[mapguide-commits] r1322 - trunk/MgDev/Common/Stylization
svn_mapguide at osgeo.org
Wed Mar 21 16:26:32 EDT 2007
Author: traianstanev
Date: 2007-03-21 16:26:32 -0400 (Wed, 21 Mar 2007)
New Revision: 1322
trunk/MgDev/Common/Stylization/SE_PositioningAlgorithms.cpp
trunk/MgDev/Common/Stylization/SE_PositioningAlgorithms.h
trunk/MgDev/Common/Stylization/SE_Renderer.cpp
trunk/MgDev/Common/Stylization/SE_Renderer.h
trunk/MgDev/Common/Stylization/StylizationEngine.cpp
trunk/MgDev/Common/Stylization/StylizationEngine.h
Add positioning algorithm for multiple highway shields in case where one road feature has multiple highway designations. This patch also submitted by Martin.
Modified: trunk/MgDev/Common/Stylization/SE_PositioningAlgorithms.cpp
--- trunk/MgDev/Common/Stylization/SE_PositioningAlgorithms.cpp 2007-03-21 20:22:37 UTC (rev 1321)
+++ trunk/MgDev/Common/Stylization/SE_PositioningAlgorithms.cpp 2007-03-21 20:26:32 UTC (rev 1322)
@@ -16,9 +16,11 @@
#include "stdafx.h"
+//#include "SE_Include.h"
#include "SE_RenderProxies.h"
#include "SE_PositioningAlgorithms.h"
#include "SE_Renderer.h"
+#include "SE_SymbolManager.h"
#include "Renderer.h"
#include "SE_Bounds.h"
#include "RS_FontEngine.h"
@@ -28,10 +30,10 @@
SE_RenderPointStyle* DeepClonePointStyle(SE_RenderPointStyle* st)
- SE_RenderPointStyle* ret = new SE_RenderPointStyle();
+ SE_RenderPointStyle* ret = new SE_RenderPointStyle();
*ret = *st;
memcpy(ret->bounds, st->bounds, sizeof(ret->bounds));
- SE_RenderText* txt = new SE_RenderText();
+ SE_RenderText* txt = new SE_RenderText();
*txt = *((SE_RenderText*)st->symbol[0]);
ret->symbol[0] = txt;
@@ -44,7 +46,7 @@
void UpdateStyleBounds(SE_RenderPointStyle* st, SE_Renderer* renderer)
SE_RenderText* txt = ((SE_RenderText*)st->symbol[0]);
RS_TextMetrics tm;
SE_Matrix txf;
renderer->GetFontEngine()->GetTextMetrics(txt->text, txt->tdef, tm, false);
@@ -93,17 +95,17 @@
-void SE_PositioningAlgorithms::EightSurrounding(SE_Renderer* renderer,
- LineBuffer* geometry,
- SE_Matrix& xform,
- SE_Style* style,
- SE_RenderStyle* rstyle,
+void SE_PositioningAlgorithms::EightSurrounding(SE_Renderer* renderer,
+ LineBuffer* geometry,
+ SE_Matrix& xform,
+ SE_Style* style,
+ SE_RenderStyle* rstyle,
double mm2px
- //this placement algorithm implements the MapGuide dynamic point labeling algorithm
+ //this placement algorithm implements the MapGuide dynamic point labeling algorithm
//which means 8 candidate labels generated for each symbol
double cx = 0.0;
double cy = 0.0;
double dummy;
@@ -123,7 +125,7 @@
rstyle2->renderPass = rstyle->renderPass;
memcpy(rstyle2->bounds, rstyle->bounds, sizeof(rstyle2->bounds));
SE_RenderText* txt = NULL;
for (SE_RenderPrimitiveList::iterator iter = rstyle->symbol.begin(); iter != rstyle->symbol.end(); iter++)
if ((*iter)->type == SE_RenderTextPrimitive)
@@ -169,17 +171,17 @@
double symbol_rot_deg = box_angle_rad / M_PI180;
double op_pts[16];
// calculate a 2 pixel offset to allow for label ghosting
- double offset = 2.0 ;
+ double offset = 2.0 ;
//compute how far label needs to be offset from
//center point of symbol
double w = 0.5 * symbol_width;
double h = 0.5 * symbol_height;
- double ch = 0; // vertical center point
- double cw = 0; // horizontal center point
+ double ch = 0; // vertical center point
+ double cw = 0; // horizontal center point
w += offset;
h += offset;
@@ -218,10 +220,10 @@
hsn = h * sn; nhsn = -hsn;
hcs = h * cs; nhcs = -hcs;
- cwsn = cw * sn; chsn = ch * sn;
- cwcs = cw * cs; chcs = ch * cs;
+ cwsn = cw * sn; chsn = ch * sn;
+ cwcs = cw * cs; chcs = ch * cs;
// find the octant that the marker is rotated into, and shift the points accordingly.
// this way, the overpost points are still within 22.5 degrees of an axis-aligned box.
// (position 0 will always be the closest to Center-Right)
@@ -242,16 +244,16 @@
if (!useBounds)
- symbol_bounds.maxx = w; symbol_bounds.minx = -w;
- symbol_bounds.maxy = h; symbol_bounds.miny = -h;
+ symbol_bounds.maxx = w; symbol_bounds.minx = -w;
+ symbol_bounds.maxy = h; symbol_bounds.miny = -h;
- op_pts[0] = symbol_bounds.maxx; op_pts[1] = ch;
- op_pts[2] = symbol_bounds.maxx; op_pts[3] = symbol_bounds.maxy;
- op_pts[4] = cw; op_pts[5] = symbol_bounds.maxy;
- op_pts[6] = symbol_bounds.minx; op_pts[7] = symbol_bounds.maxy;
- op_pts[8] = symbol_bounds.minx; op_pts[9] = ch;
+ op_pts[0] = symbol_bounds.maxx; op_pts[1] = ch;
+ op_pts[2] = symbol_bounds.maxx; op_pts[3] = symbol_bounds.maxy;
+ op_pts[4] = cw; op_pts[5] = symbol_bounds.maxy;
+ op_pts[6] = symbol_bounds.minx; op_pts[7] = symbol_bounds.maxy;
+ op_pts[8] = symbol_bounds.minx; op_pts[9] = ch;
op_pts[10] = symbol_bounds.minx;op_pts[11] = symbol_bounds.miny;
- op_pts[12] = cw; op_pts[13] = symbol_bounds.miny;
+ op_pts[12] = cw; op_pts[13] = symbol_bounds.miny;
op_pts[14] = symbol_bounds.maxx;op_pts[15] = symbol_bounds.miny;
@@ -304,11 +306,11 @@
-void SE_PositioningAlgorithms::PathLabels(SE_Renderer* se_renderer,
- SE_Matrix& xform,
- SE_Style* style,
+void SE_PositioningAlgorithms::PathLabels(SE_Renderer* se_renderer,
+ SE_Matrix& xform,
+ SE_Style* style,
double mm2px
@@ -323,16 +325,283 @@
//TODO: get rid of this dynamic_cast once we fix the class hierarchy
Renderer* renderer = dynamic_cast<Renderer*>(se_renderer);
- renderer->ProcessLabelGroup(&info, 1, rt->text, RS_OverpostType_AllFit, true, geometry);
+ renderer->ProcessLabelGroup(&info, 1, rt->text, RS_OverpostType_AllFit, true, geometry);
-void SE_PositioningAlgorithms::MultipleHighwaysShields(SE_Renderer* renderer,
- SE_Matrix& xform,
- SE_Style* style,
- double mm2px
+void SE_PositioningAlgorithms::MultipleHighwaysShields(SE_Renderer* renderer,
+ SE_Matrix& xform,
+ SE_Style* seStyle,
+ double mm2px,
+ RS_FeatureReader* featureReader,
+ SE_SymbolManager* symbolManager
+ // highway info format: countryCode|type1|num1|type2|num2|type3|num3|...
+ // example: US|2|101|3|1
+ StringOfTokens highwayInfo = StringOfTokens(featureReader->GetString(L"Url"), L"|");
+ int shieldCount = (highwayInfo.getTokenCount() - 1) / 2;
+ if (shieldCount < 1)
+ return;
+ SE_RenderPrimitiveList * symbolVectors = new SE_RenderPrimitiveList[shieldCount];
+ std::wstring countryCode = highwayInfo.getFirstToken();
+ int shieldIndex;
+ for (shieldIndex = 0; shieldIndex < shieldCount; shieldIndex++)
+ std::wstring shieldType = highwayInfo.getNextToken();
+ std::wstring highwayNum = highwayInfo.getNextToken();
+ // first the shield graphic
+ SE_RenderRaster* rr = new SE_RenderRaster();
+ std::wstring imgPathName = HIGWAY_SHIELD_SYMBOLS_LOCATION + HIGWAY_SHIELD_SYMBOLS_PREFIX +
+ countryCode + L"_" + shieldType + L".png";
+ rr->pngPtr = symbolManager->GetImageData(L"", imgPathName.c_str(), rr->pngSize);
+ rr->position[0] = 0;
+ rr->position[1] = 0;
+ rr->extent[0] = 20;
+ rr->extent[1] = 20;
+ rr->angle = 0;
+ if (highwayNum.length() == 1)
+ rr->extent[0] = ((shieldType == L"3") ? 25 : 20);
+ else if (highwayNum.length() == 2)
+ rr->extent[0] = 25;
+ else
+ rr->extent[0] = 30;
+ double w = 0.5 * rr->extent[0];
+ double h = 0.5 * rr->extent[1];
+ rr->bounds[0].x = -w;
+ rr->bounds[0].y = -h;
+ rr->bounds[1].x = w;
+ rr->bounds[1].y = -h;
+ rr->bounds[2].x = w;
+ rr->bounds[2].y = h;
+ rr->bounds[3].x = -w;
+ rr->bounds[3].y = h;
+ // the shield graphic is ready
+ symbolVectors[shieldIndex].push_back(rr);
+ // now symbol for the highway number
+ SE_RenderText* rt = new SE_RenderText();
+ rt->text = highwayNum;
+ rt->position[0] = 0;
+ rt->position[1] = 0;
+ rt->tdef.font().name() = L"Arial";
+ rt->tdef.font().height() = 10*0.001 / mm2px; // convert mm to meters
+ rt->tdef.rotation() = 0;
+ rt->tdef.halign() = RS_HAlignment_Center;
+ rt->tdef.valign() = RS_VAlignment_Half;
+ if (shieldType == L"1")
+ rt->tdef.color() = RS_Color(255, 255, 255, 255);
+ else
+ rt->tdef.color() = RS_Color(0, 0, 0, 255);
+ rt->tdef.textbg() = RS_TextBackground_None;
+ rt->tdef.font().style() = RS_FontStyle_Bold;
+ // the number graphic is ready
+ symbolVectors[shieldIndex].push_back(rt);
+ SE_RenderLineStyle* style = (SE_RenderLineStyle* ) rstyle;
+ SE_Matrix symxf;
+ int ptindex = 0;
+ double increment = style->repeat;
+ // double incrementS = 10 * mm2px; // the 'increment' used between multiple shields
+ double incrementS = style->endOffset; // use endOffset as the increment between multiple shields
+ shieldIndex = 0;
+ for (int j=0; j<geometry->cntr_count(); j++)
+ // current polyline
+ int ptcount = geometry->cntrs()[j];
+ double* pts = geometry->points() + 2*ptindex;
+ // init position along the current segment to the start offset
+ double drawpos = style->startOffset;
+ int cur_seg = 0;
+ while (cur_seg < ptcount - 1)
+ symxf.setIdentity();
+ // current line segment
+ double* seg = pts + cur_seg * 2;
+ // transform the point to screen space
+ double cx1, cy1, cx2, cy2;
+ renderer->WorldToScreenPoint(seg[0], seg[1], cx1, cy1);
+ renderer->WorldToScreenPoint(seg[2], seg[3], cx2, cy2);
+ // calc length
+ double dx = cx2 - cx1;
+ double dy = cy2 - cy1;
+ double len = sqrt(dx*dx + dy*dy);
+ // check if completely skipping current segment since it is smaller than the increment
+ if (drawpos < len)
+ double slope = atan2(dy, dx);
+ double dx_fact = cos(slope);
+ double dy_fact = sin(slope);
+ double tx = cx1 + dx_fact * drawpos;
+ double ty = cy1 + dy_fact * drawpos;
+ symxf.translate(tx, ty);
+ double dx_incr = dx_fact * increment; // x/y incr between groups of shields
+ double dy_incr = dy_fact * increment;
+ double dx_incS = dx_fact * incrementS; // x/y incr between shields in a group
+ double dy_incS = dy_fact * incrementS;
+ // follow the segment and place the shield symbols alternated via shieldIndex
+ while (drawpos < len)
+ if (style->drawLast)
+ style->symbol = symbolVectors[shieldIndex];
+ memcpy(style->bounds, symbolVectors[shieldIndex].front()->bounds, sizeof(style->bounds));
+ SE_RenderStyle* clonedStyle = renderer->CloneRenderStyle(style);
+ SE_LabelInfo info(symxf.x2, symxf.y2, 0.0, 0.0, RS_Units_Device, 0, clonedStyle);
+ renderer->ProcessLabelGroup(&info, 1, RS_OverpostType_AllFit, style->addToExclusionRegions, geometry);
+ else
+ renderer->DrawSymbol(symbolVectors[shieldIndex], symxf, 0);
+ // TODO: if this is ever needed ...
+ // if (style->addToExclusionRegions)
+ // renderer->AddExclusionRegion(style, symxf, 0);
+ // move on to the next shield, if beyond the last one go back to the first
+ shieldIndex++;
+ if (shieldIndex < shieldCount)
+ symxf.translate(dx_incS, dy_incS);
+ drawpos += incrementS;
+ else
+ // finished with one group
+ // go back to the first symbol and advance using the full increment
+ shieldIndex = 0;
+ symxf.translate(dx_incr, dy_incr);
+ drawpos += increment;
+ drawpos -= len;
+ cur_seg++;
+ ptindex += ptcount;
+ delete [] symbolVectors;
+int StringOfTokens::getTokenCount()
+ if (m_tokenstring.empty())
+ return 0;
+ std::wstring::size_type curPos = 0;
+ std::wstring::size_type delimPos;
+ int count = 1;
+ delimPos = m_tokenstring.find(m_delimiter, curPos);
+ while (std::wstring::npos != delimPos)
+ curPos = delimPos + 1;
+ count++;
+ return count;
+std::wstring StringOfTokens::getFirstToken()
+ return L"";
+ m_currentPos = 0;
+ std::wstring::size_type delimPos1 = m_tokenstring.find(m_delimiter);
+ if (std::wstring::npos == delimPos1)
+ m_currentPos = m_tokenstring.length();
+ return m_tokenstring;
+ else
+ m_currentPos = delimPos1+1;
+ return m_tokenstring.substr(0, delimPos1);
+std::wstring StringOfTokens::getNextToken()
+ if (m_tokenstring.empty() || m_currentPos >= m_tokenstring.length())
+ return L"";
+ std::wstring::size_type curPos = m_currentPos;
+ std::wstring::size_type delimPos = m_tokenstring.find(m_delimiter, m_currentPos);
+ if (std::wstring::npos == delimPos)
+ return m_tokenstring.substr(curPos);
+ else
+ m_currentPos = delimPos+1;
+ return m_tokenstring.substr(curPos, delimPos - curPos);
Modified: trunk/MgDev/Common/Stylization/SE_PositioningAlgorithms.h
--- trunk/MgDev/Common/Stylization/SE_PositioningAlgorithms.h 2007-03-21 20:22:37 UTC (rev 1321)
+++ trunk/MgDev/Common/Stylization/SE_PositioningAlgorithms.h 2007-03-21 20:26:32 UTC (rev 1322)
@@ -18,8 +18,16 @@
#ifndef SE_POSITIONINGALGORITHMS_H
#define SE_POSITIONINGALGORITHMS_H
+#include "SE_RenderProxies.h"
+//const std::wstring HIGWAY_SHIELD_SYMBOLS_LOCATION = L"Library://Symbology/HighwaySymbols/";
+const std::wstring HIGWAY_SHIELD_SYMBOLS_LOCATION = L"C:/";
+const std::wstring HIGWAY_SHIELD_SYMBOLS_PREFIX = L"shield_";
class LineBuffer;
class SE_Renderer;
+class SE_SymbolManager;
+class RS_FeatureReader;
struct SE_Matrix;
struct SE_Style;
struct SE_RenderStyle;
@@ -28,29 +36,58 @@
class SE_PositioningAlgorithms
public:
- static void EightSurrounding(SE_Renderer* renderer,
- SE_Matrix& xform,
- SE_Style* style,
+ static void EightSurrounding(SE_Renderer* renderer,
+ SE_Matrix& xform,
+ SE_Style* style,
double mm2px
- static void PathLabels(SE_Renderer* renderer,
- SE_Matrix& xform,
- SE_Style* style,
+ static void PathLabels(SE_Renderer* renderer,
+ SE_Matrix& xform,
+ SE_Style* style,
double mm2px
- static void MultipleHighwaysShields(SE_Renderer* renderer,
- SE_Matrix& xform,
- SE_Style* style,
- double mm2px
+ static void MultipleHighwaysShields(SE_Renderer* renderer,
+ SE_Matrix& xform,
+ SE_Style* style,
+ double mm2px,
+class StringOfTokens
+public:
+ StringOfTokens(std::wstring tokenstring, std::wstring delimiter) :
+ m_tokenstring(tokenstring),
+ m_delimiter(delimiter)
+ m_currentPos = 0;
+ int getTokenCount();
+ std::wstring getFirstToken();
+ std::wstring getNextToken();
+private:
+ std::wstring m_delimiter;
+ std::wstring m_tokenstring;
+ std::wstring::size_type m_currentPos;
#endif // SE_POSITIONINGALGORITHMS_H
Modified: trunk/MgDev/Common/Stylization/SE_Renderer.cpp
--- trunk/MgDev/Common/Stylization/SE_Renderer.cpp 2007-03-21 20:22:37 UTC (rev 1321)
+++ trunk/MgDev/Common/Stylization/SE_Renderer.cpp 2007-03-21 20:26:32 UTC (rev 1322)
@@ -24,11 +24,11 @@
using namespace MDFMODEL_NAMESPACE;
//cloning of RenderSymbols. Unfortunate but necessary for delay-drawing labels
-static SE_RenderStyle* CloneRenderStyle(SE_RenderStyle* symbol)
+SE_RenderStyle* SE_Renderer::CloneRenderStyle(SE_RenderStyle* symbol)
SE_RenderStyle* ret = NULL;
- //first determine what kind of style it is and copy all the
+ //first determine what kind of style it is and copy all the
//style specific properties
switch (symbol->type)
@@ -191,7 +191,7 @@
//transform to screen space -- geometry is in [the original] mapping space
WorldToScreenPoint(x, y, x, y);
xform.setIdentity();
xform.translate(x, y);
double angle = 0;//TODO: angle needs to be added to the RenderPointStyle
@@ -214,9 +214,9 @@
SE_RenderPrimitiveList& rs = style->symbol;
//check if it is a single symbol that is not a label participant
- if (rs.size() == 1
- && rs[0]->type == SE_RenderPolylinePrimitive
- && !style->drawLast
+ if (rs.size() == 1
+ && rs[0]->type == SE_RenderPolylinePrimitive
+ && !style->drawLast
&& !style->addToExclusionRegions)
SE_RenderPolyline* rp = (SE_RenderPolyline*)rs[0];
@@ -224,13 +224,13 @@
//check if it is a horizontal line
if (lb->point_count() == 2
- && lb->points()[1] == 0.0
+ && lb->points()[1] == 0.0
&& lb->points()[3] == 0.0)
- //now make sure it is not a dashed line by comparing the
+ //now make sure it is not a dashed line by comparing the
//single segment to the symbol repeat
double len = lb->points()[2] - lb->points()[0];
if (fabs(len - style->repeat) < 0.001) //repeat must be within 1/1000 of a pixel for us to assume solid line
//this is only to avoid FP precision issues, in reality they would be exactly equal
@@ -243,9 +243,9 @@
SE_Matrix symxf;
int ptindex = 0;
//get the increment (the render style already stores this in screen units)
@@ -276,7 +276,7 @@
//transform segment from mapping to screen space
WorldToScreenPoint(seg[0], seg[1], seg_screen[0], seg_screen[1]);
WorldToScreenPoint(seg[2], seg[3], seg_screen[2], seg_screen[3]);
//get length
double dx = seg_screen[2] - seg_screen[0];
double dy = seg_screen[3] - seg_screen[1];
@@ -305,7 +305,7 @@
//loop-draw the symbol along the current segment,
//moving along by increment pixels
AddLabel(geometry, style, symxf, symrot);
else
@@ -317,10 +317,10 @@
- drawpos += increment;
drawpos -= len;
cur_seg++;
@@ -404,13 +404,13 @@
void SE_Renderer::AddLabel(LineBuffer* geom, SE_RenderStyle* style, SE_Matrix& xform, double angle)
- //clone the SE_RenderStyle so that the label renderer can keep track of it until
+ //clone the SE_RenderStyle so that the label renderer can keep track of it until
//the end of rendering when it draws all the labels
//TODO: cloning is bad.
SE_RenderStyle* copied_style = CloneRenderStyle(style);
SE_LabelInfo info(xform.x2, xform.y2, 0.0, 0.0, RS_Units_Device, angle, copied_style);
RS_OverpostType type = RS_OverpostType_AllFit;
ProcessLabelGroup(&info, 1, type, style->addToExclusionRegions, geom);
Modified: trunk/MgDev/Common/Stylization/SE_Renderer.h
--- trunk/MgDev/Common/Stylization/SE_Renderer.h 2007-03-21 20:22:37 UTC (rev 1321)
+++ trunk/MgDev/Common/Stylization/SE_Renderer.h 2007-03-21 20:26:32 UTC (rev 1322)
@@ -64,6 +64,9 @@
//sigh
const RS_F_Point* GetLastExclusionRegion() { return m_lastExclusionRegion; }
+ SE_RenderStyle* CloneRenderStyle(SE_RenderStyle* symbol);
protected:
void SetRenderSelectionMode(bool mode);
@@ -73,7 +76,7 @@
void AddExclusionRegion(SE_RenderStyle* rstyle, SE_Matrix& xform, double angle);
RS_F_Point m_lastExclusionRegion[4];
protected:
SE_LineBufferPool* m_lbp;
bool m_bSelectionMode;
Modified: trunk/MgDev/Common/Stylization/StylizationEngine.cpp
--- trunk/MgDev/Common/Stylization/StylizationEngine.cpp 2007-03-21 20:22:37 UTC (rev 1321)
+++ trunk/MgDev/Common/Stylization/StylizationEngine.cpp 2007-03-21 20:26:32 UTC (rev 1322)
@@ -39,7 +39,8 @@
StylizationEngine::StylizationEngine(SE_SymbolManager* resources) :
m_resources(resources),
m_renderer(NULL),
- m_serenderer(NULL)
+ m_serenderer(NULL),
+ m_reader(NULL)
m_pool = new SE_LineBufferPool;
m_lbPool = new LineBufferPool;
@@ -70,6 +71,7 @@
return;
m_renderer = renderer;
+ m_reader = reader;
// make sure we have an SE renderer
// TODO: eliminate the need to do dynamic casts on these renderers. We should
@@ -188,6 +190,8 @@
int renderingPass,
int& nextRenderingPass)
double mm2pxs = m_serenderer->GetPixelsPerMillimeterScreen();
double mm2pxw = m_serenderer->GetPixelsPerMillimeterWorld();
@@ -199,7 +203,7 @@
SE_Rule* rulecache = new SE_Rule[nRules];
rules = rulecache;
for (int i = 0; i < nRules; i++)
CompositeRule* r = (CompositeRule*)rulecoll->GetAt(i);
@@ -227,7 +231,7 @@
bool match = (rules[i].filter == NULL);
if (!match)
rules[i].filter->Process(executor);
@@ -259,16 +263,16 @@
/* TODO: Obey the indices--Get rid of the indices altogther--single pass! */
for (std::vector<SE_Symbolization*>::const_iterator iter = symbolization->begin(); iter != symbolization->end(); iter++)
SE_Symbolization* sym = *iter;
double mm2px = (sym->context == MappingUnits)? mm2pxw : mm2pxs;
SE_Matrix xform;
- xform.setTransform( sym->scale[0].evaluate(executor),
+ xform.setTransform( sym->scale[0].evaluate(executor),
sym->scale[1].evaluate(executor),
- sym->absOffset[0].evaluate(executor),
+ sym->absOffset[0].evaluate(executor),
sym->absOffset[1].evaluate(executor) );
xform.scale(mm2px, mm2px);
@@ -349,6 +353,12 @@
SE_PositioningAlgorithms::PathLabels(m_serenderer, geometry, xform, style, rstyle, mm2px);
+ else if (positioningAlgo == L"MultipleHighwayShields")
+ SE_PositioningAlgorithms::MultipleHighwaysShields(m_serenderer, geometry, xform, style, rstyle, mm2px,
+ m_reader, m_resources);
Modified: trunk/MgDev/Common/Stylization/StylizationEngine.h
--- trunk/MgDev/Common/Stylization/StylizationEngine.h 2007-03-21 20:22:37 UTC (rev 1321)
+++ trunk/MgDev/Common/Stylization/StylizationEngine.h 2007-03-21 20:26:32 UTC (rev 1322)
@@ -92,6 +92,7 @@
SE_StyleVisitor* m_visitor;
std::map<CompositeTypeStyle*, SE_Rule*> m_rules;
LineBufferPool* m_lbPool;
+ RS_FeatureReader* m_reader;
#endif // STYLIZATION_ENGINE_H
More information about the mapguide-commits
