[mapguide-commits] r1318 - in trunk/MgDev/Server/src: Common/Manager UnitTesting
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Mar 21 15:08:00 EDT 2007
Author: brucedechant
Date: 2007-03-21 15:08:00 -0400 (Wed, 21 Mar 2007)
New Revision: 1318
   trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.cpp
   trunk/MgDev/Server/src/UnitTesting/TestFeatureService.cpp
Performance tweaks to FDO Connection Manager.
Modified: trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.cpp
--- trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.cpp	2007-03-21 16:57:39 UTC (rev 1317)
+++ trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.cpp	2007-03-21 19:08:00 UTC (rev 1318)
@@ -524,57 +524,40 @@
     MG_FDOCONNECTION_MANAGER_TRY()
     // Loop all of the FDO connection caches
-    FdoConnectionCacheCollection::iterator iterFdoConnectionCacheCollection = m_FdoConnectionCacheCollection.begin();
-    while(m_FdoConnectionCacheCollection.end() != iterFdoConnectionCacheCollection)
+    FdoConnectionCacheCollection::iterator iterFdoConnectionCacheCollection = m_FdoConnectionCacheCollection.find(provider);
+    if(m_FdoConnectionCacheCollection.end() != iterFdoConnectionCacheCollection)
-        STRING providerCached = iterFdoConnectionCacheCollection->first;
-        if(ACE_OS::strcasecmp(providerCached.c_str(), provider.c_str()) == 0)
+        FdoConnectionCache* fdoConnectionCache = iterFdoConnectionCacheCollection->second;
+        if(fdoConnectionCache)
-            FdoConnectionCache* fdoConnectionCache = iterFdoConnectionCacheCollection->second;
-            if(fdoConnectionCache)
+            FdoConnectionCache::iterator iter = fdoConnectionCache->find(key);
+            while(fdoConnectionCache->end() != iter)
-                FdoConnectionCache::iterator iter = fdoConnectionCache->begin();
-                while(fdoConnectionCache->end() != iter)
+                // We have a key match
+                FdoConnectionCacheEntry* pFdoConnectionCacheEntry = iter->second;
+                if(pFdoConnectionCacheEntry)
-                    STRING cacheKey = iter->first;
-                    if(ACE_OS::strcasecmp(cacheKey.c_str(), key.c_str()) == 0)
+                    if(pFdoConnectionCacheEntry->ltName == ltName)
-                        // We have a key match
-                        FdoConnectionCacheEntry* pFdoConnectionCacheEntry = iter->second;
-                        if(pFdoConnectionCacheEntry)
+                        // We have a long transaction name match
+                        if(pFdoConnectionCacheEntry->pFdoConnection->GetRefCount() == 1)
-                            if(pFdoConnectionCacheEntry->ltName == ltName)
+                            // It is not in use so claim it
+                            pFdoConnectionCacheEntry->lastUsed = ACE_OS::gettimeofday();
+                            if (FdoConnectionState_Closed == pFdoConnectionCacheEntry->pFdoConnection->GetConnectionState())
-                                // We have a long transaction name match
-                                if(pFdoConnectionCacheEntry->pFdoConnection->GetRefCount() == 1)
-                                    // It is not in use so claim it
-                                    pFdoConnectionCacheEntry->lastUsed = ACE_OS::gettimeofday();
-                                    if (FdoConnectionState_Closed == pFdoConnectionCacheEntry->pFdoConnection->GetConnectionState())
-                                        pFdoConnectionCacheEntry->pFdoConnection->Open();
-                                    pFdoConnection = FDO_SAFE_ADDREF(pFdoConnectionCacheEntry->pFdoConnection);
-                                    break;
+                                pFdoConnectionCacheEntry->pFdoConnection->Open();
+                            pFdoConnection = FDO_SAFE_ADDREF(pFdoConnectionCacheEntry->pFdoConnection);
+                            break;
-                    iter++;
+                // Next match
+                iter++;
-        if(pFdoConnection)
-            // We found a connection
-            break;
-        // Next FDO connection cache
-        iterFdoConnectionCacheCollection++;
     MG_FDOCONNECTION_MANAGER_CATCH_AND_THROW(L"MgFdoConnectionManager.SearchFdoConnectionCache")
@@ -1003,72 +986,63 @@
             // We need to search the entire cache because FDO only supports a thread per connection.
             // Therefore, there could be more then 1 cached connection to the same FDO provider.
-                    connections++;
+                connections++;
+                    if(pFdoConnectionCacheEntry->pFdoConnection)
-                        if(pFdoConnectionCacheEntry->pFdoConnection)
+                        INT32 refCount = pFdoConnectionCacheEntry->pFdoConnection->GetRefCount();
+                        // We have a match, is it in use?
+                        if(1 == refCount)
-                            INT32 refCount = pFdoConnectionCacheEntry->pFdoConnection->GetRefCount();
+                            // Close the connection
+                            pFdoConnectionCacheEntry->pFdoConnection->Close();
-                            // We have a match, is it in use?
-                            if(1 == refCount)
-                                // Close the connection
-                                pFdoConnectionCacheEntry->pFdoConnection->Close();
+                            // Release any resource
+                            FDO_SAFE_RELEASE(pFdoConnectionCacheEntry->pFdoConnection);
-                                // Release any resource
-                                FDO_SAFE_RELEASE(pFdoConnectionCacheEntry->pFdoConnection);
+                            delete pFdoConnectionCacheEntry;
+                            pFdoConnectionCacheEntry = NULL;
-                                delete pFdoConnectionCacheEntry;
-                                pFdoConnectionCacheEntry = NULL;
+                            // Remove any feature service cache entries for this resource
+                            MgServiceManager* serviceManager = MgServiceManager::GetInstance();
+                            assert(NULL != serviceManager);
-                                // Remove any feature service cache entries for this resource
-                                MgServiceManager* serviceManager = MgServiceManager::GetInstance();
-                                assert(NULL != serviceManager);
-                                try
-                                    Ptr<MgResourceIdentifier> resource = new MgResourceIdentifier(key);
-                                    serviceManager->RemoveFeatureServiceCacheEntry(resource);
-                                catch(MgInvalidRepositoryTypeException* e)
-                                    // If this exception is thrown then the key was not a resource identifier string
-                                    // and so there will be no entries in the feature service cache to remove.
-                                    SAFE_RELEASE(e);
-                                fdoConnectionCache->erase(iter++);
-                                connectionsRemoved++;
-                                ACE_DEBUG ((LM_DEBUG, ACE_TEXT("MgFdoConnectionManager.RemoveCachedFdoConnection() - Releasing cached FDO connection.\n")));
+                            try
+                                Ptr<MgResourceIdentifier> resource = new MgResourceIdentifier(key);
+                                serviceManager->RemoveFeatureServiceCacheEntry(resource);
-                            else
+                            catch(MgInvalidRepositoryTypeException* e)
-                                // The resource is still in use and so it cannot be removed
-                                ACE_DEBUG ((LM_DEBUG, ACE_TEXT("MgFdoConnectionManager.RemoveCachedFdoConnection() - FDO connection in use!\n")));
-                                // Next cached FDO connection
-                                iter++;
+                                // If this exception is thrown then the key was not a resource identifier string
+                                // and so there will be no entries in the feature service cache to remove.
+                                SAFE_RELEASE(e);
+                            fdoConnectionCache->erase(iter++);
+                            connectionsRemoved++;
+                            ACE_DEBUG ((LM_DEBUG, ACE_TEXT("MgFdoConnectionManager.RemoveCachedFdoConnection() - Releasing cached FDO connection.\n")));
                         else
-                            // NULL pointer
-                            break;
+                            // The resource is still in use and so it cannot be removed
+                            ACE_DEBUG ((LM_DEBUG, ACE_TEXT("MgFdoConnectionManager.RemoveCachedFdoConnection() - FDO connection in use!\n")));
+                            // Next cached FDO connection
+                            iter++;
                     else
@@ -1079,8 +1053,8 @@
                 else
-                    iter++;
+                    // NULL pointer
+                    break;
@@ -1117,23 +1091,15 @@
         // Get the appropriate provider cache
-                    fdoConnectionCache->insert(FdoConnectionCacheEntry_Pair(key, pFdoConnectionCacheEntry));
-                    bConnectionCached = true;
-                    break;
+                fdoConnectionCache->insert(FdoConnectionCacheEntry_Pair(key, pFdoConnectionCacheEntry));
+                bConnectionCached = true;
         // Check to see if the entry was cached. An entry will not be cached above if
@@ -1170,38 +1136,22 @@
     INT32 fdoConnectionCacheSize = m_nFdoConnectionPoolSize; // Set to default
-            // Found the cache we are interested in
-            fdoConnectionCache = iterFdoConnectionCacheCollection->second;
-            break;
-        // Next cache entry
+        // Found the cache we are interested in
+        fdoConnectionCache = iterFdoConnectionCacheCollection->second;
     // Loop all of the FDO connection caches size
-    ProviderInfoCollection::iterator iterProviderInfo = m_ProviderInfoCollection.begin();
-    while(m_ProviderInfoCollection.end() != iterProviderInfo)
+    ProviderInfoCollection::iterator iterProviderInfo = m_ProviderInfoCollection.find(provider);
+    if(m_ProviderInfoCollection.end() != iterProviderInfo)
-        STRING providerCached = iterProviderInfo->first;
+        ProviderInfo* providerInfo = iterProviderInfo->second;
+        if(providerInfo)
-            ProviderInfo* providerInfo = iterProviderInfo->second;
-            if(providerInfo)
-                fdoConnectionCacheSize = providerInfo->cacheSize;
-            break;
+            fdoConnectionCacheSize = providerInfo->cacheSize;
-        iterProviderInfo++;
@@ -1452,18 +1402,10 @@
     STRING resourceId = resId->ToString();
-    FeatureSourceCache::iterator iter = m_FeatureSourceCache.begin();
-    while(m_FeatureSourceCache.end() != iter)
+    FeatureSourceCache::iterator iter = m_FeatureSourceCache.find(resourceId);
+    if(m_FeatureSourceCache.end() != iter)
-        STRING resIdCached = iter->first;
-        if(ACE_OS::strcasecmp(resIdCached.c_str(), resourceId.c_str()) == 0)
-            featureSource = iter->second;
-            break;
-        // Next feature source
-        iter++;
+        featureSource = iter->second;
     if(NULL == featureSource)
@@ -1494,19 +1436,10 @@
     ProviderInfo* providerInfo = NULL;
-    ProviderInfoCollection::iterator iter = m_ProviderInfoCollection.begin();
-    while(m_ProviderInfoCollection.end() != iter)
+    ProviderInfoCollection::iterator iter = m_ProviderInfoCollection.find(provider);
+    if(iter != m_ProviderInfoCollection.end())
-        STRING providerCached = iter->first;
-            // Found it
-            providerInfo = iter->second;
-            break;
-        iter++;
+        providerInfo = iter->second;
     if(NULL == providerInfo)
Modified: trunk/MgDev/Server/src/UnitTesting/TestFeatureService.cpp
--- trunk/MgDev/Server/src/UnitTesting/TestFeatureService.cpp	2007-03-21 16:57:39 UTC (rev 1317)
+++ trunk/MgDev/Server/src/UnitTesting/TestFeatureService.cpp	2007-03-21 19:08:00 UTC (rev 1318)
@@ -351,25 +351,39 @@
         const STRING provider = L"OSGeo.SDF";
 #ifdef _WIN32
         const STRING connectionString = L"File=..\\UnitTestFiles\\Sheboygan_Parcels.sdf";
+        const STRING connectionStringAlt = L"File=..\\UnitTestFiles\\Sheboygan_BuildingOutlines.sdf";
 #else
         const STRING connectionString = L"File=../UnitTestFiles/Sheboygan_Parcels.sdf";
+        const STRING connectionStringAlt = L"File=../UnitTestFiles/Sheboygan_BuildingOutlines.sdf";
 #endif
         FdoIConnection* pFdoConnection1 = pManager->Open(provider, connectionString);
         CPPUNIT_ASSERT(pFdoConnection1);
+        FdoIConnection* pFdoConnectionAlt = pManager->Open(provider, connectionStringAlt);
+        CPPUNIT_ASSERT(pFdoConnectionAlt);
         FdoIConnection* pFdoConnection2 = pManager->Open(provider, connectionString);
         CPPUNIT_ASSERT(pFdoConnection2);
+        FdoIConnection* pFdoConnection3 = pManager->Open(provider, connectionString);
+        CPPUNIT_ASSERT(pFdoConnection3);
         // These connections should be different
         CPPUNIT_ASSERT(pFdoConnection1 != pFdoConnection2);
+        CPPUNIT_ASSERT(pFdoConnection1 != pFdoConnection3);
         pManager->Close(pFdoConnection1);
         pManager->Close(pFdoConnection2);
+        pManager->Close(pFdoConnection3);
+        pManager->Close(pFdoConnectionAlt);
         // Force removal from the FDO connection cache
         STRING key = connectionString;
         pManager->RemoveCachedFdoConnection(key);
+        key = connectionStringAlt;
+        pManager->RemoveCachedFdoConnection(key);
     catch(MgException* e)
More information about the mapguide-commits mailing list
