[mapguide-commits] r1149 - in trunk/MgDev/Common: Foundation/System
MapGuideCommon/Services
svn_mapguide at osgeo.org
Fri Mar 2 16:54:12 EST 2007
Author: brucedechant
Date: 2007-03-02 16:54:12 -0500 (Fri, 02 Mar 2007)
New Revision: 1149
trunk/MgDev/Common/Foundation/System/StreamParser.cpp
trunk/MgDev/Common/MapGuideCommon/Services/Command.cpp
Fix the server/web tier from throwing the TCP/IP protocol mismatch exception when it shouldn't be.
Modified: trunk/MgDev/Common/Foundation/System/StreamParser.cpp
--- trunk/MgDev/Common/Foundation/System/StreamParser.cpp 2007-03-02 19:52:32 UTC (rev 1148)
+++ trunk/MgDev/Common/Foundation/System/StreamParser.cpp 2007-03-02 21:54:12 UTC (rev 1149)
@@ -78,8 +78,12 @@
- if (ret == false || MgStreamParser::StreamVersion != pStreamData->GetVersion())
+ if (ret == false)
+ throw new MgInvalidStreamHeaderException(L"MgStreamParser.ParseStreamHeader", __LINE__, __WFILE__, NULL, L"", NULL);
+ else if (MgStreamParser::StreamVersion != pStreamData->GetVersion())
throw new MgStreamIoException(L"MgStreamParser.ParseStreamHeader", __LINE__, __WFILE__, NULL, L"MgInvalidTCPProtocol", NULL);
Modified: trunk/MgDev/Common/MapGuideCommon/Services/Command.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/Command.cpp 2007-03-02 19:52:32 UTC (rev 1148)
+++ trunk/MgDev/Common/MapGuideCommon/Services/Command.cpp 2007-03-02 21:54:12 UTC (rev 1149)
@@ -142,8 +142,12 @@
// Get the stream header i.e. stream_start, stream_data etc.
ptrStream->GetStreamHeader(msh);
- if (MgStreamParser::mshStreamStart != msh.m_streamStart || MgStreamParser::StreamVersion != msh.m_streamVersion)
+ if (MgStreamParser::mshStreamStart != msh.m_streamStart)
+ throw new MgInvalidStreamHeaderException(L"MgCommand.GetResponse", __LINE__, __WFILE__, NULL, L"", NULL);
+ else if (MgStreamParser::StreamVersion != msh.m_streamVersion)
throw new MgStreamIoException(L"MgCommand.GetResponse", __LINE__, __WFILE__, NULL, L"MgInvalidTCPProtocol", NULL);
More information about the mapguide-commits
