[mapguide-commits] r1218 - in trunk/MgDev: Common/Stylization Server/src/Services/Mapping Server/src/Services/Rendering
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Mar 14 07:23:34 EDT 2007
Author: waltweltonlair
Date: 2007-03-14 07:23:33 -0400 (Wed, 14 Mar 2007)
New Revision: 1218
   trunk/MgDev/Common/Stylization/DWFRenderer.cpp
   trunk/MgDev/Common/Stylization/DWFRenderer.h
   trunk/MgDev/Common/Stylization/GDRenderer.cpp
   trunk/MgDev/Common/Stylization/GDRenderer.h
   trunk/MgDev/Common/Stylization/KmlRenderer.cpp
   trunk/MgDev/Common/Stylization/KmlRenderer.h
   trunk/MgDev/Common/Stylization/LabelRenderer.cpp
   trunk/MgDev/Common/Stylization/LabelRendererLocal.cpp
   trunk/MgDev/Common/Stylization/Renderer.h
   trunk/MgDev/Server/src/Services/Mapping/SEMgSymbolManager.cpp
   trunk/MgDev/Server/src/Services/Rendering/FeatureInfoRenderer.h
Got rid of the UseLocalOverposting property on Renderer.  It's not needed.
Modified: trunk/MgDev/Common/Stylization/DWFRenderer.cpp
--- trunk/MgDev/Common/Stylization/DWFRenderer.cpp	2007-03-13 22:58:29 UTC (rev 1217)
+++ trunk/MgDev/Common/Stylization/DWFRenderer.cpp	2007-03-14 11:23:33 UTC (rev 1218)
@@ -1954,11 +1954,6 @@
     return true;
-bool DWFRenderer::UseLocalOverposting()
-    return false; // not applicable
 void DWFRenderer::EnsureBufferSize(int len)
     if (!m_wtPointBuffer)
Modified: trunk/MgDev/Common/Stylization/DWFRenderer.h
--- trunk/MgDev/Common/Stylization/DWFRenderer.h	2007-03-13 22:58:29 UTC (rev 1217)
+++ trunk/MgDev/Common/Stylization/DWFRenderer.h	2007-03-14 11:23:33 UTC (rev 1218)
@@ -111,7 +111,7 @@
                                               const RS_String& text, RS_TextDef& tdef);
     STYLIZATION_API virtual void ProcessLabelGroup( RS_LabelInfo*       labels,
-                                                    int                 nalabels,
+                                                    int                 nlabels,
                                                     RS_OverpostType     type,
                                                     bool                exclude,
@@ -143,8 +143,6 @@
     STYLIZATION_API virtual bool RequiresClipping();
-    STYLIZATION_API virtual bool UseLocalOverposting();
     STYLIZATION_API void StartLayout(RS_Bounds& extents);
     STYLIZATION_API void EndLayout();
Modified: trunk/MgDev/Common/Stylization/GDRenderer.cpp
--- trunk/MgDev/Common/Stylization/GDRenderer.cpp	2007-03-13 22:58:29 UTC (rev 1217)
+++ trunk/MgDev/Common/Stylization/GDRenderer.cpp	2007-03-14 11:23:33 UTC (rev 1218)
@@ -127,7 +127,6 @@
 m_layerInfo(NULL),
 m_fcInfo(NULL),
 m_bRequiresClipping(requiresClipping),
-m_bLocalOverposting(localOverposting),
 m_bIsSymbolW2D(false),
 m_bHaveViewport(false),
 m_imsym(NULL),
@@ -155,7 +154,7 @@
     if (bgColor.alpha() != 255)
         gdImageColorTransparent(img, bgc);
-    if (!m_bLocalOverposting)
+    if (!localOverposting)
         m_labeler = new LabelRenderer(this);
     else
         m_labeler = new LabelRendererLocal(this, tileExtentOffset);
@@ -1135,12 +1134,6 @@
-bool GDRenderer::UseLocalOverposting()
-    return m_bLocalOverposting;
 void GDRenderer::WritePolylines(LineBuffer* srclb, RS_LineStroke& stroke, bool aa)
     //apply the stroke first
Modified: trunk/MgDev/Common/Stylization/GDRenderer.h
--- trunk/MgDev/Common/Stylization/GDRenderer.h	2007-03-13 22:58:29 UTC (rev 1217)
+++ trunk/MgDev/Common/Stylization/GDRenderer.h	2007-03-14 11:23:33 UTC (rev 1218)
@@ -133,8 +133,6 @@
     // GDRenderer specific
@@ -223,7 +221,6 @@
     int m_height;
     double m_drawingScale;
     bool m_bRequiresClipping;
-    bool m_bLocalOverposting;
     RS_SymbolManager* m_symbolManager;
Modified: trunk/MgDev/Common/Stylization/KmlRenderer.cpp
--- trunk/MgDev/Common/Stylization/KmlRenderer.cpp	2007-03-13 22:58:29 UTC (rev 1217)
+++ trunk/MgDev/Common/Stylization/KmlRenderer.cpp	2007-03-14 11:23:33 UTC (rev 1218)
@@ -435,11 +435,6 @@
-bool KmlRenderer::UseLocalOverposting()
-    return false;
 //Inserts the contents of a given DWF input stream
 //into the current output W2D. The given coord sys
 //transformation is applied and geometry will be clipped
Modified: trunk/MgDev/Common/Stylization/KmlRenderer.h
--- trunk/MgDev/Common/Stylization/KmlRenderer.h	2007-03-13 22:58:29 UTC (rev 1217)
+++ trunk/MgDev/Common/Stylization/KmlRenderer.h	2007-03-14 11:23:33 UTC (rev 1218)
@@ -119,8 +119,6 @@
 private:
     // Unimplemented Constructors/Methods
Modified: trunk/MgDev/Common/Stylization/LabelRenderer.cpp
--- trunk/MgDev/Common/Stylization/LabelRenderer.cpp	2007-03-13 22:58:29 UTC (rev 1217)
+++ trunk/MgDev/Common/Stylization/LabelRenderer.cpp	2007-03-14 11:23:33 UTC (rev 1218)
@@ -77,6 +77,8 @@
     BeginOverpostGroup(type, true, exclude);
+    RS_FontEngine* fe = m_serenderer->GetFontEngine();
     // get the geometry type
     _ASSERT(path != NULL);
     int geomType = (path != NULL)? path->geom_type() : FdoGeometryType_None;
@@ -91,35 +93,9 @@
         // indicate that the current group will be labeled along the path
         m_labelGroups.back().m_algo = laCurve;
-        // If we are in tiled mode, we cannot stitch features which span
-        // more than one tile because labels will not be continuous across
-        // tiles -- i.e. computed label positions will be different since
-        // some features will not come in with the spatial query for some
-        // far away tiles, even though they should for labeling purposes.
-        // This does not affect stitching of multi-linestring features which
-        // we can always stitch without worrying about parts of them not
-        // coming in on some tiles.
+        // use the label string as the stitch key
         RS_String stitch_key = text;
-        if (false /*m_renderer->UseLocalOverposting()*/)  //LabelRenderer is not used in tiled mode so this is not needed
-            // TODO: stitch in subregions of tile
-//          const RS_Bounds& tileBounds = m_renderer->GetBounds();
-//          const RS_Bounds& featBounds = path->bounds();
-//          if (featBounds.minx < tileBounds.minx ||
-//              featBounds.maxx > tileBounds.maxx ||
-//              featBounds.miny < tileBounds.miny ||
-//              featBounds.maxy > tileBounds.maxy)
-                // If we don't want to stitch separate line features, mangle
-                // the stitch table key to make it unique across features, but
-                // keep it the same when we stitch the parts of a linestring.
-                wchar_t tmp[32];
-                swprintf(tmp, 32, L"%d", m_labelGroups.size());
-                stitch_key += tmp;
         // If it's a multi-linestring, we will add each separate linestring
         // piece for labeling.  Some of these will get stitched together
         // later, but if they are far away we will essentially label each
@@ -168,8 +144,6 @@
     else
-        RS_FontEngine* fe = m_serenderer->GetFontEngine();
         // case of a simple label
         for (int i=0; i<nlabels; i++)
@@ -195,12 +169,12 @@
                                       int              nlabels,
                                       bool             exclude,
-                                      LineBuffer*      path)
+                                      LineBuffer*      /*path*/)
     //Add a new style SE label to the overpost groups.
-    //here we are processing the simlpe case (like labels at a given points,
+    //Here we are processing the simple case (like labels at given points
     //rather than labels along a line). The hard case is //TODO
     m_labelGroups.back().m_algo = laSESymbol;
@@ -523,7 +497,7 @@
     if (render)
         m_serenderer->DrawSymbol(info.m_sestyle->symbol, m, angle);
 #ifdef DEBUG_LABELS
@@ -587,7 +561,7 @@
         double param_position = ((double)i + 0.5) / (double)numreps;
         //compute position and angle along the path for each character
-        bool success = fe->LayoutPathText(tm, info.m_pts, info.m_numpts, seglens, param_position, info.m_tdef.valign(), 0);
+        fe->LayoutPathText(tm, info.m_pts, info.m_numpts, seglens, param_position, info.m_tdef.valign(), 0);
         //once we have position and angle for each character
         //compute oriented bounding box for each character
Modified: trunk/MgDev/Common/Stylization/LabelRendererLocal.cpp
--- trunk/MgDev/Common/Stylization/LabelRendererLocal.cpp	2007-03-13 22:58:29 UTC (rev 1217)
+++ trunk/MgDev/Common/Stylization/LabelRendererLocal.cpp	2007-03-14 11:23:33 UTC (rev 1218)
@@ -87,7 +87,7 @@
+        // Since we're in tiled mode, we cannot stitch features which span
@@ -97,23 +97,20 @@
-        if (true /*m_renderer->UseLocalOverposting()*/) //Local label renderer is only used for tiled mode
+        // TODO: stitch in subregions of tile
+//      const RS_Bounds& tileBounds = m_renderer->GetBounds();
+//      const RS_Bounds& featBounds = path->bounds();
+//      if (featBounds.minx < tileBounds.minx ||
+//          featBounds.maxx > tileBounds.maxx ||
+//          featBounds.miny < tileBounds.miny ||
+//          featBounds.maxy > tileBounds.maxy)
-                wchar_t tmp[32];
+            // If we don't want to stitch separate line features, mangle
+            // the stitch table key to make it unique across features, but
+            // keep it the same when we stitch the parts of a linestring.
+            wchar_t tmp[32];
+            swprintf(tmp, 32, L"%d", m_labelGroups.size());
+            stitch_key += tmp;
@@ -309,6 +306,7 @@
                                            bool             exclude,
                                            LineBuffer*      path)
+    //TODO
@@ -747,8 +745,10 @@
 bool LabelRendererLocal::ComputeSimpleLabelBounds(LR_LabelInfoLocal& info)
     //match the font and measure the sizes of the characters
-    if (!m_serenderer->GetFontEngine()->GetTextMetrics(info.m_text, info.m_tdef, info.m_tm, false))
+    if (!fe->GetTextMetrics(info.m_text, info.m_tdef, info.m_tm, false))
         return false;
     //radian CCW rotation
@@ -886,7 +886,7 @@
-        bool ret = fe->LayoutPathText(copy_info.m_tm, info.m_pts, info.m_numpts, seglens, param_position, info.m_tdef.valign(), 0);
+        fe->LayoutPathText(copy_info.m_tm, info.m_pts, info.m_numpts, seglens, param_position, info.m_tdef.valign(), 0);
Modified: trunk/MgDev/Common/Stylization/Renderer.h
--- trunk/MgDev/Common/Stylization/Renderer.h	2007-03-13 22:58:29 UTC (rev 1217)
+++ trunk/MgDev/Common/Stylization/Renderer.h	2007-03-14 11:23:33 UTC (rev 1218)
@@ -36,114 +36,106 @@
 class Renderer
 public:
     ///<summary>
     /// Initializes the Renderer with mapping context information
     /// for generating a view of a map
     ///</summary>
-    virtual void StartMap  ( RS_MapUIInfo*    mapInfo,
-                             RS_Bounds&       extents,
-                             double           mapScale,
-                             double           dpi,
-                             double           metersPerUnit,
-                             CSysTransformer* xformToLL
-                           ) = 0;
+    virtual void StartMap(RS_MapUIInfo*    mapInfo,
+                          RS_Bounds&       extents,
+                          double           mapScale,
+                          double           dpi,
+                          double           metersPerUnit,
+                          CSysTransformer* xformToLL) = 0;
     ///<summary>
     /// Finalizes map generation. Typically the output for a map
     /// generation (DWF, JPEG, ...) will be ready after calling this function.
     ///</summary>
-    virtual void EndMap      () = 0;
+    virtual void EndMap() = 0;
     ///<summary>
     /// Indicates the renderer should process all subsequent geometry
     /// in a new graphical layer.
     ///</summary>
-    virtual void StartLayer     (RS_LayerUIInfo*      legendInfo,
-                                 RS_FeatureClassInfo* classInfo
-                                 ) = 0;
+    virtual void StartLayer(RS_LayerUIInfo*      legendInfo,
+                            RS_FeatureClassInfo* classInfo) = 0;
     ///<summary>
     /// Indicates all features for a layer are processed. At this point
     /// on overloading class can do post processing like creating
     /// EPlot resources from a layer's W2D file
     ///</summary>
-    virtual void EndLayer       () = 0;
+    virtual void EndLayer() = 0;
     ///<summary>
     /// as part of a single logical feature.
     ///</summary>
-    virtual void StartFeature (RS_FeatureReader* feature,
-                               const RS_String*  tooltip = NULL,
-                               const RS_String*  url = NULL,
-                               const RS_String* theme = NULL,
-                               double zOffset = 0,
-                               double zExtrusion = 0,
-                               RS_ElevationType zOffsetType = RS_ElevationType_RelativeToGround) = 0;
+    virtual void StartFeature(RS_FeatureReader* feature,
+                              const RS_String*  tooltip = NULL,
+                              const RS_String*  url = NULL,
+                              const RS_String*  theme = NULL,
+                              double zOffset = 0,
+                              double zExtrusion = 0,
+                              RS_ElevationType zOffsetType = RS_ElevationType_RelativeToGround) = 0;
     ///<summary>
     /// Done processing current feature.
     ///</summary>
     //TODO: is it needed -- next call to StartFeature can just imply
     //previous feature is done
-    //virtual void EndFeature     () = 0;
+    //virtual void EndFeature() = 0;
     ///<summary>
     /// Polygon features. Transformation to W2D space is done here. Also handles
     /// holes etc.
     ///</summary>
-    virtual void ProcessPolygon (LineBuffer*        lb,
-                                 RS_FillStyle&      fill
-                                 ) = 0;
+    virtual void ProcessPolygon(LineBuffer*     lb,
+                                RS_FillStyle&   fill) = 0;
     ///<summary>
     /// Polyline features. Transformation to W2D space is done here.
     ///</summary>
-    virtual void ProcessPolyline(LineBuffer*        lb,
-                                 RS_LineStroke&     lsym
-                                 ) = 0;
+    virtual void ProcessPolyline(LineBuffer*    lb,
+                                 RS_LineStroke& lsym) = 0;
     ///<summary>
     /// Raster serialization.
     ///</summary>
-    virtual void ProcessRaster  (unsigned char*     data,
-                                 int                length,
-                                 RS_ImageFormat     format,
-                                 int                width,
-                                 int                height,
-                                 RS_Bounds          extents
-                                 ) = 0;
+    virtual void ProcessRaster(unsigned char*   data,
+                               int              length,
+                               RS_ImageFormat   format,
+                               int              width,
+                               int              height,
+                               RS_Bounds        extents) = 0;
     ///<summary>
     /// Feature Marker Symbols -- added to feature W2D and should also
     /// support selection
     ///</summary>
-    virtual void ProcessMarker(LineBuffer*       lb,
-                               RS_MarkerDef&     mdef,
-                               bool              allowOverpost,
-                               RS_Bounds*        bounds = NULL
-                               ) = 0;
+    virtual void ProcessMarker(LineBuffer*      lb,
+                               RS_MarkerDef&    mdef,
+                               bool             allowOverpost,
+                               RS_Bounds*       bounds = NULL) = 0;
-    //TODO: DEPRECATED! Use PrcessLabelGroup() instead
+    //TODO: DEPRECATED! Use ProcessLabelGroup() instead
     ///<summary>
     /// Text labels
     ///</summary>
     virtual void ProcessLabel(double            x,
                               double            y,
-                              RS_TextDef&       tdef
-                              ) = 0;
+                              RS_TextDef&       tdef) = 0;
     ///<summary>
     /// Text label group --
     ///</summary>
-    virtual void ProcessLabelGroup( RS_LabelInfo*       labels,
-                                    int                 nlabels,
-                                    const RS_String&    text,
-                                    RS_OverpostType     type,
-                                    bool                exclude,
-                                    LineBuffer*         path
-                                  ) = 0;
+    virtual void ProcessLabelGroup(RS_LabelInfo*    labels,
+                                   int              nlabels,
+                                   const RS_String& text,
+                                   RS_OverpostType  type,
+                                   bool             exclude,
+                                   LineBuffer*      path) = 0;
     ///<summary>
     ///Inserts the contents of a given DWF input stream
@@ -155,8 +147,7 @@
                                CSysTransformer* xformer,
                                const RS_String& section,
                                const RS_String& passwd,
-                               const RS_String& w2dfilter
-                               ) = 0;
+                               const RS_String& w2dfilter) = 0;
     ///<summary>
     ///Provides an instance of an RS_Symbol manager which will be used
@@ -189,13 +180,6 @@
     virtual bool RequiresClipping() = 0;
-    // Local overposting label renderer option
-    virtual bool UseLocalOverposting() = 0;
 #endif
Modified: trunk/MgDev/Server/src/Services/Mapping/SEMgSymbolManager.cpp
--- trunk/MgDev/Server/src/Services/Mapping/SEMgSymbolManager.cpp	2007-03-13 22:58:29 UTC (rev 1217)
+++ trunk/MgDev/Server/src/Services/Mapping/SEMgSymbolManager.cpp	2007-03-14 11:23:33 UTC (rev 1218)
@@ -138,8 +138,8 @@
             INT64 len = sdReader->GetLength();
             if (len > 0 && len < 16*1024*1024) // draw the line at 16 MB
-                ret = new unsigned char[len];
                 length = (int)len;
+                ret = new unsigned char[length];
                 sdReader->Read(ret, length);
                 m_mImageCache[uniqueName] = ret;
Modified: trunk/MgDev/Server/src/Services/Rendering/FeatureInfoRenderer.h
--- trunk/MgDev/Server/src/Services/Rendering/FeatureInfoRenderer.h	2007-03-13 22:58:29 UTC (rev 1217)
+++ trunk/MgDev/Server/src/Services/Rendering/FeatureInfoRenderer.h	2007-03-14 11:23:33 UTC (rev 1218)
@@ -144,12 +144,6 @@
         return false;
-    // not applicable
-        return false;
     // SE_Renderer implementation
More information about the mapguide-commits mailing list
