[mapguide-commits] r1297 - trunk/MgDev/Common/Stylization
svn_mapguide at osgeo.org
Tue Mar 20 11:08:09 EDT 2007
Author: traianstanev
Date: 2007-03-20 11:08:08 -0400 (Tue, 20 Mar 2007)
New Revision: 1297
trunk/MgDev/Common/Stylization/LabelRenderer.cpp
trunk/MgDev/Common/Stylization/LabelRendererLocal.cpp
trunk/MgDev/Common/Stylization/SE_PositioningAlgorithms.cpp
trunk/MgDev/Common/Stylization/SE_RenderProxies.h
trunk/MgDev/Common/Stylization/SE_Renderer.cpp
trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.cpp
Changed the way cached bounding boxes are stored in styles. Replaced the SE_Bounds object by an array of 4 points. Currently these hold axis aligned boxes, but in the future they should be changed to oriented boxes.
Modified: trunk/MgDev/Common/Stylization/LabelRenderer.cpp
--- trunk/MgDev/Common/Stylization/LabelRenderer.cpp 2007-03-20 14:04:18 UTC (rev 1296)
+++ trunk/MgDev/Common/Stylization/LabelRenderer.cpp 2007-03-20 15:08:08 UTC (rev 1297)
@@ -445,21 +445,10 @@
//This needs to be improved to handle text along a path
//get native symbol bounds (in pixels -- the render style is already scaled to pixels)
- SE_Bounds* b = info.m_sestyle->bounds;
- if (!b)
- return false;
- //now we will translate and orient the bounds with the given angle and position of the symbol
RS_F_Point fpts[4];
- fpts[0].x = b->min[0];
- fpts[0].y = b->min[1];
- fpts[1].x = b->max[0];
- fpts[1].y = b->min[1];
- fpts[2].x = b->max[0];
- fpts[2].y = b->max[1];
- fpts[3].x = b->min[0];
- fpts[3].y = b->max[1];
+ memcpy(fpts, info.m_sestyle->bounds, sizeof (fpts));
+ //now we will translate and orient the bounds with the given angle and position of the symbol
//apply position and rotation to the native bounds of the symbol
double angle = m_serenderer->GetFontEngine()->_Yup() ? info.m_tdef.rotation() : -info.m_tdef.rotation();
SE_Matrix m;
Modified: trunk/MgDev/Common/Stylization/LabelRendererLocal.cpp
--- trunk/MgDev/Common/Stylization/LabelRendererLocal.cpp 2007-03-20 14:04:18 UTC (rev 1296)
+++ trunk/MgDev/Common/Stylization/LabelRendererLocal.cpp 2007-03-20 15:08:08 UTC (rev 1297)
@@ -981,21 +981,10 @@
bool LabelRendererLocal::ComputeSELabelBounds(LR_LabelInfoLocal& info)
- if (!b)
- return false;
RS_F_Point fpts[4];
SE_Matrix m;
Modified: trunk/MgDev/Common/Stylization/SE_PositioningAlgorithms.cpp
--- trunk/MgDev/Common/Stylization/SE_PositioningAlgorithms.cpp 2007-03-20 14:04:18 UTC (rev 1296)
+++ trunk/MgDev/Common/Stylization/SE_PositioningAlgorithms.cpp 2007-03-20 15:08:08 UTC (rev 1297)
@@ -30,7 +30,7 @@
SE_RenderPointStyle* ret = new SE_RenderPointStyle();
*ret = *st;
- ret->bounds = st->bounds->Clone();
+ memcpy(ret->bounds, st->bounds, sizeof(ret->bounds));
SE_RenderText* txt = new SE_RenderText();
*txt = *((SE_RenderText*)st->symbol[0]);
ret->symbol[0] = txt;
@@ -80,15 +80,16 @@
- txt->bounds->min[0] = rotatedBounds.minx;
- txt->bounds->min[1] = rotatedBounds.miny;
- txt->bounds->max[0] = rotatedBounds.maxx;
- txt->bounds->max[1] = rotatedBounds.maxy;
+ txt->bounds[0].x = rotatedBounds.minx;
+ txt->bounds[0].y = rotatedBounds.miny;
+ txt->bounds[1].x = rotatedBounds.maxx;
+ txt->bounds[1].y = rotatedBounds.miny;
+ txt->bounds[2].x = rotatedBounds.maxx;
+ txt->bounds[2].y = rotatedBounds.maxy;
+ txt->bounds[3].x = rotatedBounds.minx;
+ txt->bounds[3].y = rotatedBounds.maxy;
- st->bounds->min[0] = rotatedBounds.minx;
- st->bounds->min[1] = rotatedBounds.miny;
- st->bounds->max[0] = rotatedBounds.maxx;
- st->bounds->max[1] = rotatedBounds.maxy;
+ memcpy(st->bounds, txt->bounds, sizeof(st->bounds));
@@ -120,7 +121,7 @@
rstyle2->checkExclusionRegions = rstyle->checkExclusionRegions;
rstyle2->drawLast = rstyle->drawLast;
rstyle2->renderPass = rstyle->renderPass;
- rstyle2->bounds = rstyle->bounds->Clone();
+ memcpy(rstyle2->bounds, rstyle->bounds, sizeof(rstyle2->bounds));
SE_RenderText* txt = NULL;
for (SE_RenderPrimitiveList::iterator iter = rstyle->symbol.begin(); iter != rstyle->symbol.end(); iter++)
Modified: trunk/MgDev/Common/Stylization/SE_RenderProxies.h
--- trunk/MgDev/Common/Stylization/SE_RenderProxies.h 2007-03-20 14:04:18 UTC (rev 1296)
+++ trunk/MgDev/Common/Stylization/SE_RenderProxies.h 2007-03-20 15:08:08 UTC (rev 1297)
@@ -50,7 +50,7 @@
SE_RenderPrimitiveType type;
bool resize;
- SE_Bounds* bounds;
+ RS_F_Point bounds[4];
@@ -113,9 +113,8 @@
: type(stype),
drawLast(false),
checkExclusionRegions(false),
- addToExclusionRegions(false),
- bounds(NULL)
+ addToExclusionRegions(false)
+ { memset (&bounds, 0, sizeof(bounds));}
~SE_RenderStyle()
@@ -132,13 +131,11 @@
default: throw; //means there is a bug
- if (bounds) bounds->Free();
SE_RenderStyleType type;
SE_RenderPrimitiveList symbol;
int renderPass;
Modified: trunk/MgDev/Common/Stylization/SE_Renderer.cpp
--- trunk/MgDev/Common/Stylization/SE_Renderer.cpp 2007-03-20 14:04:18 UTC (rev 1296)
+++ trunk/MgDev/Common/Stylization/SE_Renderer.cpp 2007-03-20 15:08:08 UTC (rev 1297)
@@ -23,7 +23,7 @@
using namespace MDFMODEL_NAMESPACE;
-//cloning of RenderSymbols. Unfortunate but nexessary for delay-drawing labels
+//cloning of RenderSymbols. Unfortunate but necessary for delay-drawing labels
static SE_RenderStyle* CloneRenderStyle(SE_RenderStyle* symbol)
SE_RenderStyle* ret = NULL;
@@ -74,7 +74,7 @@
//copy all the common properties
ret->addToExclusionRegions = symbol->addToExclusionRegions;
- ret->bounds = symbol->bounds->Clone();
+ memcpy(ret->bounds, symbol->bounds, sizeof (ret->bounds));
ret->checkExclusionRegions = symbol->checkExclusionRegions;
ret->drawLast = symbol->drawLast;
ret->renderPass = symbol->renderPass;
@@ -95,7 +95,7 @@
if (!rpc) rpc = new SE_RenderPolyline();
SE_RenderPolyline* drp = (SE_RenderPolyline*)rpc;
SE_RenderPolyline* srp = (SE_RenderPolyline*)rp;
- drp->bounds = srp->bounds->Clone();
+ memcpy(drp->bounds, srp->bounds, sizeof (drp->bounds));
drp->color = srp->color;
drp->resize = srp->resize;
drp->weight = srp->weight;
@@ -108,7 +108,7 @@
SE_RenderText* st = (SE_RenderText*)rp;
SE_RenderText* dt = (SE_RenderText*)rpc;
- dt->bounds = st->bounds->Clone();
+ memcpy(dt->bounds, st->bounds, sizeof (dt->bounds));
dt->position[0] = st->position[0];
dt->position[1] = st->position[1];
dt->resize = st->resize;
@@ -123,7 +123,7 @@
SE_RenderRaster* dr = (SE_RenderRaster*)rpc;
dr->angle = sr->angle;
- dr->bounds = sr->bounds->Clone();
+ memcpy(dr->bounds, sr->bounds, sizeof (dr->bounds));
dr->extent[0] = sr->extent[0];
dr->extent[1] = sr->extent[1];
dr->pngSize = sr->pngSize;
@@ -424,16 +424,8 @@
xform2.translate(xform.x2, xform.y2);
RS_F_Point* fpts = m_lastExclusionRegion;
+ memcpy(fpts, rstyle->bounds, 4 * sizeof(RS_F_Point));
- fpts[0].x = rstyle->bounds->min[0];
- fpts[0].y = rstyle->bounds->min[1];
- fpts[1].x = rstyle->bounds->max[0];
- fpts[1].y = rstyle->bounds->min[1];
- fpts[2].x = rstyle->bounds->max[0];
- fpts[2].y = rstyle->bounds->max[1];
- fpts[3].x = rstyle->bounds->min[0];
- fpts[3].y = rstyle->bounds->max[1];
for (int i=0; i<4; i++)
xform2.transform(fpts[i].x, fpts[i].y);
Modified: trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.cpp
--- trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.cpp 2007-03-20 14:04:18 UTC (rev 1296)
+++ trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.cpp 2007-03-20 15:08:08 UTC (rev 1297)
@@ -26,6 +26,63 @@
#include <algorithm>
#include <functional>
+//assumes axis aligned
+static void SetUndefinedBounds(RS_F_Point* pts)
+ pts[0].x = pts[3].x = DBL_MAX;
+ pts[1].x = pts[2].x = -DBL_MAX;
+ pts[0].y = pts[1].y = DBL_MAX;
+ pts[2].y = pts[3].y = -DBL_MAX;
+//assumes axis aligned bounds stored in src and dst
+static void BoundsUnion(RS_F_Point* dst, RS_F_Point* src)
+ dst[0].x = dst[3].x = rs_min(dst[0].x, src[0].x);
+ dst[1].x = dst[2].x = rs_max(dst[1].x, src[1].x);
+ dst[0].y = dst[1].y = rs_min(dst[0].y, src[0].y);
+ dst[2].y = dst[3].y = rs_max(dst[2].y, src[2].y);
+static void ComputeGrowAmount(RS_F_Point* bounds, double minx, double miny, double maxx, double maxy, double &growx, double &growy)
+ double sx, sy;
+ double cx = (minx + maxx)/2.0;
+ double cy = (miny + maxy)/2.0;
+ minx -= cx;
+ maxx -= cx;
+ miny -= cy;
+ maxy -= cy;
+ double xfminx, xfminy, xfmaxx, xfmaxy;
+ xfminx = bounds[0].x - cx;
+ xfminy = bounds[0].y - cy;
+ xfmaxx = bounds[2].x - cx;
+ xfmaxy = bounds[2].y - cy;
+ if (xfminx < minx) // minx always negative
+ sx = xfminx/minx - 1.0;
+ growx = (growx > sx) ? growx : sx;
+ if (xfmaxx > maxx) // maxx always positive
+ sx = xfmaxx/maxx - 1.0;
+ if (xfminy < miny)
+ sy = xfminy/miny - 1.0;
+ growy = (growy > sy) ? growy : sy;
+ if (xfmaxy > maxy)
+ sy = xfmaxy/maxy - 1.0;
SE_Style::~SE_Style()
for (SE_PrimitiveList::iterator iter = symbol.begin(); iter != symbol.end(); iter++)
@@ -49,10 +106,22 @@
if (!cxt->useBox)
ret->geometry->Transform(*cxt->xform, ret->weight);
- ret->bounds = ret->geometry->xf_bounds()->Clone();
+ SE_Bounds* seb = ret->geometry->xf_bounds();
+ //TODO: here we would implement rotating calipers algorithm to get
+ //a tighter oriented box, but for now we just get the axis aligned bounds of the path
+ ret->bounds[0].x = seb->min[0];
+ ret->bounds[0].y = seb->min[1];
+ ret->bounds[1].x = seb->max[0];
+ ret->bounds[1].y = seb->min[1];
+ ret->bounds[2].x = seb->max[0];
+ ret->bounds[2].y = seb->max[1];
+ ret->bounds[3].x = seb->min[0];
+ ret->bounds[3].y = seb->max[1];
else
- ret->bounds = NULL;
+ SetUndefinedBounds(ret->bounds);
return ret;
@@ -73,10 +142,22 @@
if (!cxt->useBox)
else
return ret;
@@ -143,23 +224,27 @@
txf.rotate(ret->tdef.rotation() * M_PI180);
txf.translate(ret->position[0], ret->position[1]);
- double* buffer = (double*)alloca(tm.line_pos.size()*sizeof(double)*8);
- double* ptr = buffer;
- for(size_t k = 0; k < tm.line_pos.size(); k++)
+ //compute axis aligned boudns of the text primitive
+ RS_F_Point fpts[4];
+ RS_Bounds xformBounds(+DBL_MAX, +DBL_MAX, -DBL_MAX, -DBL_MAX);
+ for (size_t k=0; k<tm.line_pos.size(); ++k)
- const RS_F_Point* pts = tm.line_pos[k].ext;
- txf.transform(pts[0].x, pts[0].y, ptr[0], ptr[1]);
- txf.transform(pts[1].x, pts[1].y, ptr[2], ptr[3]);
- txf.transform(pts[2].x, pts[2].y, ptr[4], ptr[5]);
- txf.transform(pts[3].x, pts[3].y, ptr[6], ptr[7]);
- ptr += 8;
+ //convert the unrotated measured bounds for the current line to a local point array
+ memcpy(fpts, tm.line_pos[k].ext, sizeof(fpts));
+ // process the extent points
+ for (int j=0; j<4; ++j)
+ txf.transform(fpts[j].x, fpts[j].y);
+ // update the overall rotated bounds
+ xformBounds.add_point(fpts[j]);
- std::sort((std::pair<double,double>*)buffer, (std::pair<double,double>*)(ptr - 2), PointLess( ));
- ret->bounds = AndrewHull<std::pair<double,double>*,SimplePOINT>
- ((std::pair<double,double>*)buffer,
- ((std::pair<double,double>*)ptr) - 1,
- (int)tm.line_pos.size()*4, cxt->pool);
+ //set the bounds into the returned primitive
+ xformBounds.get_points(ret->bounds);
return ret;
@@ -200,11 +285,7 @@
rxf.transform(-w, -h, pts[2].x, pts[2].y);
rxf.transform(-w, h, pts[3].x, pts[3].y);
- std::sort((std::pair<double,double>*)pts, (std::pair<double,double>*)(pts + 3), PointLess( ));
- ((std::pair<double,double>*)pts,
- ((std::pair<double,double>*)(pts+3)) - 1,
- 4, cxt->pool);
+ memcpy(ret->bounds, pts, sizeof(ret->bounds));
return ret;
@@ -255,14 +336,7 @@
if (!rsym->resize)
- if (rstyle->bounds)
- SE_Bounds* bounds = rstyle->bounds;
- rstyle->bounds = bounds->Union(rsym->bounds);
- bounds->Free();
- else
- rstyle->bounds = rsym->bounds->Clone();
+ BoundsUnion(rstyle->bounds, rsym->bounds);
rstyle->symbol.push_back(rsym);
@@ -270,8 +344,9 @@
if (useBox)
const wchar_t* sResizeCtrl = sym->resizeControl.evaluate(cxt->exec);
- if (sResizeCtrl && wcscmp(sResizeCtrl, L"AddToResizeBox") == 0)
- rsym->bounds->Contained(minx, miny, maxx, maxy, growx, growy);
+ if (wcscmp(sResizeCtrl, L"AddToResizeBox") == 0)
+ ComputeGrowAmount(rstyle->bounds, minx, miny, maxx, maxy, growx, growy);
@@ -322,7 +397,15 @@
SE_RenderPolyline* rp = (SE_RenderPolyline*)rsym;
rp->geometry->Transform(totalxf, rp->weight);
- rp->bounds = rp->geometry->xf_bounds()->Clone();
+ SE_Bounds* seb = rp->geometry->xf_bounds();
+ rp->bounds[0].x = seb->min[0];
+ rp->bounds[0].y = seb->min[1];
+ rp->bounds[1].x = seb->max[0];
+ rp->bounds[1].y = seb->min[1];
+ rp->bounds[2].x = seb->max[0];
+ rp->bounds[2].y = seb->max[1];
+ rp->bounds[3].x = seb->min[0];
+ rp->bounds[3].y = seb->max[1];
break;
case SE_RenderTextPrimitive:
@@ -330,7 +413,8 @@
SE_RenderText* rt = (SE_RenderText*)rsym;
growxf.transform(rt->position[0], rt->position[1]);
rt->tdef.font().height() *= growxf.y1;
- rt->bounds->Transform(growxf);
+ for (int j=0; j<4; j++)
+ growxf.transform(rt->bounds[j].x, rt->bounds[j].y);
break;
case SE_RenderRasterPrimitive:
@@ -339,19 +423,13 @@
growxf.transform(rr->position[0], rr->position[1]);
rr->extent[0] *= growxf.x0;
rr->extent[1] *= growxf.y1;
- rr->bounds->Transform(growxf);
+ growxf.transform(rr->bounds[j].x, rr->bounds[j].y);
break;
- bounds->Free();
- else
More information about the mapguide-commits
