[mapguide-commits] r1146 - in trunk/MgDev:
Common/MapGuideCommon/Services Common/PlatformBase/Services
Server/src/Common/Manager Server/src/Services/Feature
Server/src/Services/Resource
UnitTest/WebTier/MapAgent/MapAgentForms Web/src/HttpHandler
svn_mapguide at osgeo.org
Fri Mar 2 00:50:23 EST 2007
Author: tonyfang
Date: 2007-03-02 00:50:23 -0500 (Fri, 02 Mar 2007)
New Revision: 1146
trunk/MgDev/Common/MapGuideCommon/Services/ProxyResourceService.cpp
trunk/MgDev/Common/PlatformBase/Services/ResourceDefs.cpp
trunk/MgDev/Common/PlatformBase/Services/ResourceDefs.h
trunk/MgDev/Common/PlatformBase/Services/ResourceService.cpp
trunk/MgDev/Common/PlatformBase/Services/ResourceService.h
trunk/MgDev/Server/src/Common/Manager/UnmanagedDataManager.cpp
trunk/MgDev/Server/src/Common/Manager/UnmanagedDataManager.h
trunk/MgDev/Server/src/Services/Feature/ServerGetSchemaMapping.cpp
trunk/MgDev/Server/src/Services/Resource/OpEnumerateUnmanagedData.cpp
trunk/MgDev/Server/src/Services/Resource/ServerResourceService.cpp
trunk/MgDev/Server/src/Services/Resource/ServerResourceService.h
trunk/MgDev/Server/src/Services/Resource/TagManager.cpp
trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/enumerateunmanageddataform.html
trunk/MgDev/Web/src/HttpHandler/HttpEnumerateUnmanagedData.cpp
trunk/MgDev/Web/src/HttpHandler/HttpEnumerateUnmanagedData.h
trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.cpp
trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.h
Update to MapGuide RFC 12 - Unmanaged Data API Changes
- use %MG_DATA_PATH_ALIAS[alias]%
* added MgResourceTag::DataPathAliasBegin and MgResourceTag::DataPathAliasEnd (moved/renamed from UnmanagedDataManager)
* renamed SubstituteMappingTag to SubstituteDataPathAliases
- renamed EnumerateUnmanagedData API "select" argument to "type"
* added MgResourceUnmanagedDataType::Folders, Files, Both (moved/renamed from UnmanagedDataManager)
- fixed http signature for EnumerateUnmanagedData API
* use "1" or "0" for recursive argument
* changed webtier test pages to use "1" or "0" for recursive argument
Other Unmanaged Data API fixes
- fixed SubstituteDataPathAliases (SubstituteMappingTag) bug
* unclosed tags, multiple tags resulted in an infinite loop
- use MgUtil::ReplaceEscapeCharInXml to encode file/folder names in EnumerateUnmanagedData
- Corrected EnumerateUnmanagedData API declaration to PUBLISHED_API instead of INTERNAL_API
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ProxyResourceService.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/ProxyResourceService.cpp 2007-03-02 01:40:09 UTC (rev 1145)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ProxyResourceService.cpp 2007-03-02 05:50:23 UTC (rev 1146)
@@ -1062,7 +1062,7 @@
/// Enumerates the unmanaged data
MgByteReader* MgProxyResourceService::EnumerateUnmanagedData(
- CREFSTRING path, bool recursive, CREFSTRING select, CREFSTRING filter)
+ CREFSTRING path, bool recursive, CREFSTRING type, CREFSTRING filter)
MgCommand cmd;
@@ -1074,7 +1074,7 @@
1,
MgCommand::knString, &path,
MgCommand::knInt8, (int)recursive,
- MgCommand::knString, &select,
+ MgCommand::knString, &type,
MgCommand::knString, &filter,
MgCommand::knNone);
Modified: trunk/MgDev/Common/PlatformBase/Services/ResourceDefs.cpp
--- trunk/MgDev/Common/PlatformBase/Services/ResourceDefs.cpp 2007-03-02 01:40:09 UTC (rev 1145)
+++ trunk/MgDev/Common/PlatformBase/Services/ResourceDefs.cpp 2007-03-02 05:50:23 UTC (rev 1146)
@@ -64,6 +64,8 @@
const STRING MgResourceTag::Username = L"%MG_USERNAME%";
const STRING MgResourceTag::Password = L"%MG_PASSWORD%";
const STRING MgResourceTag::DataFilePath = L"%MG_DATA_FILE_PATH%";
+const STRING MgResourceTag::DataPathAliasBegin = L"%MG_DATA_PATH_ALIAS[";
+const STRING MgResourceTag::DataPathAliasEnd = L"]%";
@@ -101,3 +103,10 @@
const STRING MgResourceFolder::Users = L"Users";
const STRING MgResourceFolder::Groups = L"Groups";
const STRING MgResourceFolder::Roles = L"Roles";
+/// Types of unmanaged data that can be returned
+const STRING MgResourceUnmanagedDataType::Folders = L"Folders";
+const STRING MgResourceUnmanagedDataType::Files = L"Files";
+const STRING MgResourceUnmanagedDataType::Both = L"Both";
Modified: trunk/MgDev/Common/PlatformBase/Services/ResourceDefs.h
--- trunk/MgDev/Common/PlatformBase/Services/ResourceDefs.h 2007-03-02 01:40:09 UTC (rev 1145)
+++ trunk/MgDev/Common/PlatformBase/Services/ResourceDefs.h 2007-03-02 05:50:23 UTC (rev 1146)
@@ -279,6 +279,18 @@
/// given resource. The trailing "/" is included.
static const STRING DataFilePath; ///\if INTERNAL value("%MG_DATA_FILE_PATH%") \endif
+ /// \brief
+ /// Denotes beginning of data path alias.
+ static const STRING DataPathAliasBegin; ///\if INTERNAL value("%MG_DATA_PATH_ALIAS[") \endif
+ /// \brief
+ /// Denotes end of data path alias.
+ static const STRING DataPathAliasEnd; ///\if INTERNAL value("]%") \endif
@@ -432,6 +444,30 @@
/// \endcond
+/// \brief
+/// \ingroup Resource_Service_classes
+class MG_PLATFORMBASE_API MgResourceUnmanagedDataType
+PUBLISHED_API:
+ /// \if INTERNAL
+ /// The "value(xxx)" comments are used by SWIG to build constants.php. Do not alter them.
+ /// \endif
+ /// Return folders only
+ static const STRING Folders; ///\if INTERNAL value("Folders") \endif
+ /// Return files only
+ static const STRING Files; ///\if INTERNAL value("Files") \endif
+ /// Return both files and folders
+ static const STRING Both; ///\if INTERNAL value("Both") \endif
#define DECLARE_DYNCREATE_RESOURCE() \
public: \
static MgObject* CreateObject();
Modified: trunk/MgDev/Common/PlatformBase/Services/ResourceService.cpp
--- trunk/MgDev/Common/PlatformBase/Services/ResourceService.cpp 2007-03-02 01:40:09 UTC (rev 1145)
+++ trunk/MgDev/Common/PlatformBase/Services/ResourceService.cpp 2007-03-02 05:50:23 UTC (rev 1146)
@@ -204,7 +204,7 @@
/// Resources of all types can be enumerated all at once, or only
/// resources of a given type.
-MgByteReader* MgResourceService::EnumerateUnmanagedData(CREFSTRING path, bool recursive, CREFSTRING select, CREFSTRING filter)
+MgByteReader* MgResourceService::EnumerateUnmanagedData(CREFSTRING path, bool recursive, CREFSTRING type, CREFSTRING filter)
throw new MgNotImplementedException(L"MgResourceService.EnumerateUnmanagedData", __LINE__, __WFILE__, NULL, L"", NULL);
Modified: trunk/MgDev/Common/PlatformBase/Services/ResourceService.h
--- trunk/MgDev/Common/PlatformBase/Services/ResourceService.h 2007-03-02 01:40:09 UTC (rev 1145)
+++ trunk/MgDev/Common/PlatformBase/Services/ResourceService.h 2007-03-02 05:50:23 UTC (rev 1146)
@@ -1500,6 +1500,37 @@
virtual bool ResourceExists(MgResourceIdentifier* resource);
+ /// \brief
+ /// Enumerate unmanaged data
+ /// <!-- Syntax in .Net, Java, and PHP -->
+ /// \htmlinclude DotNetSyntaxTop.html
+ /// virtual MgByteReader EnumerateUnmanagedData(string path, bool recursive, string type, string filter);
+ /// \htmlinclude SyntaxBottom.html
+ /// \htmlinclude JavaSyntaxTop.html
+ /// virtual MgByteReader EnumerateUnmanagedData(String path, boolean recursive, String type, String filter);
+ /// \htmlinclude PHPSyntaxTop.html
+ /// \param path (String/string)
+ /// Unmanaged data path
+ /// \param recursive (boolean/bool)
+ /// Flag to determine whether to recurse subfolders or not
+ /// \param type (String/string)
+ /// Folders, Files, or Both
+ /// \param filter (String/string)
+ /// file filter to be used on returned files
+ /// \return
+ /// Returns an MgByteReader object containing the unmanaged data
+ /// in XML format using the \link UnmanagedDataList_schema UnmanagedDataList_schema \endlink
+ virtual MgByteReader* EnumerateUnmanagedData(CREFSTRING path, bool recursive, CREFSTRING type, CREFSTRING filter);
INTERNAL_API:
@@ -1635,15 +1666,6 @@
virtual MgSerializableCollection* EnumerateParentMapDefinitions(
MgSerializableCollection* resources) = 0;
- /// \brief
- /// Enumerate unmanaged data
- /// \return
- /// MgByteReader of unmanaged data
- virtual MgByteReader* EnumerateUnmanagedData(CREFSTRING path, bool recursive, CREFSTRING select, CREFSTRING filter);
protected:
Modified: trunk/MgDev/Server/src/Common/Manager/UnmanagedDataManager.cpp
--- trunk/MgDev/Server/src/Common/Manager/UnmanagedDataManager.cpp 2007-03-02 01:40:09 UTC (rev 1145)
+++ trunk/MgDev/Server/src/Common/Manager/UnmanagedDataManager.cpp 2007-03-02 05:50:23 UTC (rev 1146)
@@ -24,16 +24,11 @@
// Process-wide MgUnmanagedDataManager
Ptr<MgUnmanagedDataManager> MgUnmanagedDataManager::sm_unmanagedDataManager = (MgUnmanagedDataManager*)NULL;
-const STRING MgUnmanagedDataManager::Folders = L"FOLDERS";
-const STRING MgUnmanagedDataManager::Files = L"FILES";
-const STRING MgUnmanagedDataManager::Both = L"BOTH";
-const STRING MgUnmanagedDataManager::OpenSquareBracket = L"[";
-const STRING MgUnmanagedDataManager::ClosedSquareBracket = L"]";
+const STRING MgUnmanagedDataManager::SquareBracketBegin = L"[";
+const wchar_t MgUnmanagedDataManager::SquareBracketCharBegin = L'[';
+const STRING MgUnmanagedDataManager::SquareBracketEnd = L"]";
+const wchar_t MgUnmanagedDataManager::SquareBracketCharEnd = L']';
-const string MgUnmanagedDataManager::MappingBegin = "%MG_[";
-const string MgUnmanagedDataManager::MappingEnd = "]%";
/// \brief
/// Constructs the object.
@@ -89,10 +84,10 @@
else
// the first character must be open square bracket '['
- if (path.at(0) == L'[')
+ if (path.at(0) == SquareBracketCharBegin)
// find the first closed square bracket ']'
- size_t pos = path.find_first_of(L']');
+ size_t pos = path.find_first_of(SquareBracketCharEnd);
size_t pathlen = path.length();
if (pos > 1 && pos < pathlen)
@@ -239,7 +234,7 @@
// append a slash to the folder if is NOT just the [alias]
if (!entryName.empty() && !MgFileUtil::EndsWithSlash(id))
MgFileUtil::AppendSlashToEndOfPath(id);
- string unmanagedDataId = MgUtil::WideCharToMultiByte(id);
+ string unmanagedDataId = MgUtil::WideCharToMultiByte(MgUtil::ReplaceEscapeCharInXml(id));
list += "\t\t<UnmanagedDataId>";
list += unmanagedDataId;
list += "</UnmanagedDataId>\n";
@@ -272,7 +267,7 @@
list += "\t<UnmanagedDataFile>\n";
STRING id = FormatMappingName(mappingName) + FormatSubdir(subdir) + entryName;
@@ -338,7 +333,7 @@
STRING MgUnmanagedDataManager::FormatMappingName(CREFSTRING name)
- return MgUnmanagedDataManager::OpenSquareBracket + name + MgUnmanagedDataManager::ClosedSquareBracket;
+ return MgUnmanagedDataManager::SquareBracketBegin + name + MgUnmanagedDataManager::SquareBracketEnd;
@@ -398,10 +393,10 @@
/// \brief
/// Substitutes unmanaged data mappings
-int MgUnmanagedDataManager::SubstituteMappingTag(REFSTRING doc)
+int MgUnmanagedDataManager::SubstituteDataPathAliases(REFSTRING doc)
string temp = MgUtil::WideCharToMultiByte(doc);
- int result = SubstituteMappingTag(temp);
+ int result = SubstituteDataPathAliases(temp);
doc = MgUtil::MultiByteToWideChar(temp);
return result;
@@ -409,19 +404,22 @@
/// \brief
-/// Substitutes unmanaged data mappings
+/// Substitutes unmanaged data aliases
-int MgUnmanagedDataManager::SubstituteMappingTag(string& doc)
+int MgUnmanagedDataManager::SubstituteDataPathAliases(string& doc)
int count = 0;
- size_t startPos, endPos;
- size_t len1 = MgUnmanagedDataManager::MappingBegin.length();
- size_t len2 = MgUnmanagedDataManager::MappingEnd.length();
+ size_t startPos = 0, endPos = 0, currStartPos = 0;
+ string dataPathAliasBegin = MgUtil::WideCharToMultiByte(MgResourceTag::DataPathAliasBegin);
+ string dataPathAliasEnd = MgUtil::WideCharToMultiByte(MgResourceTag::DataPathAliasEnd);
+ size_t len1 = dataPathAliasBegin.length();
+ size_t len2 = dataPathAliasEnd.length();
- while (string::npos != (startPos = doc.find(MgUnmanagedDataManager::MappingBegin)))
+ while (string::npos != (startPos = doc.find(dataPathAliasBegin, currStartPos)))
+ bool aliasSubstituted = false;
// beginTag found, now look for endTag
- while (string::npos != (endPos = doc.find(MgUnmanagedDataManager::MappingEnd)))
+ while (string::npos != (endPos = doc.find(dataPathAliasEnd, startPos + len1)))
// extract out the mapping name
string mappingName = doc.substr(startPos + len1, endPos - startPos - len1);
@@ -443,11 +441,16 @@
size_t dirLen = mappingDir.length();
doc.replace(startPos, len1 + nameLen + len2, MgUtil::WideCharToMultiByte(mappingDir), 0, dirLen);
+ currStartPos = startPos + dirLen;
+ aliasSubstituted = true;
++count;
- break;
+ break;
+ if (!aliasSubstituted)
+ currStartPos = endPos + len2;
return count;
@@ -457,7 +460,7 @@
/// \brief
/// Returns unmanaged data
-MgByteReader* MgUnmanagedDataManager::EnumerateUnmanagedData(CREFSTRING path, bool recursive, CREFSTRING select, CREFSTRING filter)
+MgByteReader* MgUnmanagedDataManager::EnumerateUnmanagedData(CREFSTRING path, bool recursive, CREFSTRING type, CREFSTRING filter)
Ptr<MgByteReader> byteReader;
@@ -492,20 +495,20 @@
__LINE__, __WFILE__, &arguments, L"", NULL);
- // select must be:
+ // type must be:
// "FOLDERS"
// "FILES"
// "BOTH"
- bool storeFolders = ACE_OS::strcasecmp(select.c_str(), MgUnmanagedDataManager::Folders.c_str()) == 0
- || ACE_OS::strcasecmp(select.c_str(), MgUnmanagedDataManager::Both.c_str()) == 0;
+ bool storeFolders = ACE_OS::strcasecmp(type.c_str(), MgResourceUnmanagedDataType::Folders.c_str()) == 0
+ || ACE_OS::strcasecmp(type.c_str(), MgResourceUnmanagedDataType::Both.c_str()) == 0;
- bool storeFiles = ACE_OS::strcasecmp(select.c_str(), MgUnmanagedDataManager::Files.c_str()) == 0
+ bool storeFiles = ACE_OS::strcasecmp(type.c_str(), MgResourceUnmanagedDataType::Files.c_str()) == 0
ACE_ASSERT(storeFolders || storeFiles);
- // filter is ignored if select = "FOLDERS"
+ // filter is ignored if type = "FOLDERS"
// filter can be:
// ".sdf"
Modified: trunk/MgDev/Server/src/Common/Manager/UnmanagedDataManager.h
--- trunk/MgDev/Server/src/Common/Manager/UnmanagedDataManager.h 2007-03-02 01:40:09 UTC (rev 1145)
+++ trunk/MgDev/Server/src/Common/Manager/UnmanagedDataManager.h 2007-03-02 05:50:23 UTC (rev 1146)
@@ -56,13 +56,13 @@
static MgUnmanagedDataManager* GetInstance();
MgPropertyCollection* GetUnmanagedDataMappings();
- static int SubstituteMappingTag(REFSTRING data);
- static int SubstituteMappingTag(string& data);
+ static int SubstituteDataPathAliases(REFSTRING data);
+ static int SubstituteDataPathAliases(string& data);
void Initialize();
virtual void Dispose();
- MgByteReader* EnumerateUnmanagedData(CREFSTRING path, bool recursive, CREFSTRING select, CREFSTRING filter);
+ MgByteReader* EnumerateUnmanagedData(CREFSTRING path, bool recursive, CREFSTRING type, CREFSTRING filter);
/// Data Members
@@ -71,15 +71,10 @@
static Ptr<MgUnmanagedDataManager> sm_unmanagedDataManager;
Ptr<MgPropertyCollection> m_unmanagedDataMappings;
- static const STRING Folders;
- static const STRING Files;
- static const STRING Both;
- static const STRING OpenSquareBracket;
- static const STRING ClosedSquareBracket;
- static const string MappingBegin;
- static const string MappingEnd;
+ static const STRING SquareBracketBegin;
+ static const wchar_t SquareBracketCharBegin;
+ static const STRING SquareBracketEnd;
+ static const wchar_t SquareBracketCharEnd;
#endif
Modified: trunk/MgDev/Server/src/Services/Feature/ServerGetSchemaMapping.cpp
--- trunk/MgDev/Server/src/Services/Feature/ServerGetSchemaMapping.cpp 2007-03-02 01:40:09 UTC (rev 1145)
+++ trunk/MgDev/Server/src/Services/Feature/ServerGetSchemaMapping.cpp 2007-03-02 05:50:23 UTC (rev 1146)
@@ -41,7 +41,7 @@
FdoPtr<FdoIConnection> fdoConnection;
STRING data = partialConnString;
- MgUnmanagedDataManager::SubstituteMappingTag(data);
+ MgUnmanagedDataManager::SubstituteDataPathAliases(data);
MgServerFeatureConnection msfc(providerName, data);
if (( msfc.IsConnectionOpen() ) || ( msfc.IsConnectionPending() ))
Modified: trunk/MgDev/Server/src/Services/Resource/OpEnumerateUnmanagedData.cpp
--- trunk/MgDev/Server/src/Services/Resource/OpEnumerateUnmanagedData.cpp 2007-03-02 01:40:09 UTC (rev 1145)
+++ trunk/MgDev/Server/src/Services/Resource/OpEnumerateUnmanagedData.cpp 2007-03-02 05:50:23 UTC (rev 1146)
@@ -69,11 +69,11 @@
if (4 == m_packet.m_NumArguments)
- STRING path, select, filter;
+ STRING path, type, filter;
bool recursive;
m_stream->GetString(path);
m_stream->GetBoolean(recursive);
- m_stream->GetString(select);
+ m_stream->GetString(type);
m_stream->GetString(filter);
BeginExecution();
@@ -83,7 +83,7 @@
MG_LOG_OPERATION_MESSAGE_ADD_SEPARATOR();
MG_LOG_OPERATION_MESSAGE_ADD_BOOL(recursive);
- MG_LOG_OPERATION_MESSAGE_ADD_STRING(select.c_str());
+ MG_LOG_OPERATION_MESSAGE_ADD_STRING(type.c_str());
MG_LOG_OPERATION_MESSAGE_ADD_STRING(filter.c_str());
MG_LOG_OPERATION_MESSAGE_PARAMETERS_END();
@@ -91,7 +91,7 @@
Validate();
Ptr<MgByteReader> byteReader =
- m_service->EnumerateUnmanagedData(path, recursive, select, filter);
+ m_service->EnumerateUnmanagedData(path, recursive, type, filter);
EndExecution(byteReader);
Modified: trunk/MgDev/Server/src/Services/Resource/ServerResourceService.cpp
--- trunk/MgDev/Server/src/Services/Resource/ServerResourceService.cpp 2007-03-02 01:40:09 UTC (rev 1145)
+++ trunk/MgDev/Server/src/Services/Resource/ServerResourceService.cpp 2007-03-02 05:50:23 UTC (rev 1146)
@@ -1833,7 +1833,7 @@
MgByteReader* MgServerResourceService::EnumerateUnmanagedData(
@@ -1841,7 +1841,7 @@
MG_LOG_TRACE_ENTRY(L"MgServerResourceService::EnumerateUnmanagedData()");
- byteReader = MgUnmanagedDataManager::GetInstance()->EnumerateUnmanagedData(path, recursive, select, filter);
+ byteReader = MgUnmanagedDataManager::GetInstance()->EnumerateUnmanagedData(path, recursive, type, filter);
MG_RESOURCE_SERVICE_CATCH_AND_THROW(L"MgServerResourceService.EnumerateUnmanagedData")
Modified: trunk/MgDev/Server/src/Services/Resource/ServerResourceService.h
--- trunk/MgDev/Server/src/Services/Resource/ServerResourceService.h 2007-03-02 01:40:09 UTC (rev 1145)
+++ trunk/MgDev/Server/src/Services/Resource/ServerResourceService.h 2007-03-02 05:50:23 UTC (rev 1146)
@@ -146,7 +146,7 @@
// Unmanaged Data APIs
// Site Security related methods
Modified: trunk/MgDev/Server/src/Services/Resource/TagManager.cpp
--- trunk/MgDev/Server/src/Services/Resource/TagManager.cpp 2007-03-02 01:40:09 UTC (rev 1145)
+++ trunk/MgDev/Server/src/Services/Resource/TagManager.cpp 2007-03-02 05:50:23 UTC (rev 1146)
@@ -323,7 +323,7 @@
if (dataBindingInfo.GetSubstituteUnmanagedDataMappings())
- count += MgUnmanagedDataManager::SubstituteMappingTag(doc);
+ count += MgUnmanagedDataManager::SubstituteDataPathAliases(doc);
CheckTagStrings(doc);
Modified: trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/enumerateunmanageddataform.html
--- trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/enumerateunmanageddataform.html 2007-03-02 01:40:09 UTC (rev 1145)
+++ trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/enumerateunmanageddataform.html 2007-03-02 05:50:23 UTC (rev 1146)
@@ -17,16 +17,14 @@
<input type="text" name="PATH" value="" size="30">
<p> Recursive:
-<select name="RECURSIVE">
-<option value="FALSE">FALSE</option>
-<option value="TRUE">TRUE</option>
+<input type="text" name="RECURSIVE" value="0" size="1" ID="Text6">
</select>
-<p> Select:
-<select name="SELECT">
-<option value="FOLDERS">FOLDERS</option>
-<option value="FILES">FILES</option>
-<option value="BOTH">BOTH</option>
+<p> Type:
+<select name="TYPE">
+<option value="Folders">Folders</option>
+<option value="Files">Files</option>
+<option value="Both">Both</option>
</select>
<p> Filter:
Modified: trunk/MgDev/Web/src/HttpHandler/HttpEnumerateUnmanagedData.cpp
--- trunk/MgDev/Web/src/HttpHandler/HttpEnumerateUnmanagedData.cpp 2007-03-02 01:40:09 UTC (rev 1145)
+++ trunk/MgDev/Web/src/HttpHandler/HttpEnumerateUnmanagedData.cpp 2007-03-02 05:50:23 UTC (rev 1146)
@@ -41,11 +41,28 @@
// Get the recursive flag
STRING recursive = hrParam->GetParameterValue(MgHttpResourceStrings::reqRecursive);
- m_recursive = SZ_EQI(recursive.c_str(), L"TRUE");
- // Get select
- m_select = hrParam->GetParameterValue(MgHttpResourceStrings::reqSelect);
+ MG_HTTP_HANDLER_TRY()
+ if (recursive == L"1")
+ m_recursive = true;
+ else if (recursive == L"0" || recursive == L"")
+ m_recursive = false;
+ else
+ MgStringCollection arguments;
+ arguments.Add(MgHttpResourceStrings::reqRecursive);
+ arguments.Add(recursive);
+ throw new MgInvalidArgumentException(L"MgHttpEnumerateUnmanagedData.MgHttpEnumerateUnmanagedData",
+ __LINE__, __WFILE__, &arguments, L"MgInvalidValueOutsideRange", NULL);
+ MG_HTTP_HANDLER_CATCH_AND_THROW(L"MgHttpEnumerateUnmanagedData.MgHttpEnumerateUnmanagedData")
+ // Get type
+ m_type = hrParam->GetParameterValue(MgHttpResourceStrings::reqType);
// Get filter
m_filter = hrParam->GetParameterValue(MgHttpResourceStrings::reqFilter);
@@ -72,7 +89,7 @@
Ptr<MgResourceService> mgprService = (MgResourceService*)(CreateService(MgServiceType::ResourceService));
// call the C++ API
- Ptr<MgByteReader> byteReaderResult = mgprService->EnumerateUnmanagedData(m_path, m_recursive, m_select, m_filter);
+ Ptr<MgByteReader> byteReaderResult = mgprService->EnumerateUnmanagedData(m_path, m_recursive, m_type, m_filter);
hResult->SetResultObject(byteReaderResult, byteReaderResult->GetMimeType());
MG_HTTP_HANDLER_CATCH_AND_THROW_EX(L"MgHttpEnumerateUnmanagedData.Execute")
Modified: trunk/MgDev/Web/src/HttpHandler/HttpEnumerateUnmanagedData.h
--- trunk/MgDev/Web/src/HttpHandler/HttpEnumerateUnmanagedData.h 2007-03-02 01:40:09 UTC (rev 1145)
+++ trunk/MgDev/Web/src/HttpHandler/HttpEnumerateUnmanagedData.h 2007-03-02 05:50:23 UTC (rev 1146)
@@ -46,7 +46,7 @@
private:
STRING m_path;
bool m_recursive;
- STRING m_select;
+ STRING m_type;
STRING m_filter;
Modified: trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.cpp
--- trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.cpp 2007-03-02 01:40:09 UTC (rev 1145)
+++ trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.cpp 2007-03-02 05:50:23 UTC (rev 1146)
@@ -100,7 +100,6 @@
const STRING MgHttpResourceStrings::reqIncludeDescendants = L"INCLUDEDESCENDANTS";
const STRING MgHttpResourceStrings::reqPath = L"PATH";
const STRING MgHttpResourceStrings::reqRecursive = L"RECURSIVE";
-const STRING MgHttpResourceStrings::reqSelect = L"SELECT";
const STRING MgHttpResourceStrings::reqFilter = L"FILTER";
// Resource Service Operation Requests
Modified: trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.h
--- trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.h 2007-03-02 01:40:09 UTC (rev 1145)
+++ trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.h 2007-03-02 05:50:23 UTC (rev 1146)
@@ -104,7 +104,6 @@
static const STRING reqIncludeDescendants;
static const STRING reqPath;
static const STRING reqRecursive;
- static const STRING reqSelect;
static const STRING reqFilter;
// PREDEFINED FEATURE REQUEST PARAMETERS
More information about the mapguide-commits
