[mapguide-commits] r1222 - trunk/MgDev/Common/Stylization
svn_mapguide at osgeo.org
Wed Mar 14 12:50:32 EDT 2007
Author: traianstanev
Date: 2007-03-14 12:50:32 -0400 (Wed, 14 Mar 2007)
New Revision: 1222
trunk/MgDev/Common/Stylization/SE_Renderer.cpp
trunk/MgDev/Common/Stylization/StylizationEngine.cpp
Workaround for some bugs in bounds union / convex hull computations. The bugs were causing crashes in a layer which tests simple highway shields by overlaying a text onto an image to make the shield symbol.
Modified: trunk/MgDev/Common/Stylization/SE_Renderer.cpp
--- trunk/MgDev/Common/Stylization/SE_Renderer.cpp 2007-03-14 16:42:43 UTC (rev 1221)
+++ trunk/MgDev/Common/Stylization/SE_Renderer.cpp 2007-03-14 16:50:32 UTC (rev 1222)
@@ -103,7 +103,8 @@
//single segment to the symbol repeat
double len = lb->points()[2] - lb->points()[0];
- if (fabs(len - style->repeat) < 0.001) //repeat must be within 1/100 of a pixel for us to assume solid line
+ if (fabs(len - style->repeat) < 0.001) //repeat must be within 1/1000 of a pixel for us to assume solid line
+ //this is only to avoid FP precision issues, in reality they would be exactly equal
//ok, it's only a solid line, just draw it and bail out of the
//layout function
Modified: trunk/MgDev/Common/Stylization/StylizationEngine.cpp
--- trunk/MgDev/Common/Stylization/StylizationEngine.cpp 2007-03-14 16:42:43 UTC (rev 1221)
+++ trunk/MgDev/Common/Stylization/StylizationEngine.cpp 2007-03-14 16:50:32 UTC (rev 1222)
@@ -463,7 +463,6 @@
rr->extent[1] = r->extent[1].evaluate(m_exec)*xform.y1;
rr->angle = r->angle.evaluate(m_exec) * M_PI180;
- rr->bounds = m_pool->NewBounds(5);
SE_Matrix rxf;
rxf.rotate(rr->angle);
rxf.translate(rr->position[0], rr->position[1]);
@@ -472,15 +471,17 @@
double h = 0.5 * rr->extent[1];
double sx, sy, x, y;
- rxf.transform(w, h, sx, sy); // upper right
- rr->bounds->Add(sx, sy);
- rxf.transform(w, -h, x, y); // lower right
- rr->bounds->Add(x, y);
- rxf.transform(-w, -h, x, y); // lower left
- rxf.transform(-w, h, x, y); // upper left
- rr->bounds->Add(sx, sy); // upper right
+ RS_F_Point pts[4];
+ rxf.transform( w, h, pts[0].x, pts[0].y);
+ rxf.transform( w, -h, pts[1].x, pts[1].y);
+ rxf.transform(-w, -h, pts[2].x, pts[2].y);
+ rxf.transform(-w, h, pts[3].x, pts[3].y);
+ std::sort((std::pair<double,double>*)pts, (std::pair<double,double>*)(pts + 3), PointLess( ));
+ rr->bounds = AndrewHull<std::pair<double,double>*,SimplePOINT>
+ ((std::pair<double,double>*)pts,
+ ((std::pair<double,double>*)(pts+3)) - 1,
+ 4, m_pool);
break;
More information about the mapguide-commits
