[mapguide-commits] r1293 - trunk/MgDev/Common/Stylization
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon Mar 19 16:25:03 EDT 2007
Author: waltweltonlair
Date: 2007-03-19 16:25:03 -0400 (Mon, 19 Mar 2007)
New Revision: 1293
   trunk/MgDev/Common/Stylization/GDRenderer.h
   trunk/MgDev/Common/Stylization/KmlRenderer.cpp
   trunk/MgDev/Common/Stylization/KmlRenderer.h
Removed KmlRenderer::GetMapToScreenScale.  It was implemented as a virtual
method along with the other Renderer methods, but Renderer doesn't have a
GetMapToScreenScale method.  GDRenderer had the same virtual method.  In
this case I left it, but made it non-virtual and moved the declaration to
the GDRenderer-specific section.
Modified: trunk/MgDev/Common/Stylization/GDRenderer.h
--- trunk/MgDev/Common/Stylization/GDRenderer.h	2007-03-19 20:16:52 UTC (rev 1292)
+++ trunk/MgDev/Common/Stylization/GDRenderer.h	2007-03-19 20:25:03 UTC (rev 1293)
@@ -62,7 +62,7 @@
     // Renderer implementation
     STYLIZATION_API virtual void StartMap(RS_MapUIInfo* mapInfo,
                                           RS_Bounds&    extents,
                                           double        mapScale,
@@ -85,27 +85,27 @@
                                               double zExtrusion = 0,
                                               RS_ElevationType zOffsetType = RS_ElevationType_RelativeToGround);
     STYLIZATION_API virtual void ProcessPolygon(LineBuffer* lb, RS_FillStyle& fill);
     STYLIZATION_API virtual void ProcessPolyline(LineBuffer* lb, RS_LineStroke& lsym);
     STYLIZATION_API virtual void ProcessRaster(unsigned char* data,
-                                               int length,
+                                               int            length,
                                                RS_ImageFormat format,
-                                               int width, int height,
-                                               RS_Bounds extents);
+                                               int            width,
+                                               int            height,
+                                               RS_Bounds      extents);
     STYLIZATION_API virtual void ProcessMarker(LineBuffer* lb, RS_MarkerDef& mdef, bool allowOverpost, RS_Bounds* bounds = NULL);
     STYLIZATION_API virtual void ProcessLabel(double x, double y, const RS_String& text, RS_TextDef& tdef);
-    STYLIZATION_API virtual void ProcessLabelGroup( RS_LabelInfo*    labels,
-                                                    int              nlabels,
-                                                    const RS_String& text,
-                                                    RS_OverpostType  type,
-                                                    bool             exclude,
-                                                    LineBuffer*      path);
+    STYLIZATION_API virtual void ProcessLabelGroup(RS_LabelInfo*    labels,
+                                                   int              nlabels,
+                                                   const RS_String& text,
+                                                   RS_OverpostType  type,
+                                                   bool             exclude,
+                                                   LineBuffer*      path);
     STYLIZATION_API virtual void AddDWFContent(RS_InputStream*  in,
                                                CSysTransformer* xformer,
@@ -123,19 +123,19 @@
     STYLIZATION_API virtual double GetMapScale();
+    STYLIZATION_API virtual double GetMetersPerUnit();
     STYLIZATION_API virtual RS_Bounds& GetBounds();
     STYLIZATION_API virtual double GetDpi();
-    STYLIZATION_API virtual double GetMetersPerUnit();
-    STYLIZATION_API virtual double GetMapToScreenScale();
     STYLIZATION_API virtual bool RequiresClipping();
     // GDRenderer specific
+    STYLIZATION_API double GetMapToScreenScale();
     STYLIZATION_API void Save(const RS_String& filename, const RS_String& format);
     STYLIZATION_API void Save(const RS_String& filename, const RS_String& format, int width, int height);
     STYLIZATION_API RS_ByteData* Save(const RS_String& format, int width, int height);
@@ -149,7 +149,7 @@
     virtual void DrawScreenPolyline(LineBuffer* geom, const SE_Matrix* xform, unsigned int color, double weight); // px
     virtual void DrawScreenPolygon(LineBuffer* geom, const SE_Matrix* xform, unsigned int fill);
-    virtual void DrawScreenRaster(unsigned char* data, int length, RS_ImageFormat format, int native_width, int native_height,
+    virtual void DrawScreenRaster(unsigned char* data, int length, RS_ImageFormat format, int native_width, int native_height,
         double x, double y, double w, double h, double angledeg);
     virtual void DrawScreenText(const RS_String& txt, RS_TextDef& tdef, double insx, double insy, double* path, int npts, double param_position);
@@ -162,8 +162,6 @@
     virtual RS_FontEngine* GetFontEngine();
-    //labeling -- this is the entry API for adding SE labels
-    //to the label mananger
     virtual void ProcessLabelGroup(SE_LabelInfo*    labels,
                                    int              nlabels,
Modified: trunk/MgDev/Common/Stylization/KmlRenderer.cpp
--- trunk/MgDev/Common/Stylization/KmlRenderer.cpp	2007-03-19 20:16:52 UTC (rev 1292)
+++ trunk/MgDev/Common/Stylization/KmlRenderer.cpp	2007-03-19 20:25:03 UTC (rev 1293)
@@ -430,12 +430,6 @@
-double KmlRenderer::GetMapToScreenScale()
-    return 0;
 bool KmlRenderer::RequiresClipping()
     return false;
Modified: trunk/MgDev/Common/Stylization/KmlRenderer.h
--- trunk/MgDev/Common/Stylization/KmlRenderer.h	2007-03-19 20:16:52 UTC (rev 1292)
+++ trunk/MgDev/Common/Stylization/KmlRenderer.h	2007-03-19 20:25:03 UTC (rev 1293)
@@ -108,14 +108,12 @@
 private:
More information about the mapguide-commits mailing list
