[mapguide-commits] r1135 - trunk/MgDev/Common/CoordinateSystem
svn_mapguide at osgeo.org
Fri Feb 23 17:21:27 EST 2007
Author: brucedechant
Date: 2007-02-23 17:21:27 -0500 (Fri, 23 Feb 2007)
New Revision: 1135
trunk/MgDev/Common/CoordinateSystem/CoordSysTransform.cpp
Fix no datum shift performed in MapGuide's public API when the two coordinate systems are both geographic, but are different geographic coordinate systems.
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysTransform.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysTransform.cpp 2007-02-23 19:01:55 UTC (rev 1134)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysTransform.cpp 2007-02-23 22:21:27 UTC (rev 1135)
@@ -41,6 +41,8 @@
m_coordSysTarget(NULL),
m_transformHint(TH_IDENTITY)
+ bool bPossibleDatumConversion = false;
if(NULL == source)
throw new CNullArgumentException(L"CCoordinateSystemTransform.CCoordinateSystemTransform", __LINE__, __WFILE__, L"[1] - CCoordinateSystem pointer.");
@@ -66,6 +68,8 @@
if ((m_coordSysSource->GetType() == CCoordinateSystemType::Arbitrary) &&
(m_coordSysTarget->GetType() == CCoordinateSystemType::Arbitrary))
+ bPossibleDatumConversion = false;
// Make sure the unit scale values are set so that we can't get a
// divide by zero error.
if ((m_coordSysSource->GetUnitScale() != 0.0) &&
@@ -81,32 +85,37 @@
else if ((m_coordSysSource->GetType() == CCoordinateSystemType::Arbitrary) ||
m_transformHint = TH_IDENTITY;
else if ((m_coordSysSource->GetType() == CCoordinateSystemType::Geographic) &&
(m_coordSysTarget->GetType() == CCoordinateSystemType::Geographic))
+ bPossibleDatumConversion = true;
else if (m_coordSysSource->GetInternalCoordinateSystem()->IsSame(m_coordSysTarget->GetInternalCoordinateSystem()))
else if(m_coordSysSource->GetType() == CCoordinateSystemType::Geographic)
m_transformHint = TH_GEOGRAPHIC_TO_PROJECTED;
else if(m_coordSysTarget->GetType() == CCoordinateSystemType::Geographic)
m_transformHint = TH_PROJECTED_TO_GEOGRAPHIC;
else
m_transformHint = TH_PROJECTED_TO_PROJECTED;
- // If the source and destination coordinate systems match then there is no datum shift
- if((m_transformHint != TH_IDENTITY) && (m_transformHint != TH_LOCAL))
+ if(bPossibleDatumConversion)
// Setup the transformation with datum shift
m_transformForward = CCoordinateSystemTransformation::CreateCoordinateTransformation(m_coordSysSource->GetInternalCoordinateSystem(), m_coordSysTarget->GetInternalCoordinateSystem(), true);
@@ -560,6 +569,17 @@
switch(m_transformHint)
case TH_IDENTITY: // No conversion required
+ if(m_transformForward)
+ //pass on to proj for the transform
+ if (TRUE != m_transformForward->TransformEx(numPts, x, y, z, NULL))
+ //if proj failed to convert, generate an exception
+ throw new CCoordinateSystemTransformFailedException(L"CCoordinateSystemTransform.InternalTransform", __LINE__, __WFILE__, L"PROJ4 failed to transform the data.");
break;
case TH_LOCAL: // Scaling only
More information about the mapguide-commits
