[mapguide-commits] r1307 - in trunk/MgDev: Common/MapGuideCommon
Common/MapGuideCommon/Exception
Common/MapGuideCommon/Resources Common/MapGuideCommon/System
Server/src/Common/Manager Server/src/Core
Server/src/Services/Feature Server/src/UnitTesting
svn_mapguide at osgeo.org
Tue Mar 20 19:03:54 EDT 2007
Author: brucedechant
Date: 2007-03-20 19:03:07 -0400 (Tue, 20 Mar 2007)
New Revision: 1307
Added:
trunk/MgDev/Common/MapGuideCommon/Exception/UnsupportedProviderThreadModelException.cpp
trunk/MgDev/Common/MapGuideCommon/Exception/UnsupportedProviderThreadModelException.h
trunk/MgDev/Common/MapGuideCommon/Makefile.am
trunk/MgDev/Common/MapGuideCommon/MapGuideCommon.h
trunk/MgDev/Common/MapGuideCommon/MapGuideCommon.vcproj
trunk/MgDev/Common/MapGuideCommon/MapGuideCommonBuild.cpp
trunk/MgDev/Common/MapGuideCommon/Resources/mapguide_en.res
trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp
trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h
trunk/MgDev/Common/MapGuideCommon/System/MapGuideCommonClassId.h
trunk/MgDev/Common/MapGuideCommon/System/MapGuideCommonFactory.cpp
trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.cpp
trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.h
trunk/MgDev/Server/src/Core/Server.cpp
trunk/MgDev/Server/src/Core/serverconfig.ini
trunk/MgDev/Server/src/Services/Feature/ServerDescribeSchema.cpp
trunk/MgDev/Server/src/Services/Feature/ServerDescribeSchema.h
trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.cpp
trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.h
trunk/MgDev/Server/src/UnitTesting/TestFeatureService.cpp
Add improvements to the FDO connection pooling.
These improvements include:
1) Tweaking the caching for more performance
2) Adding a new server configuration property DataConnectionPoolSizeCustom that allows you to specify the exact # of connections to cache on a per provider basis. Providers will still cache the default # if not specified.
3) Enforced the supported FDO thread models the server can use.
Added: trunk/MgDev/Common/MapGuideCommon/Exception/UnsupportedProviderThreadModelException.cpp
--- trunk/MgDev/Common/MapGuideCommon/Exception/UnsupportedProviderThreadModelException.cpp (rev 0)
+++ trunk/MgDev/Common/MapGuideCommon/Exception/UnsupportedProviderThreadModelException.cpp 2007-03-20 23:03:07 UTC (rev 1307)
@@ -0,0 +1,40 @@
+// Copyright (C) 2004-2007 by Autodesk, Inc.
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of version 2.1 of the GNU Lesser
+// General Public License as published by the Free Software Foundation.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+#include "MapGuideCommon.h"
+IMPLEMENT_EXCEPTION_DEFAULTS(MgUnsupportedProviderThreadModelException, MgApplicationException)
+/// \brief
+/// Construct a MgUnsupportedProviderThreadModelException object.
+MgUnsupportedProviderThreadModelException::MgUnsupportedProviderThreadModelException(CREFSTRING methodName,
+ INT32 lineNumber, CREFSTRING fileName, MgStringCollection* whatArguments,
+ CREFSTRING whyMessageId, MgStringCollection* whyArguments) throw() :
+ MgApplicationException(methodName, lineNumber, fileName,
+ whatArguments, whyMessageId, whyArguments)
+/// \brief
+/// Destruct the object.
+MgUnsupportedProviderThreadModelException::~MgUnsupportedProviderThreadModelException() throw()
Property changes on: trunk/MgDev/Common/MapGuideCommon/Exception/UnsupportedProviderThreadModelException.cpp
___________________________________________________________________
+ native
Added: trunk/MgDev/Common/MapGuideCommon/Exception/UnsupportedProviderThreadModelException.h
--- trunk/MgDev/Common/MapGuideCommon/Exception/UnsupportedProviderThreadModelException.h (rev 0)
+++ trunk/MgDev/Common/MapGuideCommon/Exception/UnsupportedProviderThreadModelException.h 2007-03-20 23:03:07 UTC (rev 1307)
@@ -0,0 +1,69 @@
+#ifndef MG_UNSUPPORTED_PROVIDER_THREADMODEL_EXCEPTION_H_
+#define MG_UNSUPPORTED_PROVIDER_THREADMODEL_EXCEPTION_H_
+/// \ingroup Exceptions_Module
+/// \brief
+/// Thrown when the server does not support the FDO provider thread model.
+class MG_MAPGUIDE_API MgUnsupportedProviderThreadModelException : public MgApplicationException
+ DECLARE_CLASSNAME(MgUnsupportedProviderThreadModelException)
+EXTERNAL_API:
+ /// \brief
+ /// Construct a MgUnsupportedProviderThreadModelException object.
+ /// \param methodName
+ /// Name of the method where the exception occurred.
+ /// \param lineNumber
+ /// Line number where the exception occurred.
+ /// \param fileName
+ /// File name where the exception occurred.
+ /// \param whatArguments
+ /// Collection of arguments used to format the message that describes what the exception is.
+ /// \param whyMessageId
+ /// ID of the message that describes why the exception occurs.
+ /// \param whyArguments
+ /// Collection of arguments used to format the message that describes why the exception occurs.
+ MgUnsupportedProviderThreadModelException(CREFSTRING methodName, INT32 lineNumber,
+ CREFSTRING fileName, MgStringCollection* whatArguments,
+ CREFSTRING whyMessageId, MgStringCollection* whyArguments) throw();
+ /// \brief
+ /// Destructor for a MgUnsupportedProviderThreadModelException object.
+ virtual ~MgUnsupportedProviderThreadModelException() throw();
+INTERNAL_API:
+ DECLARE_EXCEPTION_DEFAULTS(MgUnsupportedProviderThreadModelException)
+CLASS_ID:
+ static const INT32 m_cls_id = MapGuide_Exception_MgUnsupportedProviderThreadModelException;
+#endif
Property changes on: trunk/MgDev/Common/MapGuideCommon/Exception/UnsupportedProviderThreadModelException.h
+ native
Modified: trunk/MgDev/Common/MapGuideCommon/Makefile.am
--- trunk/MgDev/Common/MapGuideCommon/Makefile.am 2007-03-20 21:06:33 UTC (rev 1306)
+++ trunk/MgDev/Common/MapGuideCommon/Makefile.am 2007-03-20 23:03:07 UTC (rev 1307)
@@ -63,6 +63,7 @@
Exception/SessionNotFoundException.cpp \
Exception/StylizeLayerFailedException.cpp \
Exception/UnauthorizedAccessException.cpp \
+ Exception/UnsupportedProviderThreadModelException.cpp \
Exception/UriFormatException.cpp \
MapLayer/Layer.cpp \
MapLayer/Map.cpp \
@@ -178,6 +179,7 @@
Exception/SessionNotFoundException.h \
Exception/StylizeLayerFailedException.h \
Exception/UnauthorizedAccessException.h \
+ Exception/UnsupportedProviderThreadModelException.h \
Exception/UriFormatException.h \
MapLayer/Layer.h \
MapLayer/Map.h \
Modified: trunk/MgDev/Common/MapGuideCommon/MapGuideCommon.h
--- trunk/MgDev/Common/MapGuideCommon/MapGuideCommon.h 2007-03-20 21:06:33 UTC (rev 1306)
+++ trunk/MgDev/Common/MapGuideCommon/MapGuideCommon.h 2007-03-20 23:03:07 UTC (rev 1307)
@@ -109,6 +109,7 @@
#include "Exception/SessionNotFoundException.h"
#include "Exception/StylizeLayerFailedException.h"
#include "Exception/UnauthorizedAccessException.h"
+#include "Exception/UnsupportedProviderThreadModelException.h"
#include "Exception/UriFormatException.h"
#include "Net/IOperationHandler.h"
Modified: trunk/MgDev/Common/MapGuideCommon/MapGuideCommon.vcproj
--- trunk/MgDev/Common/MapGuideCommon/MapGuideCommon.vcproj 2007-03-20 21:06:33 UTC (rev 1306)
+++ trunk/MgDev/Common/MapGuideCommon/MapGuideCommon.vcproj 2007-03-20 23:03:07 UTC (rev 1307)
@@ -1588,6 +1588,30 @@
</File>
<File
+ RelativePath=".\Exception\UnsupportedProviderThreadModelException.cpp"
+ <FileConfiguration
+ Name="Debug|Win32"
+ ExcludedFromBuild="true"
+ <Tool
+ Name="VCCLCompilerTool"
+ </FileConfiguration>
+ Name="Release|Win32"
+ <Tool
+ </File>
+ <File
+ RelativePath=".\Exception\UnsupportedProviderThreadModelException.h"
+ </File>
+ <File
RelativePath=".\Exception\UriFormatException.cpp"
<FileConfiguration
Modified: trunk/MgDev/Common/MapGuideCommon/MapGuideCommonBuild.cpp
--- trunk/MgDev/Common/MapGuideCommon/MapGuideCommonBuild.cpp 2007-03-20 21:06:33 UTC (rev 1306)
+++ trunk/MgDev/Common/MapGuideCommon/MapGuideCommonBuild.cpp 2007-03-20 23:03:07 UTC (rev 1307)
@@ -70,6 +70,7 @@
#include "Exception/SessionNotFoundException.cpp"
#include "Exception/StylizeLayerFailedException.cpp"
#include "Exception/UnauthorizedAccessException.cpp"
+#include "Exception/UnsupportedProviderThreadModelException.cpp"
#include "Exception/UriFormatException.cpp"
#include "MapLayer/Layer.cpp"
#include "MapLayer/Map.cpp"
Modified: trunk/MgDev/Common/MapGuideCommon/Resources/mapguide_en.res
--- trunk/MgDev/Common/MapGuideCommon/Resources/mapguide_en.res 2007-03-20 21:06:33 UTC (rev 1306)
+++ trunk/MgDev/Common/MapGuideCommon/Resources/mapguide_en.res 2007-03-20 23:03:07 UTC (rev 1307)
@@ -144,6 +144,7 @@
MgUnauthorizedAccessException = Unauthorized access.
MgUnclassifiedException = An unclassified exception occurred.
MgUnderflowException = Underflow exception.
+MgUnsupportedProviderThreadModelException = The FDO provider thread model is not supported.
MgUriFormatException = Uri format exception.
MgUserNotFoundException = The specified user was not found: %1
MgXmlException = An XML exception occurred.
Modified: trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp
--- trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp 2007-03-20 21:06:33 UTC (rev 1306)
+++ trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp 2007-03-20 23:03:07 UTC (rev 1307)
@@ -35,7 +35,7 @@
#define MG_CONFIG_MAX_CACHE_SIZE MG_CONFIG_MAX_INT32
#define MG_CONFIG_MIN_CONNECTION_POOL_SIZE 1
-#define MG_CONFIG_MAX_CONNECTION_POOL_SIZE 1024
+#define MG_CONFIG_MAX_CONNECTION_POOL_SIZE 100
#define MG_CONFIG_MIN_CONNECTIONS 1
#define MG_CONFIG_MAX_CONNECTIONS 1024
@@ -239,7 +239,9 @@
const STRING MgConfigProperties::FeatureServicePropertyDataConnectionPoolExcludedProviders = L"DataConnectionPoolExcludedProviders";
const STRING MgConfigProperties::DefaultFeatureServicePropertyDataConnectionPoolExcludedProviders = L""; // This means all providers are cached
const STRING MgConfigProperties::FeatureServicePropertyDataConnectionPoolSize = L"DataConnectionPoolSize";
-const INT32 MgConfigProperties::DefaultFeatureServicePropertyDataConnectionPoolSize = 100;
+const INT32 MgConfigProperties::DefaultFeatureServicePropertyDataConnectionPoolSize = 20;
+const STRING MgConfigProperties::FeatureServicePropertyDataConnectionPoolSizeCustom = L"DataConnectionPoolSizeCustom";
+const STRING MgConfigProperties::DefaultFeatureServicePropertyDataConnectionPoolSizeCustom = L"";
const STRING MgConfigProperties::FeatureServicePropertyDataConnectionTimeout = L"DataConnectionTimeout";
const INT32 MgConfigProperties::DefaultFeatureServicePropertyDataConnectionTimeout = 600;
const STRING MgConfigProperties::FeatureServicePropertyDataConnectionTimerInterval = L"DataConnectionTimerInterval";
@@ -523,6 +525,7 @@
{ MgConfigProperties::FeatureServicePropertyDataConnectionPoolEnabled , MgPropertyType::Boolean , 0 , 1 , L"" },
{ MgConfigProperties::FeatureServicePropertyDataConnectionPoolExcludedProviders , MgPropertyType::String , MG_CONFIG_MIN_FS_CP_EXCLUDED_LENGTH , MG_CONFIG_MAX_FS_CP_EXCLUDED_LENGTH , L"" },
{ MgConfigProperties::FeatureServicePropertyDataConnectionPoolSize , MgPropertyType::Int32 , MG_CONFIG_MIN_CONNECTION_POOL_SIZE , MG_CONFIG_MAX_CONNECTION_POOL_SIZE , L"" },
+ { MgConfigProperties::FeatureServicePropertyDataConnectionPoolSizeCustom , MgPropertyType::String , MG_CONFIG_MIN_FS_CP_EXCLUDED_LENGTH , MG_CONFIG_MAX_FS_CP_EXCLUDED_LENGTH , L"" },
{ MgConfigProperties::FeatureServicePropertyDataConnectionTimeout , MgPropertyType::Int32 , MG_CONFIG_MIN_TIMEOUT , MG_CONFIG_MAX_TIMEOUT , L"" },
{ MgConfigProperties::FeatureServicePropertyDataConnectionTimerInterval , MgPropertyType::Int32 , MG_CONFIG_MIN_TIMER_INTERVAL , MG_CONFIG_MAX_TIMER_INTERVAL , L"" },
{ MgConfigProperties::FeatureServicePropertyJoinQueryBatchSize , MgPropertyType::Int32 , MG_CONFIG_MIN_JOIN_QUERY_BATCH_SIZE , MG_CONFIG_MAX_JOIN_QUERY_BATCH_SIZE , L"" },
Modified: trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h
--- trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h 2007-03-20 21:06:33 UTC (rev 1306)
+++ trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h 2007-03-20 23:03:07 UTC (rev 1307)
@@ -285,8 +285,12 @@
/// Sets the number of pooled data connections
static const STRING FeatureServicePropertyDataConnectionPoolSize; /// value("DataConnectionPoolSize")
- static const INT32 DefaultFeatureServicePropertyDataConnectionPoolSize; /// value(100)
+ static const INT32 DefaultFeatureServicePropertyDataConnectionPoolSize; /// value(20)
+ /// Sets the number of pooled data connections for a specific provider
+ static const STRING FeatureServicePropertyDataConnectionPoolSizeCustom; /// value("DataConnectionPoolSizeCustom")
+ static const STRING DefaultFeatureServicePropertyDataConnectionPoolSizeCustom; /// value("")
/// Sets the maximum amount of time (in seconds) for data connection idle activity before the data connection is closed
static const STRING FeatureServicePropertyDataConnectionTimeout; /// value("DataConnectionTimeout")
static const INT32 DefaultFeatureServicePropertyDataConnectionTimeout; /// value(600)
Modified: trunk/MgDev/Common/MapGuideCommon/System/MapGuideCommonClassId.h
--- trunk/MgDev/Common/MapGuideCommon/System/MapGuideCommonClassId.h 2007-03-20 21:06:33 UTC (rev 1306)
+++ trunk/MgDev/Common/MapGuideCommon/System/MapGuideCommonClassId.h 2007-03-20 23:03:07 UTC (rev 1307)
@@ -85,6 +85,7 @@
#define MapGuide_Exception_MgUriFormatException MAPGUIDE_EXCEPTION_ID+50
#define MapGuide_Exception_MgStylizeLayerFailedException MAPGUIDE_EXCEPTION_ID+51
#define MapGuide_Exception_MgSessionNotFoundException MAPGUIDE_EXCEPTION_ID+52
+#define MapGuide_Exception_MgUnsupportedProviderThreadModelException MAPGUIDE_EXCEPTION_ID+53
// MapLayer API
Modified: trunk/MgDev/Common/MapGuideCommon/System/MapGuideCommonFactory.cpp
--- trunk/MgDev/Common/MapGuideCommon/System/MapGuideCommonFactory.cpp 2007-03-20 21:06:33 UTC (rev 1306)
+++ trunk/MgDev/Common/MapGuideCommon/System/MapGuideCommonFactory.cpp 2007-03-20 23:03:07 UTC (rev 1307)
@@ -86,6 +86,7 @@
EXCEPTION_CLASS_CREATOR(MgSessionExpiredException)
EXCEPTION_CLASS_CREATOR(MgSessionNotFoundException)
EXCEPTION_CLASS_CREATOR(MgUnauthorizedAccessException)
+ EXCEPTION_CLASS_CREATOR(MgUnsupportedProviderThreadModelException)
EXCEPTION_CLASS_CREATOR(MgUriFormatException)
fact->Register(MapGuide_MapLayer_Map, MgMap::CreateObject);
Modified: trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.cpp
--- trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.cpp 2007-03-20 21:06:33 UTC (rev 1306)
+++ trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.cpp 2007-03-20 23:03:07 UTC (rev 1307)
@@ -16,6 +16,7 @@
#include "FdoConnectionManager.h"
+#include "System/ConfigProperties.h"
#include "System/XmlDefs.h"
#include "System/XmlUtil.h"
#include "ServiceManager.h"
@@ -24,11 +25,11 @@
ACE_Recursive_Thread_Mutex MgFdoConnectionManager::sm_mutex;
-const INT32 MaxFdoConnectionPoolSize = 1000;
// Process-wide MgFdoConnectionManager
Ptr<MgFdoConnectionManager> MgFdoConnectionManager::sm_fdoConnectionManager = (MgFdoConnectionManager*)NULL;
+// Uncomment the next line to debug the FDO Connection Manager cache
+//#define _DEBUG_FDOCONNECTION_MANAGER
// Constructor
MgFdoConnectionManager::MgFdoConnectionManager(void)
@@ -48,6 +49,20 @@
ClearCache();
+ // Clear the provider information collection
+ ProviderInfoCollection::iterator iter = m_ProviderInfoCollection.begin();
+ while(m_ProviderInfoCollection.end() != iter)
+ ProviderInfo* providerInfo = iter->second;
+ if(providerInfo)
+ delete providerInfo;
+ providerInfo = NULL;
+ m_ProviderInfoCollection.erase(iter++);
FDO_SAFE_RELEASE(m_connManager);
MG_FDOCONNECTION_MANAGER_CATCH(L"MgFdoConnectionManager.~MgFdoConnectionManager")
@@ -91,19 +106,20 @@
/// </summary>
-void MgFdoConnectionManager::Initialize(bool bFdoConnectionPoolEnabled, INT32 nFdoConnectionPoolSize, INT32 nFdoConnectionTimeout, STRING excludedProviders)
+void MgFdoConnectionManager::Initialize(bool bFdoConnectionPoolEnabled, INT32 nFdoConnectionPoolSize, INT32 nFdoConnectionTimeout, STRING excludedProviders, STRING fdoConnectionPoolSizeCustom)
MG_FDOCONNECTION_MANAGER_TRY()
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("(%P|%t) MgFdoConnectionManager::Initialize()\n")));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("MgFdoConnectionManager::Initialize()\n")));
MG_LOG_TRACE_ENTRY(L"MgFdoConnectionManager::Initialize()");
m_connManager = FdoFeatureAccessManager::GetConnectionManager();
CHECKNULL(m_connManager, L"MgFdoConnectionManager.Initialize()");
- if((MaxFdoConnectionPoolSize < nFdoConnectionPoolSize) || (1 > nFdoConnectionPoolSize))
+ if((MgConfigProperties::DefaultFeatureServicePropertyDataConnectionPoolSize < nFdoConnectionPoolSize) ||
+ (1 > nFdoConnectionPoolSize))
- nFdoConnectionPoolSize = MaxFdoConnectionPoolSize;
+ nFdoConnectionPoolSize = MgConfigProperties::DefaultFeatureServicePropertyDataConnectionPoolSize;
m_bFdoConnectionPoolEnabled = bFdoConnectionPoolEnabled;
@@ -113,6 +129,37 @@
// Parse the comma delimited string into a string collection
m_excludedProviders = MgStringCollection::ParseCollection(excludedProviders, L",");
+ Ptr<MgStringCollection> fdoConnectionPoolSizeCustomCol = MgStringCollection::ParseCollection(fdoConnectionPoolSizeCustom, L",");
+ // Update the provider cache size collection
+ for(INT32 i=0;i<fdoConnectionPoolSizeCustomCol->GetCount();i++)
+ STRING customPoolSize = fdoConnectionPoolSizeCustomCol->GetItem(i);
+ STRING provider = customPoolSize;
+ INT32 nCustomPoolSize = nFdoConnectionPoolSize;
+ // Parse the format: provider:size
+ // Example: OSGeo.SDF:10
+ size_t position = customPoolSize.find(L":", 0); // NOXLATE
+ if(position != string::npos)
+ provider = customPoolSize.substr(0, position);
+ STRING value = customPoolSize.substr(position+1, customPoolSize.size());
+ nCustomPoolSize = MgUtil::StringToInt32(value);
+ ProviderInfo* providerInfo = new ProviderInfo();
+ if(providerInfo)
+ providerInfo->cacheSize = nCustomPoolSize;
+ providerInfo->threadModel = (FdoThreadCapability)-1; // Not set yet
+ m_ProviderInfoCollection.insert(ProviderInfoCacheEntry_Pair(provider, providerInfo));
MG_FDOCONNECTION_MANAGER_CATCH_AND_THROW(L"MgFdoConnectionManager.Initialize")
@@ -149,30 +196,51 @@
if(NULL == pFdoConnection)
- // Retrieve XML from repository
- string featureSourceXmlContent;
- RetrieveFeatureSource(resourceIdentifier, featureSourceXmlContent);
// Parse XML and get properties
- auto_ptr<MdfModel::FeatureSource> featureSource(GetFeatureSource(resourceIdentifier));
+ MdfModel::FeatureSource* featureSource = GetFeatureSource(resourceIdentifier);
- STRING providerName = (STRING)featureSource->GetProvider();
+ STRING provider = (STRING)featureSource->GetProvider();
STRING configDocumentName = (STRING)featureSource->GetConfigurationDocument();
STRING longTransactionName = (STRING)featureSource->GetLongTransaction();
- providerName = UpdateProviderName(providerName);
+ provider = UpdateProviderName(provider);
// Update the long transaction name to any active one for the current request
MgLongTransactionManager::GetLongTransactionName(resourceIdentifier, longTransactionName);
// Create a new connection and add it to the cache
- pFdoConnection = m_connManager->CreateConnection(providerName.c_str());
+ pFdoConnection = m_connManager->CreateConnection(provider.c_str());
+ // Check to see if we already have the capabilities for this provider
+ ProviderInfo* providerInfo = GetProviderInformation(provider);
+ if(providerInfo)
+ // Check if we have thread model
+ if((FdoThreadCapability)-1 == providerInfo->threadModel)
+ // Get the connection capabilities
+ FdoPtr<FdoIConnectionCapabilities> ficc = pFdoConnection->GetConnectionCapabilities();
+ // Get the thread model
+ FdoThreadCapability ftc = ficc->GetThreadCapability();
+ // Update the provider information collection
+ providerInfo->threadModel = ftc;
+ // The server only support FdoThreadCapability_PerConnectionThreaded or better connections
+ if(FdoThreadCapability_SingleThreaded == providerInfo->threadModel)
+ throw new MgUnsupportedProviderThreadModelException(L"MgFdoConnectionManager.Open",
+ __LINE__, __WFILE__, NULL, L"", NULL);
// Retrieve the properties and open the connection
- SetConnectionProperties(pFdoConnection, featureSource.get());
+ SetConnectionProperties(pFdoConnection, featureSource);
- SetConfiguration(providerName, pFdoConnection, resourceIdentifier, configDocumentName);
+ SetConfiguration(provider, pFdoConnection, resourceIdentifier, configDocumentName);
Open(pFdoConnection);
@@ -182,13 +250,14 @@
if(m_bFdoConnectionPoolEnabled)
// Check to see if this provider has been excluded from caching
- if(!IsExcludedProvider(providerName))
+ if(!IsExcludedProvider(provider))
- if(!FdoConnectionCacheFull())
+ if(!FdoConnectionCacheFull(provider))
// Add this entry to the cache
- CacheFdoConnection(pFdoConnection, resourceIdentifier->ToString(),
- featureSourceXmlContent,
+ CacheFdoConnection(pFdoConnection,
+ provider,
+ resourceIdentifier->ToString(),
@@ -201,7 +270,7 @@
-FdoIConnection* MgFdoConnectionManager::Open(CREFSTRING providerName, CREFSTRING connectionString)
+FdoIConnection* MgFdoConnectionManager::Open(CREFSTRING provider, CREFSTRING connectionString)
ACE_MT(ACE_GUARD_RETURN(ACE_Recursive_Thread_Mutex, ace_mon, sm_mutex, NULL));
@@ -215,7 +284,7 @@
// Empty connection string is allowed for ODBC provider to retrieve
// DataSources
- if (providerName.empty())
+ if (provider.empty())
MgStringCollection arguments;
arguments.Add(L"1");
@@ -225,18 +294,44 @@
__LINE__, __WFILE__, &arguments, L"MgStringEmpty", NULL);
- STRING providerNameNoVersion = UpdateProviderName(providerName);
+ STRING providerNoVersion = UpdateProviderName(provider);
// Search the cache for an FDO connection matching this provider/connection string
- pFdoConnection = FindFdoConnection(providerNameNoVersion, connectionString);
+ pFdoConnection = FindFdoConnection(providerNoVersion, connectionString);
- pFdoConnection = m_connManager->CreateConnection(providerNameNoVersion.c_str());
+ pFdoConnection = m_connManager->CreateConnection(providerNoVersion.c_str());
+ ProviderInfo* providerInfo = GetProviderInformation(providerNoVersion);
+ if(providerInfo)
// No connection string, no pooling and connection will remain in closed state
if (!connectionString.empty())
@@ -249,15 +344,13 @@
- if(!IsExcludedProvider(providerNameNoVersion))
+ if(!IsExcludedProvider(providerNoVersion))
+ if(!FdoConnectionCacheFull(providerNoVersion))
- STRING key = providerNameNoVersion + L" - " + connectionString;
- string data = "";
STRING ltName = L"";
- CacheFdoConnection(pFdoConnection, key, data, ltName);
+ CacheFdoConnection(pFdoConnection, providerNoVersion, connectionString, ltName);
@@ -293,60 +386,72 @@
ACE_Time_Value now = ACE_OS::gettimeofday();
- FdoConnectionCache::iterator iter = m_FdoConnectionCache.begin();
- while(m_FdoConnectionCache.end() != iter)
+ // Loop all of the FDO connection caches
+ FdoConnectionCacheCollection::iterator iterFdoConnectionCacheCollection = m_FdoConnectionCacheCollection.begin();
+ while(m_FdoConnectionCacheCollection.end() != iterFdoConnectionCacheCollection)
- FdoConnectionCacheEntry* pFdoConnectionCacheEntry = iter->second;
- if(pFdoConnectionCacheEntry)
+ FdoConnectionCache* fdoConnectionCache = iterFdoConnectionCacheCollection->second;
+ if(fdoConnectionCache)
- INT32 time = now.sec() - pFdoConnectionCacheEntry->lastUsed.sec();
- if(time > m_nFdoConnectionTimeout)
+ FdoConnectionCache::iterator iter = fdoConnectionCache->begin();
+ while(fdoConnectionCache->end() != iter)
- // Connection has expired so close it and remove it
- pFdoConnectionCacheEntry->pFdoConnection->Close();
+ FdoConnectionCacheEntry* pFdoConnectionCacheEntry = iter->second;
+ if(pFdoConnectionCacheEntry)
+ INT32 time = now.sec() - pFdoConnectionCacheEntry->lastUsed.sec();
+ if(time > m_nFdoConnectionTimeout)
+ // Connection has expired so close it and remove it
+ pFdoConnectionCacheEntry->pFdoConnection->Close();
- // Release any resource
- FDO_SAFE_RELEASE(pFdoConnectionCacheEntry->pFdoConnection);
+ // Release any resource
+ FDO_SAFE_RELEASE(pFdoConnectionCacheEntry->pFdoConnection);
- delete pFdoConnectionCacheEntry;
- pFdoConnectionCacheEntry = NULL;
+ delete pFdoConnectionCacheEntry;
+ pFdoConnectionCacheEntry = NULL;
- STRING cacheKey = iter->first;
+ STRING cacheKey = iter->first;
- // Remove any feature service cache entries for this resource
- MgServiceManager* serviceManager = MgServiceManager::GetInstance();
- assert(NULL != serviceManager);
+ // Remove any feature service cache entries for this resource
+ MgServiceManager* serviceManager = MgServiceManager::GetInstance();
+ assert(NULL != serviceManager);
- try
- Ptr<MgResourceIdentifier> resource = new MgResourceIdentifier(cacheKey);
- serviceManager->RemoveFeatureServiceCacheEntry(resource);
+ try
+ Ptr<MgResourceIdentifier> resource = new MgResourceIdentifier(cacheKey);
+ serviceManager->RemoveFeatureServiceCacheEntry(resource);
+ catch(MgInvalidRepositoryTypeException* e)
+ // If this exception is thrown then the key was not a resource identifier string
+ // and so there will be no entries in the feature service cache to remove.
+ SAFE_RELEASE(e);
+ fdoConnectionCache->erase(iter++);
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("MgFdoConnectionManager.RemoveExpiredConnections() - Found expired cached FDO connection.\n")));
+ else
+ // Check the next cached connection
+ iter++;
- catch(MgInvalidRepositoryTypeException* e)
+ else
- // If this exception is thrown then the key was not a resource identifier string
- // and so there will be no entries in the feature service cache to remove.
- SAFE_RELEASE(e);
+ // NULL Pointer
+ break;
- m_FdoConnectionCache.erase(iter++);
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("(%P|%t) MgFdoConnectionManager.RemoveExpiredConnections() - Found expired cached FDO connection.\n")));
- else
- // Check the next cached connection
- iter++;
- else
- // NULL Pointer
- break;
+ // Next FDO connection cache
+ iterFdoConnectionCacheCollection++;
MG_FDOCONNECTION_MANAGER_CATCH_AND_THROW(L"MgFdoConnectionManager.RemoveExpiredConnections")
@@ -359,10 +464,12 @@
+ // Parse feature source XML and get provider
// Get the active long transaction name for the current request
@@ -371,17 +478,15 @@
// No long transaction name cached for the current session or no current session
// In this case we want to use the requested long transaction of the feature source
- // Parse feature source XML and get long transaction
+ // Get long transaction
ltName = longTransactionName;
- pFdoConnection = SearchFdoConnectionCache(resourceIdentifier->ToString(),
+ pFdoConnection = SearchFdoConnectionCache(provider,
ltName);
MG_FDOCONNECTION_MANAGER_CATCH_AND_THROW(L"MgFdoConnectionManager.FindFdoConnection")
@@ -390,18 +495,16 @@
-FdoIConnection* MgFdoConnectionManager::FindFdoConnection(CREFSTRING providerName, CREFSTRING connectionString)
+FdoIConnection* MgFdoConnectionManager::FindFdoConnection(CREFSTRING provider, CREFSTRING connectionString)
FdoIConnection* pFdoConnection = NULL;
- string data = "";
- pFdoConnection = SearchFdoConnectionCache(key, data, ltName);
+ pFdoConnection = SearchFdoConnectionCache(providerNoVersion, connectionString, ltName);
@@ -409,7 +512,7 @@
-FdoIConnection* MgFdoConnectionManager::SearchFdoConnectionCache(CREFSTRING key, string& data, CREFSTRING ltName)
+FdoIConnection* MgFdoConnectionManager::SearchFdoConnectionCache(CREFSTRING provider, CREFSTRING key, CREFSTRING ltName)
@@ -417,46 +520,64 @@
- if(ACE_OS::strcasecmp(cacheKey.c_str(), key.c_str()) == 0)
+ STRING providerCached = iterFdoConnectionCacheCollection->first;
+ if(ACE_OS::strcasecmp(providerCached.c_str(), provider.c_str()) == 0)
- // We have a key match
- if(pFdoConnectionCacheEntry->data == data)
- // We have a data match
- if(pFdoConnectionCacheEntry->ltName == ltName)
+ if(ACE_OS::strcasecmp(cacheKey.c_str(), key.c_str()) == 0)
- // We have a long transaction name match
- if(pFdoConnectionCacheEntry->pFdoConnection->GetRefCount() == 1)
+ // We have a key match
- // It is not in use so claim it
- pFdoConnectionCacheEntry->lastUsed = ACE_OS::gettimeofday();
- if (FdoConnectionState_Closed == pFdoConnectionCacheEntry->pFdoConnection->GetConnectionState())
+ if(pFdoConnectionCacheEntry->ltName == ltName)
- pFdoConnectionCacheEntry->pFdoConnection->Open();
+ // We have a long transaction name match
+ if(pFdoConnectionCacheEntry->pFdoConnection->GetRefCount() == 1)
+ // It is not in use so claim it
+ pFdoConnectionCacheEntry->lastUsed = ACE_OS::gettimeofday();
+ if (FdoConnectionState_Closed == pFdoConnectionCacheEntry->pFdoConnection->GetConnectionState())
+ pFdoConnectionCacheEntry->pFdoConnection->Open();
+ pFdoConnection = FDO_SAFE_ADDREF(pFdoConnectionCacheEntry->pFdoConnection);
+ break;
- pFdoConnection = FDO_SAFE_ADDREF(pFdoConnectionCacheEntry->pFdoConnection);
- break;
+ iter++;
- iter++;
+ if(pFdoConnection)
+ // We found a connection
+ break;
MG_FDOCONNECTION_MANAGER_CATCH_AND_THROW(L"MgFdoConnectionManager.SearchFdoConnectionCache")
- #ifdef _DEBUG
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("SearchFdoConnectionCache:\nConnection: %@\nKey = %W\nData = %W\nVersion(LT) = %W\n\n"), (void*)pFdoConnection, key.c_str(), data.empty() ? L"(empty)" : L"(data)", ltName.empty() ? L"(empty)" : ltName.c_str()));
+ #ifdef _DEBUG_FDOCONNECTION_MANAGER
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("SearchFdoConnectionCache:\nConnection: %@\nKey = %W\nVersion(LT) = %W\n\n"), (void*)pFdoConnection, key.c_str(), ltName.empty() ? L"(empty)" : ltName.c_str()));
#endif
return pFdoConnection;
@@ -614,7 +735,6 @@
return ficc->SupportsConfiguration();
void MgFdoConnectionManager::RetrieveFeatureSource(MgResourceIdentifier* resource, string& resourceContent)
CHECKNULL(resource, L"MgFdoConnectionManager.RetrieveFeatureSource");
@@ -623,7 +743,6 @@
- FdoConnectionCacheEntry* pFdoConnectionCacheEntry = NULL;
resourceContent = "";
// Check to see if we have a valid resource
@@ -638,65 +757,32 @@
SAFE_RELEASE(e);
- if(bValidResource)
- STRING key = resource->ToString();
+ MgServiceManager* serviceMan = MgServiceManager::GetInstance();
+ assert(NULL != serviceMan);
+ // Get the service from service manager
+ Ptr<MgResourceService> resourceService = dynamic_cast<MgResourceService*>(
+ serviceMan->RequestService(MgServiceType::ResourceService));
+ assert(resourceService != NULL);
- pFdoConnectionCacheEntry = iter->second;
- resourceContent = pFdoConnectionCacheEntry->data;
- break;
+ // Get the feature source contents
+ Ptr<MgByteReader> byteReader = resourceService->GetResourceContent(resource, MgResourcePreProcessingType::Substitution);
- iter++;
+ Ptr<MgByteSink> byteSink = new MgByteSink((MgByteReader*)byteReader);
+ byteSink->ToStringUtf8(resourceContent);
- if(resourceContent.empty())
- MgServiceManager* serviceMan = MgServiceManager::GetInstance();
- assert(NULL != serviceMan);
+ ValidateFeatureSource(resourceContent);
- // Get the service from service manager
- Ptr<MgResourceService> resourceService = dynamic_cast<MgResourceService*>(
- serviceMan->RequestService(MgServiceType::ResourceService));
- assert(resourceService != NULL);
- // Get the feature source contents
- Ptr<MgByteReader> byteReader = resourceService->GetResourceContent(resource, MgResourcePreProcessingType::Substitution);
- Ptr<MgByteSink> byteSink = new MgByteSink((MgByteReader*)byteReader);
- byteSink->ToStringUtf8(resourceContent);
- ValidateFeatureSource(resourceContent);
- // Update the cache entry with the resource document now that we have it
- pFdoConnectionCacheEntry->data = resourceContent;
MG_FDOCONNECTION_MANAGER_CATCH_AND_THROW(L"MgFdoConnectionManager.RetrieveFeatureSource")
-void MgFdoConnectionManager::SetConfiguration(CREFSTRING providerName, FdoIConnection* pFdoConnection, MgResourceIdentifier* resourceIdentifier, STRING& configDataName)
+void MgFdoConnectionManager::SetConfiguration(CREFSTRING provider, FdoIConnection* pFdoConnection, MgResourceIdentifier* resourceIdentifier, STRING& configDataName)
CHECKNULL(resourceIdentifier, L"MgFdoConnectionManager.SetConfiguration");
CHECKNULL(pFdoConnection, L"MgFdoConnectionManager.SetConfiguration");
@@ -783,7 +869,6 @@
return supports;
void MgFdoConnectionManager::ValidateFeatureSource(string& featureSourceXmlContent)
bool isValidFeatureSource = true;
@@ -819,7 +904,6 @@
void MgFdoConnectionManager::Open(FdoIConnection* pFdoConnection)
try
@@ -860,18 +944,13 @@
- // Parse XML and get properties
// Get the supplementary spatial context information which defines the coordinate system
// for spatial contexts that are missing this information
spatialContextInfoMap = new MgSpatialContextInfoMap();
- GetSpatialContextInfoFromXml(featureSource.get(), spatialContextInfoMap);
+ GetSpatialContextInfoFromXml(featureSource, spatialContextInfoMap);
MG_FDOCONNECTION_MANAGER_CATCH_AND_THROW(L"MgFdoConnectionManager.GetSpatialContextInfo")
@@ -879,28 +958,28 @@
-STRING MgFdoConnectionManager::UpdateProviderName(CREFSTRING providerName)
+STRING MgFdoConnectionManager::UpdateProviderName(CREFSTRING provider)
- STRING providerNameNoVersion = providerName;
+ STRING providerNoVersion = provider;
// Remove the version from the provider name if it is found
// ie: OSGeo.SDF.3.0 = OSGeo.SDF
- STRING::size_type index = providerNameNoVersion.find(L".");
+ STRING::size_type index = providerNoVersion.find(L".");
if(STRING::npos != index)
index++;
// Found 1st ".", keep looking for second one
- index = providerNameNoVersion.find(L".", index);
+ index = providerNoVersion.find(L".", index);
// Found 2nd "."
// Update provider name to not include version
- providerNameNoVersion = providerNameNoVersion.substr(0, index);
+ providerNoVersion = providerNoVersion.substr(0, index);
- return providerNameNoVersion;
+ return providerNoVersion;
@@ -914,85 +993,97 @@
// Protect the cache
ACE_MT(ACE_GUARD_RETURN(ACE_Recursive_Thread_Mutex, ace_mon, sm_mutex, false));
- // We need to search the entire cache because FDO only supports a thread per connection.
- // Therefore, there could be more then 1 cached connection to the same FDO provider.
- connections++;
+ // We need to search the entire cache because FDO only supports a thread per connection.
+ // Therefore, there could be more then 1 cached connection to the same FDO provider.
- if(pFdoConnectionCacheEntry->pFdoConnection)
- INT32 refCount = pFdoConnectionCacheEntry->pFdoConnection->GetRefCount();
+ connections++;
- // We have a match, is it in use?
- if(1 == refCount)
- // Close the connection
+ if(pFdoConnectionCacheEntry->pFdoConnection)
+ INT32 refCount = pFdoConnectionCacheEntry->pFdoConnection->GetRefCount();
+ // We have a match, is it in use?
+ if(1 == refCount)
+ // Close the connection
- try
- Ptr<MgResourceIdentifier> resource = new MgResourceIdentifier(key);
+ try
+ Ptr<MgResourceIdentifier> resource = new MgResourceIdentifier(key);
+ SAFE_RELEASE(e);
+ connectionsRemoved++;
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("MgFdoConnectionManager.RemoveCachedFdoConnection() - Releasing cached FDO connection.\n")));
+ else
+ // The resource is still in use and so it cannot be removed
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("MgFdoConnectionManager.RemoveCachedFdoConnection() - FDO connection in use!\n")));
+ // Next cached FDO connection
+ iter++;
+ else
- SAFE_RELEASE(e);
+ // NULL pointer
+ break;
- connectionsRemoved++;
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("(%P|%t) MgFdoConnectionManager.RemoveCachedFdoConnection() - Releasing cached FDO connection.\n")));
else
- // The resource is still in use and so it cannot be removed
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("(%P|%t) MgFdoConnectionManager.RemoveCachedFdoConnection() - FDO connection in use!\n")));
- // Next cached FDO connection
- iter++;
+ // NULL pointer
+ break;
else
- // NULL pointer
- break;
+ iter++;
- else
- // NULL pointer
- break;
- else
- iter++;
MG_FDOCONNECTION_MANAGER_CATCH_AND_THROW(L"MgFdoConnectionManager.RemoveCachedFdoConnection")
@@ -1000,7 +1091,7 @@
return (connections == connectionsRemoved);
-void MgFdoConnectionManager::CacheFdoConnection(FdoIConnection* pFdoConnection, CREFSTRING key, string& data, CREFSTRING ltName)
+void MgFdoConnectionManager::CacheFdoConnection(FdoIConnection* pFdoConnection, CREFSTRING provider, CREFSTRING key, CREFSTRING ltName)
@@ -1011,17 +1102,50 @@
FdoConnectionCacheEntry* pFdoConnectionCacheEntry = new FdoConnectionCacheEntry;
- pFdoConnectionCacheEntry->data = data;
pFdoConnectionCacheEntry->ltName = ltName;
pFdoConnectionCacheEntry->pFdoConnection = pFdoConnection;
- #ifdef _DEBUG
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("CacheFdoConnection:\nConnection: %@\nKey = %W\nData = %W\nVersion(LT) = %W\n\n"), (void*)pFdoConnection, key.c_str(), data.empty() ? L"(empty)" : L"(data)", ltName.empty() ? L"(empty)" : ltName.c_str()));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("CacheFdoConnection:\nConnection: %@\nProvider = %W\nKey = %W\nVersion(LT) = %W\n\n"), (void*)pFdoConnection, provider.c_str(), key.c_str(), ltName.empty() ? L"(empty)" : ltName.c_str()));
#endif
- m_FdoConnectionCache.insert(FdoConnectionCache_Pair(key, pFdoConnectionCacheEntry));
+ bool bConnectionCached = false;
+ // Get the appropriate provider cache
+ fdoConnectionCache->insert(FdoConnectionCacheEntry_Pair(key, pFdoConnectionCacheEntry));
+ bConnectionCached = true;
+ break;
+ // Check to see if the entry was cached. An entry will not be cached above if
+ // the cache doesn't exist for the specified provider
+ if(!bConnectionCached)
+ // Create the FDO connection cache for the specified provider
+ FdoConnectionCache* fdoConnectionCache = new FdoConnectionCache();
+ m_FdoConnectionCacheCollection.insert(FdoConnectionCache_Pair(provider, fdoConnectionCache));
// Increase the reference count before returning it because this entry has been cached
FDO_SAFE_ADDREF(pFdoConnection);
@@ -1030,7 +1154,7 @@
-bool MgFdoConnectionManager::FdoConnectionCacheFull(void)
+bool MgFdoConnectionManager::FdoConnectionCacheFull(CREFSTRING provider)
bool bCacheFull = false;
@@ -1039,48 +1163,94 @@
ACE_MT(ACE_GUARD_RETURN(ACE_Recursive_Thread_Mutex, ace_mon, sm_mutex, true));
- if((INT32)m_FdoConnectionCache.size() >= m_nFdoConnectionPoolSize)
+ FdoConnectionCache* fdoConnectionCache = NULL;
+ INT32 fdoConnectionCacheSize = m_nFdoConnectionPoolSize; // Set to default
- // We are full, but are all entries in use?
- bCacheFull = true;
+ // Found the cache we are interested in
+ fdoConnectionCache = iterFdoConnectionCacheCollection->second;
+ break;
+ // Next cache entry
- // See if we can make room in the FDO connection cache by removing an unused connection
- if(bCacheFull)
+ // Loop all of the FDO connection caches size
+ ProviderInfoCollection::iterator iterProviderInfo = m_ProviderInfoCollection.begin();
+ while(m_ProviderInfoCollection.end() != iterProviderInfo)
+ STRING providerCached = iterProviderInfo->first;
+ ProviderInfo* providerInfo = iterProviderInfo->second;
+ if(providerInfo)
+ fdoConnectionCacheSize = providerInfo->cacheSize;
+ break;
+ iterProviderInfo++;
+ if((INT32)fdoConnectionCache->size() >= fdoConnectionCacheSize)
+ // We are full, but are all entries in use?
+ bCacheFull = true;
+ // See if we can make room in the FDO connection cache by removing an unused connection
+ if(bCacheFull)
- // Is it in use?
// Is it in use?
- if(1 == refCount)
+ // Is it in use?
+ if(1 == refCount)
- bCacheFull = false;
- break;
+ bCacheFull = false;
+ break;
+ else
+ // Next cached connection
+ iter++;
else
- // Next cached connection
- iter++;
+ // NULL pointer
+ break;
else
@@ -1089,11 +1259,6 @@
break;
- else
- // NULL pointer
- break;
@@ -1107,77 +1272,109 @@
ACE_MT(ACE_GUARD(ACE_Recursive_Thread_Mutex, ace_mon, sm_mutex));
-#ifdef _DEBUG
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("(%P|%t) MgFdoConnectionManager::ClearCache() - FDO cache BEFORE\n")));
+#ifdef _DEBUG_FDOCONNECTION_MANAGER
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("MgFdoConnectionManager::ClearCache() - FDO cache BEFORE\n")));
ShowCache();
#endif
- size_t cacheSize = m_FdoConnectionCache.size();
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("(%P|%t) MgFdoConnectionManager::ClearCache()\n")));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("(%P|%t) Releasing %d cached FDO connections.\n"), cacheSize));
+ size_t cacheCollectionSize = m_FdoConnectionCacheCollection.size();
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("MgFdoConnectionManager::ClearCache()\n")));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("FDO connection caches: %d.\n"), cacheCollectionSize));
- // Cleanup the FDO connection cache
- STRING key = iter->first;
+ // Cleanup the FDO connection cache
+ STRING provider = iterFdoConnectionCacheCollection->first;
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" %W - "), key.c_str()));
+ size_t cacheSize = fdoConnectionCache->size();
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("Releasing %d cached %W FDO connections.\n"), cacheSize, provider.c_str()));
- if(1 == refCount)
+ STRING key = iter->first;
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("Removed\n")));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" %W - "), key.c_str()));
- // The FDO cache is the only one with a reference
+ if(1 == refCount)
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("Removed\n")));
+ // The FDO cache is the only one with a reference
+ else
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("Still in use!!\n")));
+ iter++;
+ else
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("Removed (NULL connection)\n")));
+ // Remove NULL FDO connection entry
else
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("Still in use!!\n")));
- iter++;
+ // NULL pointer
+ break;
- else
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("Removed (NULL connection)\n")));
- // Remove NULL FDO connection entry
+ cacheSize = fdoConnectionCache->size();
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("%W FDO cached connections still in use %d.\n"), provider.c_str(), cacheSize));
+#endif
- else
- // NULL pointer
- break;
-#ifdef _DEBUG
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("(%P|%t) MgFdoConnectionManager::ClearCache() - FDO cache AFTER\n")));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("MgFdoConnectionManager::ClearCache() - FDO cache AFTER\n")));
ShowCache();
- cacheSize = m_FdoConnectionCache.size();
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("(%P|%t) FDO cached connections still in use %d.\n"), cacheSize));
#endif
+ // Clear the feature source cache
+ FeatureSourceCache::iterator iterFeatureSource = m_FeatureSourceCache.begin();
+ while(m_FeatureSourceCache.end() != iterFeatureSource)
+ MdfModel::FeatureSource* featureSource = iterFeatureSource->second;
+ if(featureSource)
+ delete featureSource;
+ m_FeatureSourceCache.erase(iterFeatureSource++);
@@ -1186,19 +1383,38 @@
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("(%P|%t) MgFdoConnectionManager::ShowCache()\n")));
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("(%P|%t) Cached FDO connections = %d\n"), cacheSize));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("MgFdoConnectionManager::ShowCache()\n")));
- // Show the contents of the FDO connection cache
- int nIndex = 1;
- for (FdoConnectionCache::iterator iter = m_FdoConnectionCache.begin();iter != m_FdoConnectionCache.end(); iter++)
+ // Show the contents of the FDO connection cache collection
+ INT32 nIndex = 1;
+ for (FdoConnectionCacheCollection::iterator iterCol = m_FdoConnectionCacheCollection.begin();iterCol != m_FdoConnectionCacheCollection.end(); iterCol++)
+ STRING provider = iterCol->first;
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("%2d) %W\n"), nIndex++, provider.c_str()));
+ FdoConnectionCache* fdoConnectionCache = iterCol->second;
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" %4d) %W\n"), nIndex++, key.c_str()));
+ INT32 entry = 1;
+ if(cacheSize > 0)
+ for (FdoConnectionCache::iterator iter = fdoConnectionCache->begin();iter != fdoConnectionCache->end(); iter++)
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" %2d) %W\n"), entry++, key.c_str()));
+ else
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" No cached entries.\n")));
@@ -1209,13 +1425,13 @@
#endif
-bool MgFdoConnectionManager::IsExcludedProvider(CREFSTRING providerName)
+bool MgFdoConnectionManager::IsExcludedProvider(CREFSTRING provider)
bool bResult = false;
if(m_excludedProviders.p)
- bResult = m_excludedProviders->Contains(providerName);
+ bResult = m_excludedProviders->Contains(provider);
return bResult;
@@ -1223,21 +1439,85 @@
MdfModel::FeatureSource* MgFdoConnectionManager::GetFeatureSource(MgResourceIdentifier* resId)
- RetrieveFeatureSource(resId, featureSourceXmlContent);
+ MdfModel::FeatureSource* featureSource = NULL;
- MdfParser::FSDSAX2Parser parser;
- parser.ParseString(featureSourceXmlContent.c_str(),
- (unsigned int)(featureSourceXmlContent.length()*sizeof(char)));
+ if (resId->GetRepositoryType().empty())
+ throw new MgInvalidRepositoryTypeException(
+ L"MgFdoConnectionManager.GetFeatureSource", __LINE__, __WFILE__, NULL, L"", NULL);
- assert(parser.GetSucceeded());
+ STRING resourceId = resId->ToString();
- // detach the feature source from the parser - it's
- // now the caller's responsibility to delete it
- MdfModel::FeatureSource* fs = parser.DetachFeatureSource();
+ FeatureSourceCache::iterator iter = m_FeatureSourceCache.begin();
+ while(m_FeatureSourceCache.end() != iter)
+ STRING resIdCached = iter->first;
+ if(ACE_OS::strcasecmp(resIdCached.c_str(), resourceId.c_str()) == 0)
+ featureSource = iter->second;
+ break;
- assert(fs != NULL);
- return fs;
+ // Next feature source
+ iter++;
+ if(NULL == featureSource)
+ // Retrieve XML from repository
+ string featureSourceXmlContent;
+ RetrieveFeatureSource(resId, featureSourceXmlContent);
+ MdfParser::FSDSAX2Parser parser;
+ parser.ParseString(featureSourceXmlContent.c_str(),
+ (unsigned int)(featureSourceXmlContent.length()*sizeof(char)));
+ assert(parser.GetSucceeded());
+ // detach the feature source from the parser - it's
+ // now the caller's responsibility to delete it
+ featureSource = parser.DetachFeatureSource();
+ // Store this feature source in the feature source cache
+ m_FeatureSourceCache.insert(FeatureSourceCacheEntry_Pair(resourceId, featureSource));
+ assert(featureSource != NULL);
+ return featureSource;
+ProviderInfo* MgFdoConnectionManager::GetProviderInformation(CREFSTRING provider)
+ ProviderInfo* providerInfo = NULL;
+ STRING providerCached = iter->first;
+ // Found it
+ providerInfo = iter->second;
+ break;
+ iter++;
+ if(NULL == providerInfo)
+ // Create new entry
+ providerInfo = new ProviderInfo();
+ if(providerInfo)
+ providerInfo->cacheSize = m_nFdoConnectionPoolSize;
+ return providerInfo;
Modified: trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.h
--- trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.h 2007-03-20 21:06:33 UTC (rev 1306)
+++ trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.h 2007-03-20 23:03:07 UTC (rev 1307)
@@ -38,18 +38,38 @@
#define MG_FDOCONNECTION_MANAGER_CATCH_AND_THROW(methodName) MG_FEATURE_SERVICE_CATCH_AND_THROW(methodName)
typedef struct {
- string data; // Feature source XML content
- STRING ltName; // current long transaction name for this connection
+ STRING ltName; // Current long transaction name for this connection
FdoIConnection* pFdoConnection;
ACE_Time_Value lastUsed;
} FdoConnectionCacheEntry;
+// Feature Source Cache
+typedef std::map<STRING, MdfModel::FeatureSource*> FeatureSourceCache;
+typedef std::pair<STRING, MdfModel::FeatureSource*> FeatureSourceCacheEntry_Pair;
+// FDO Connection Cache
typedef std::multimap<STRING, FdoConnectionCacheEntry*> FdoConnectionCache;
-typedef std::pair<STRING, FdoConnectionCacheEntry*> FdoConnectionCache_Pair;
+typedef std::pair<STRING, FdoConnectionCacheEntry*> FdoConnectionCacheEntry_Pair;
+// FDO Connection Cache Collection
+typedef std::map<STRING, FdoConnectionCache*> FdoConnectionCacheCollection;
+typedef std::pair<STRING, FdoConnectionCache*> FdoConnectionCache_Pair;
+// Spatial Context
typedef std::map<STRING, STRING> MgSpatialContextInfoMap;
typedef std::pair<STRING, STRING> MgSpatialContextInfoPair;
+typedef struct {
+ INT32 cacheSize;
+ FdoThreadCapability threadModel;
+} ProviderInfo;
+// Provider Information Collection
+typedef std::map<STRING, ProviderInfo*> ProviderInfoCollection;
+typedef std::pair<STRING, ProviderInfo*> ProviderInfoCacheEntry_Pair;
class MG_SERVER_MANAGER_API MgFdoConnectionManager : public MgGuardDisposable
DECLARE_CLASSNAME(MgFdoConnectionManager)
@@ -63,16 +83,16 @@
static MgFdoConnectionManager* GetInstance(void);
// This initializes the FDO connection manager
- void Initialize(bool bFdoConnectionPoolEnabled, INT32 nFdoConnectionPoolSize, INT32 nFdoConnectionTimeout, STRING excludedProviders);
+ void Initialize(bool bFdoConnectionPoolEnabled, INT32 nFdoConnectionPoolSize, INT32 nFdoConnectionTimeout, STRING excludedProviders, STRING fdoConnectionPoolSizeCustom);
static void Terminate();
void ClearCache();
FdoIConnection* Open(MgResourceIdentifier* resourceIdentifier);
- FdoIConnection* Open(CREFSTRING providerName, CREFSTRING connectionString);
+ FdoIConnection* Open(CREFSTRING provider, CREFSTRING connectionString);
void Close(FdoIConnection* pFdoConnection);
MgSpatialContextInfoMap* GetSpatialContextInfo(MgResourceIdentifier* resourceIdentifier);
- STRING UpdateProviderName(CREFSTRING providerName);
+ STRING UpdateProviderName(CREFSTRING provider);
void RetrieveFeatureSource(MgResourceIdentifier* resource, string& resourceContent);
@@ -90,14 +110,14 @@
MgFdoConnectionManager(void);
FdoIConnection* FindFdoConnection(MgResourceIdentifier* resourceIdentifier);
- FdoIConnection* FindFdoConnection(CREFSTRING providerName, CREFSTRING connectionString);
- FdoIConnection* SearchFdoConnectionCache(CREFSTRING key, string& data, CREFSTRING ltName);
- void CacheFdoConnection(FdoIConnection* pFdoConnection, CREFSTRING key, string& data, CREFSTRING ltName);
- bool FdoConnectionCacheFull(void);
+ FdoIConnection* FindFdoConnection(CREFSTRING provider, CREFSTRING connectionString);
+ FdoIConnection* SearchFdoConnectionCache(CREFSTRING provider, CREFSTRING key, CREFSTRING ltName);
+ void CacheFdoConnection(FdoIConnection* pFdoConnection, CREFSTRING provider, CREFSTRING key, CREFSTRING ltName);
+ bool FdoConnectionCacheFull(CREFSTRING provider);
void GetSpatialContextInfoFromXml(MdfModel::FeatureSource* pFeatureSource, MgSpatialContextInfoMap* spatialContextInfoMap);
- void SetConfiguration(CREFSTRING providerName, FdoIConnection* pFdoConnection, MgResourceIdentifier* resourceIdentifier, STRING& configDataName);
+ void SetConfiguration(CREFSTRING provider, FdoIConnection* pFdoConnection, MgResourceIdentifier* resourceIdentifier, STRING& configDataName);
void SetConnectionProperties(FdoIConnection* pFdoConnection, MgXmlUtil* pXmlUtil);
void SetConnectionProperties(FdoIConnection* pFdoConnection, MdfModel::FeatureSource* pFeatureSource);
@@ -109,13 +129,16 @@
void ValidateFeatureSource(string& featureSourceXmlContent);
void Open(FdoIConnection* pFdoConnection);
- bool IsExcludedProvider(CREFSTRING providerName);
+ bool IsExcludedProvider(CREFSTRING provider);
+ ProviderInfo* GetProviderInformation(CREFSTRING provider);
static Ptr<MgFdoConnectionManager> sm_fdoConnectionManager;
static ACE_Recursive_Thread_Mutex sm_mutex;
IConnectionManager* m_connManager;
- FdoConnectionCache m_FdoConnectionCache;
+ FdoConnectionCacheCollection m_FdoConnectionCacheCollection;
+ FeatureSourceCache m_FeatureSourceCache;
+ ProviderInfoCollection m_ProviderInfoCollection;
bool m_bFdoConnectionPoolEnabled;
INT32 m_nFdoConnectionPoolSize;
Modified: trunk/MgDev/Server/src/Core/Server.cpp
--- trunk/MgDev/Server/src/Core/Server.cpp 2007-03-20 21:06:33 UTC (rev 1306)
+++ trunk/MgDev/Server/src/Core/Server.cpp 2007-03-20 23:03:07 UTC (rev 1307)
@@ -852,10 +852,12 @@
bool bDataConnectionPoolEnabled = MgConfigProperties::DefaultFeatureServicePropertyDataConnectionPoolEnabled;
INT32 nDataConnectionPoolSize = MgConfigProperties::DefaultFeatureServicePropertyDataConnectionPoolSize;
STRING dataConnectionPoolExcludedProviders = MgConfigProperties::DefaultFeatureServicePropertyDataConnectionPoolExcludedProviders;
+ STRING dataConnectionPoolSizeCustom = MgConfigProperties::DefaultFeatureServicePropertyDataConnectionPoolSizeCustom;
pConfiguration->GetBoolValue(MgConfigProperties::FeatureServicePropertiesSection, MgConfigProperties::FeatureServicePropertyDataConnectionPoolEnabled, bDataConnectionPoolEnabled, MgConfigProperties::DefaultFeatureServicePropertyDataConnectionPoolEnabled);
pConfiguration->GetIntValue(MgConfigProperties::FeatureServicePropertiesSection, MgConfigProperties::FeatureServicePropertyDataConnectionPoolSize, nDataConnectionPoolSize, MgConfigProperties::DefaultFeatureServicePropertyDataConnectionPoolSize);
pConfiguration->GetStringValue(MgConfigProperties::FeatureServicePropertiesSection, MgConfigProperties::FeatureServicePropertyDataConnectionPoolExcludedProviders, dataConnectionPoolExcludedProviders, MgConfigProperties::DefaultFeatureServicePropertyDataConnectionPoolExcludedProviders);
+ pConfiguration->GetStringValue(MgConfigProperties::FeatureServicePropertiesSection, MgConfigProperties::FeatureServicePropertyDataConnectionPoolSizeCustom, dataConnectionPoolSizeCustom, MgConfigProperties::DefaultFeatureServicePropertyDataConnectionPoolSizeCustom);
// Add additional font mappings to the FontManager
ACE_DEBUG((LM_DEBUG, ACE_TEXT("(%P|%t) MgServer::open() - Adding Font Manager Mappings.\n")));
@@ -940,7 +942,7 @@
ACE_DEBUG ((LM_DEBUG, ACE_TEXT("(%P|%t) MgServer::open() - Initializing FDO Connection Manager.\n")));
MgEventTimer& dataConnectionTimer = m_eventTimerManager.GetEventTimer(MgEventTimer::DataConnectionTimeout);
MgFdoConnectionManager* pFdoConnectionManager = MgFdoConnectionManager::GetInstance();
- pFdoConnectionManager->Initialize(bDataConnectionPoolEnabled, nDataConnectionPoolSize, dataConnectionTimer.GetEventTimeout(), dataConnectionPoolExcludedProviders);
+ pFdoConnectionManager->Initialize(bDataConnectionPoolEnabled, nDataConnectionPoolSize, dataConnectionTimer.GetEventTimeout(), dataConnectionPoolExcludedProviders, dataConnectionPoolSizeCustom);
// Initialize the Feature Service Cache
INT32 cacheLimit;
@@ -999,6 +1001,7 @@
ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Data Connection Pool Enabled : %s\n"), bDataConnectionPoolEnabled == true ? ACE_TEXT("true") : ACE_TEXT("false")));
ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Data Connection Pool Excluded Providers: %s\n"), MG_WCHAR_TO_TCHAR(dataConnectionPoolExcludedProviders)));
ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Data Connection Pool Size : %d\n"), nDataConnectionPoolSize));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Data Connection Pool Size Custom : %s\n"), MG_WCHAR_TO_TCHAR(dataConnectionPoolSizeCustom)));
ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Data Connection Timeout : %d\n"), dataConnectionTimer.GetEventTimeout()));
ACE_DEBUG ((LM_DEBUG, ACE_TEXT(" Data Connection Timer Interval : %d\n"), dataConnectionTimer.GetInterval()));
ACE_DEBUG ((LM_DEBUG, ACE_TEXT("\n Mapping Service Properties:\n")));
Modified: trunk/MgDev/Server/src/Core/serverconfig.ini
--- trunk/MgDev/Server/src/Core/serverconfig.ini 2007-03-20 21:06:33 UTC (rev 1306)
+++ trunk/MgDev/Server/src/Core/serverconfig.ini 2007-03-20 23:03:07 UTC (rev 1307)
@@ -237,8 +237,11 @@
# connection pooling.
# Value = provider name(s) separated by ","
# Example: OSGeo.SDF,OSGeo.SHP
-# DataConnectionPoolSize # of connections to cache
+# DataConnectionPoolSize Default # of FDO connections to cache per provider
+# 0 < Value <= 100
+# DataConnectionPoolSizeCustom Custom # of FDO connections to cache for specified provider
# 0 < Value <= 1024
+# Example: OSGeo.SDF:10,OSGeo.SHP:10
# DataConnectionTimeout Time duration in seconds for when an idle
# connection is dropped
# 0 < Value <= 86400
@@ -255,6 +258,7 @@
DataConnectionPoolEnabled = 1
DataConnectionPoolExcludedProviders= OSGeo.SDF,OSGeo.SHP
+DataConnectionPoolSizeCustom =
DataConnectionTimerInterval = 60
JoinQueryBatchSize = 100
Modified: trunk/MgDev/Server/src/Services/Feature/ServerDescribeSchema.cpp
--- trunk/MgDev/Server/src/Services/Feature/ServerDescribeSchema.cpp 2007-03-20 21:06:33 UTC (rev 1306)
+++ trunk/MgDev/Server/src/Services/Feature/ServerDescribeSchema.cpp 2007-03-20 23:03:07 UTC (rev 1307)
@@ -35,11 +35,6 @@
MgServerDescribeSchema::~MgServerDescribeSchema()
- if (m_featureSource != NULL)
- delete m_featureSource;
- m_featureSource = NULL;
@@ -72,9 +67,10 @@
CHECKNULL((FdoFeatureSchemaCollection*)ffsc, L"MgServerDescribeSchema.ExecuteDescribeSchema");
// Finished with primary feature source, so now cycle through any secondary sources
- RetrieveFeatureSource(resource, featureSourceXmlContent);
+ if (m_featureSource == NULL)
+ m_featureSource = GetFeatureSource(resource);
CHECKNULL(m_featureSource, L"MgServerDescribeSchema.ExecuteDescribeSchema");
@@ -260,9 +256,10 @@
// A new MgClassDefinition needs to be created for each extension and added to the classCollection
CHECKNULL(m_featureSource, L"MgServerDescribeSchema.DescribeSchema");
@@ -1517,9 +1514,10 @@
if (!bHaveIdProps && classCnt > 0)
// Get the className for the primary source that is being extended
CHECKNULL(m_featureSource, L"MgServerDescribeSchema.GetIdentityProperties");
@@ -1581,25 +1579,6 @@
return idProps.Detach();
-void MgServerDescribeSchema::RetrieveFeatureSource(MgResourceIdentifier* resource, string& resourceContent)
- CHECKNULL(resource, L"MgServerDescribeSchema.RetrieveFeatureSource");
- resourceContent = "";
- // Get the feature source XML content document from the FDO connection manager.
- MgFdoConnectionManager* pFdoConnectionManager = MgFdoConnectionManager::GetInstance();
- if(pFdoConnectionManager)
- pFdoConnectionManager->RetrieveFeatureSource(resource, resourceContent);
- if (m_featureSource == NULL)
- m_featureSource = GetFeatureSource(resource);
MdfModel::FeatureSource* MgServerDescribeSchema::GetFeatureSource(MgResourceIdentifier* resource)
CHECKNULL(resource, L"MgServerDescribeSchema.GetFeatureSource");
Modified: trunk/MgDev/Server/src/Services/Feature/ServerDescribeSchema.h
--- trunk/MgDev/Server/src/Services/Feature/ServerDescribeSchema.h 2007-03-20 21:06:33 UTC (rev 1306)
+++ trunk/MgDev/Server/src/Services/Feature/ServerDescribeSchema.h 2007-03-20 23:03:07 UTC (rev 1307)
@@ -60,7 +60,6 @@
FdoFeatureSchemaCollection* ExecuteDescribeSchema(MgResourceIdentifier* resource, CREFSTRING schemaName);
STRING GetSerializedXml(FdoFeatureSchemaCollection* fdoSchemaCol);
- void RetrieveFeatureSource(MgResourceIdentifier* resource, string& resourceContent);
MdfModel::FeatureSource* GetFeatureSource(MgResourceIdentifier* resource);
MdfModel::FeatureSource* m_featureSource;
Modified: trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.cpp
--- trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.cpp 2007-03-20 21:06:33 UTC (rev 1306)
+++ trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.cpp 2007-03-20 23:03:07 UTC (rev 1307)
@@ -63,12 +63,6 @@
MgServerSelectFeatures::~MgServerSelectFeatures()
FDO_SAFE_RELEASE(m_customFunction);
// Executes the select features command and serializes the reader
@@ -85,9 +79,11 @@
// Validate parameters
ValidateParam(resource,className);
- // Retrieve the feature source XML document
+ // Retrieve the feature source
// Check if a feature join is to be performed by inspecting the resource for join properties
bool bFeatureJoinProperties = FindFeatureJoinProperties(resource, className);
@@ -1038,27 +1034,6 @@
return gwsFeatureReader.Detach();
-void MgServerSelectFeatures::RetrieveFeatureSource(MgResourceIdentifier* resource, string& resourceContent)
- CHECKNULL(resource, L"MgServerSelectFeatures.RetrieveFeatureSource");
void MgServerSelectFeatures::ParseQualifiedClassName(CREFSTRING qualifiedClassName, STRING& schemaName, STRING& className)
STRING::size_type nIndex = qualifiedClassName.rfind(CLASSNAME_QUALIFIER);
Modified: trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.h
--- trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.h 2007-03-20 21:06:33 UTC (rev 1306)
+++ trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.h 2007-03-20 23:03:07 UTC (rev 1307)
@@ -81,7 +81,6 @@
// Methods for Feature Join
bool FindFeatureJoinProperties(MgResourceIdentifier* resourceId, CREFSTRING extensionName);
MgServerGwsFeatureReader* JoinFeatures(MgResourceIdentifier* featureSourceId, CREFSTRING extensionName, FdoFilter* filter);
void ParseQualifiedClassName(CREFSTRING qualifiedClassName, STRING& schemaName, STRING& className);
MgResourceIdentifier* GetSecondaryResourceIdentifier(MgResourceIdentifier* primResId, CREFSTRING extensionName, CREFSTRING relationName);
Modified: trunk/MgDev/Server/src/UnitTesting/TestFeatureService.cpp
--- trunk/MgDev/Server/src/UnitTesting/TestFeatureService.cpp 2007-03-20 21:06:33 UTC (rev 1306)
+++ trunk/MgDev/Server/src/UnitTesting/TestFeatureService.cpp 2007-03-20 23:03:07 UTC (rev 1307)
@@ -368,7 +368,7 @@
pManager->Close(pFdoConnection2);
// Force removal from the FDO connection cache
- STRING key = provider + L" - " + connectionString;
+ STRING key = connectionString;
pManager->RemoveCachedFdoConnection(key);
catch(MgException* e)
More information about the mapguide-commits
