[mapguide-commits] r1080 - in trunk/MgDev/Server/src: Core
UnitTesting
svn_mapguide at osgeo.org
Mon Jan 29 19:08:26 EST 2007
Author: tonyfang
Date: 2007-01-29 19:08:25 -0500 (Mon, 29 Jan 2007)
New Revision: 1080
trunk/MgDev/Server/src/Core/serverconfig.ini
trunk/MgDev/Server/src/UnitTesting/TestResourceService.cpp
trunk/MgDev/Server/src/UnitTesting/TestResourceService.h
trunk/MgDev/Server/src/UnitTesting/TestServerAdminService.cpp
trunk/MgDev/Server/src/UnitTesting/TestServerAdminService.h
MapGuide RFC 12 - Unmanaged Data API Changes
- added unit test for RemoveConfigurationProperties
- added unit test for EnumerateUnmanagedData
- added UnmanagedDataMappings section to serverconfig.ini
Modified: trunk/MgDev/Server/src/Core/serverconfig.ini
--- trunk/MgDev/Server/src/Core/serverconfig.ini 2007-01-29 19:29:09 UTC (rev 1079)
+++ trunk/MgDev/Server/src/Core/serverconfig.ini 2007-01-30 00:08:25 UTC (rev 1080)
@@ -438,3 +438,9 @@
MS Pゴシック = MS PGothic
MS 明朝 = MS Mincho
MS P明朝 = MS PMincho
+[UnmanagedDataMappings]
+# U N M A N A G E D D A T A M A P P I N G S
+# This section is used to map a mapping name to an unmanaged data folder.
\ No newline at end of file
Modified: trunk/MgDev/Server/src/UnitTesting/TestResourceService.cpp
--- trunk/MgDev/Server/src/UnitTesting/TestResourceService.cpp 2007-01-29 19:29:09 UTC (rev 1079)
+++ trunk/MgDev/Server/src/UnitTesting/TestResourceService.cpp 2007-01-30 00:08:25 UTC (rev 1080)
@@ -1472,3 +1472,42 @@
throw;
+/// Test Case Description:
+/// This test case enumerates the unmanaged data
+void TestResourceService::TestCase_EnumerateUnmanagedData()
+ try
+ MgServiceManager* serviceManager = MgServiceManager::GetInstance();
+ if(serviceManager == 0)
+ throw new MgNullReferenceException(L"TestResourceService.TestCase_EnumerateUnmanagedData", __LINE__, __WFILE__, NULL, L"", NULL);
+ Ptr<MgResourceService> pService = dynamic_cast<MgResourceService*>(serviceManager->RequestService(MgServiceType::ResourceService));
+ if (pService == 0)
+ throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_EnumerateUnmanagedData", __LINE__, __WFILE__, NULL, L"", NULL);
+ // Try to enumerate mappings
+ Ptr<MgByteReader> byteReader0 = pService->EnumerateUnmanagedData(L"", false, L"FOLDERS", L"");
+ STRING mimeType0 = byteReader0->GetMimeType();
+ CPPUNIT_ASSERT(wcscmp(mimeType0.c_str(), MgMimeType::Xml.c_str()) == 0);
+ // Enumerate all unmanaged data files
+ Ptr<MgByteReader> byteReader1 = pService->EnumerateUnmanagedData(L"", true, L"FILES", L"");
+ STRING mimeType1 = byteReader1->GetMimeType();
+ CPPUNIT_ASSERT(wcscmp(mimeType1.c_str(), MgMimeType::Xml.c_str()) == 0);
+ catch(MgException* e)
+ STRING message = e->GetDetails(TEST_LOCALE);
+ SAFE_RELEASE(e);
+ CPPUNIT_FAIL(MG_WCHAR_TO_CHAR(message.c_str()));
Modified: trunk/MgDev/Server/src/UnitTesting/TestResourceService.h
--- trunk/MgDev/Server/src/UnitTesting/TestResourceService.h 2007-01-29 19:29:09 UTC (rev 1079)
+++ trunk/MgDev/Server/src/UnitTesting/TestResourceService.h 2007-01-30 00:08:25 UTC (rev 1080)
@@ -51,6 +51,8 @@
CPPUNIT_TEST(TestCase_DeleteResource);
+ CPPUNIT_TEST(TestCase_EnumerateUnmanagedData);
CPPUNIT_TEST(TestEnd); // This must be the very last unit test
CPPUNIT_TEST_SUITE_END();
@@ -88,6 +90,8 @@
void TestCase_DeleteResourceData();
void TestCase_DeleteResource();
+ void TestCase_EnumerateUnmanagedData();
#endif // TESTRESOURCESERVICE_H_
Modified: trunk/MgDev/Server/src/UnitTesting/TestServerAdminService.cpp
--- trunk/MgDev/Server/src/UnitTesting/TestServerAdminService.cpp 2007-01-29 19:29:09 UTC (rev 1079)
+++ trunk/MgDev/Server/src/UnitTesting/TestServerAdminService.cpp 2007-01-30 00:08:25 UTC (rev 1080)
@@ -222,7 +222,57 @@
+/// This test case tries to remove the server configuration properties
+void TestServerAdminService::TestCase_RemoveConfigurationProperties()
+ try
+ MgServiceManager* serviceMan = MgServiceManager::GetInstance();
+ if(serviceMan == 0)
+ throw new MgNullReferenceException(L"TestServerAdminService::TestCase_RemoveConfigurationProperties", __LINE__, __WFILE__, NULL, L"", NULL);
+ Ptr<MgServerAdminService> pService = dynamic_cast<MgServerAdminService*>(serviceMan->RequestService(MgServiceType::ServerAdminService));
+ throw new MgServiceNotAvailableException(L"TestServerAdminService::TestCase_RemoveConfigurationProperties", __LINE__, __WFILE__, NULL, L"", NULL);
+ Ptr<MgPropertyCollection> pPropertyCollection1 = pService->GetConfigurationProperties(L"GeneralProperties");
+ Ptr<MgStringProperty> pProperty1 = (MgStringProperty*)pPropertyCollection1->GetItem(L"DefaultLocale");
+ STRING valueOriginal = pProperty1->GetValue();
+ Ptr<MgPropertyCollection> pPropertyCollectionRemove = new MgPropertyCollection();
+ Ptr<MgStringProperty> pPropertyRemove = new MgStringProperty(L"DefaultLocale", L"");
+ pPropertyCollectionRemove->Add(pPropertyRemove);
+ pService->RemoveConfigurationProperties(L"GeneralProperties", pPropertyCollectionRemove);
+ Ptr<MgPropertyCollection> pPropertyCollection2 = pService->GetConfigurationProperties(L"GeneralProperties");
+ Ptr<MgStringProperty> pProperty2 = (MgStringProperty*)pPropertyCollection1->GetItem(L"DefaultLocale");
+ CPPUNIT_ASSERT(pProperty2 == NULL);
+ // Restore original value
+ pService->SetConfigurationProperties(L"GeneralProperties", pPropertyCollection1);
+ SAFE_RELEASE(e);
+ catch(...)
+ throw;
Modified: trunk/MgDev/Server/src/UnitTesting/TestServerAdminService.h
--- trunk/MgDev/Server/src/UnitTesting/TestServerAdminService.h 2007-01-29 19:29:09 UTC (rev 1079)
+++ trunk/MgDev/Server/src/UnitTesting/TestServerAdminService.h 2007-01-30 00:08:25 UTC (rev 1080)
@@ -30,6 +30,7 @@
//CPPUNIT_TEST(TestCase_IsOnline);
CPPUNIT_TEST(TestCase_GetConfigurationProperties);
CPPUNIT_TEST(TestCase_SetConfigurationProperties);
+ CPPUNIT_TEST(TestCase_RemoveConfigurationProperties);
CPPUNIT_TEST(TestCase_GetInformationProperties);
CPPUNIT_TEST(TestCase_ClearLog);
@@ -65,6 +66,7 @@
//void TestCase_IsOnline();
void TestCase_GetConfigurationProperties();
void TestCase_SetConfigurationProperties();
+ void TestCase_RemoveConfigurationProperties();
void TestCase_GetInformationProperties();
void TestCase_ClearLog();
More information about the mapguide-commits
