamic Link Library"
VALUE "FileVersion", "1, 0, 0, 1"
VALUE "InternalName", "MgCoordinateSystem"
- VALUE "LegalCopyright", "Copyright (C) 2006 Autodesk, Inc."
+ VALUE "LegalCopyright", "Copyright (C) 2007 Autodesk, Inc."
VALUE "OriginalFilename", "MgCoordinateSystem.dll"
VALUE "ProductName", "MapGuide Open Source"
VALUE "ProductVersion", "1, 0, 0, 1"
Modified: trunk/MgDev/Common/CoordinateSystem/CriticalSection.h
--- trunk/MgDev/Common/CoordinateSystem/CriticalSection.h 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/CriticalSection.h 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/Dll.cpp
--- trunk/MgDev/Common/CoordinateSystem/Dll.cpp 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/Dll.cpp 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Common/CoordinateSystem/stdafx.h
--- trunk/MgDev/Common/CoordinateSystem/stdafx.h 2007-02-16 19:21:33 UTC (rev 1111)
+++ trunk/MgDev/Common/CoordinateSystem/stdafx.h 2007-02-16 20:51:40 UTC (rev 1112)
@@ -1,5 +1,5 @@
More information about the mapguide-commits
