[mapguide-commits] r1310 - trunk/MgDev/Server/src/Common/Manager
svn_mapguide at osgeo.org
Tue Mar 20 21:25:34 EDT 2007
Author: waltweltonlair
Date: 2007-03-20 21:25:29 -0400 (Tue, 20 Mar 2007)
New Revision: 1310
trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.cpp
Fix server startup crash due to missing null pointer check
Modified: trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.cpp
--- trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.cpp 2007-03-21 00:50:25 UTC (rev 1309)
+++ trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.cpp 2007-03-21 01:25:29 UTC (rev 1310)
@@ -132,31 +132,34 @@
Ptr<MgStringCollection> fdoConnectionPoolSizeCustomCol = MgStringCollection::ParseCollection(fdoConnectionPoolSizeCustom, L",");
// Update the provider cache size collection
- for(INT32 i=0;i<fdoConnectionPoolSizeCustomCol->GetCount();i++)
+ if (fdoConnectionPoolSizeCustomCol)
- STRING customPoolSize = fdoConnectionPoolSizeCustomCol->GetItem(i);
+ for(INT32 i=0;i<fdoConnectionPoolSizeCustomCol->GetCount();i++)
+ STRING customPoolSize = fdoConnectionPoolSizeCustomCol->GetItem(i);
- STRING provider = customPoolSize;
- INT32 nCustomPoolSize = nFdoConnectionPoolSize;
+ STRING provider = customPoolSize;
+ INT32 nCustomPoolSize = nFdoConnectionPoolSize;
- // Parse the format: provider:size
- // Example: OSGeo.SDF:10
+ // Parse the format: provider:size
+ // Example: OSGeo.SDF:10
- size_t position = customPoolSize.find(L":", 0); // NOXLATE
- if(position != string::npos)
- provider = customPoolSize.substr(0, position);
- STRING value = customPoolSize.substr(position+1, customPoolSize.size());
- nCustomPoolSize = MgUtil::StringToInt32(value);
+ size_t position = customPoolSize.find(L":", 0); // NOXLATE
+ if(position != string::npos)
+ provider = customPoolSize.substr(0, position);
+ STRING value = customPoolSize.substr(position+1, customPoolSize.size());
+ nCustomPoolSize = MgUtil::StringToInt32(value);
- ProviderInfo* providerInfo = new ProviderInfo();
- if(providerInfo)
- providerInfo->cacheSize = nCustomPoolSize;
- providerInfo->threadModel = (FdoThreadCapability)-1; // Not set yet
+ ProviderInfo* providerInfo = new ProviderInfo();
+ if(providerInfo)
+ providerInfo->cacheSize = nCustomPoolSize;
+ providerInfo->threadModel = (FdoThreadCapability)-1; // Not set yet
- m_ProviderInfoCollection.insert(ProviderInfoCacheEntry_Pair(provider, providerInfo));
+ m_ProviderInfoCollection.insert(ProviderInfoCacheEntry_Pair(provider, providerInfo));
More information about the mapguide-commits
