[mapguide-commits] r1374 - trunk/MgDev/Common/Stylization
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon Mar 26 05:43:10 EDT 2007
Author: waltweltonlair
Date: 2007-03-26 05:42:53 -0400 (Mon, 26 Mar 2007)
New Revision: 1374
   trunk/MgDev/Common/Stylization/SE_Renderer.cpp
   trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.cpp
Image extents must be positive, unless you don't want your images to draw...
Modified: trunk/MgDev/Common/Stylization/SE_Renderer.cpp
--- trunk/MgDev/Common/Stylization/SE_Renderer.cpp	2007-03-26 05:50:01 UTC (rev 1373)
+++ trunk/MgDev/Common/Stylization/SE_Renderer.cpp	2007-03-26 09:42:53 UTC (rev 1374)
@@ -187,21 +187,21 @@
     for (int i = 0; i < geometry->point_count(); i++)
         double x = geometry->points()[2*i];
-        double y= geometry->points()[2*i+1];
+        double y = geometry->points()[2*i+1];
         //transform to screen space -- geometry is in [the original] mapping space
         WorldToScreenPoint(x, y, x, y);
         xform.setIdentity();
         xform.translate(x, y);
-        double angle = 0;//TODO: angle needs to be added to the RenderPointStyle
+        double angle = 0.0; //TODO: angle needs to be added to the RenderPointStyle
         if (style->drawLast)
-            AddLabel(geometry, style, xform, 0);
+            AddLabel(geometry, style, xform, 0.0);
         else
             DrawSymbol(style->symbol, xform, angle);
-            double angle = 0;
             if (style->addToExclusionRegions)
                 AddExclusionRegion(style, xform, angle);
Modified: trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.cpp
--- trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.cpp	2007-03-26 05:50:01 UTC (rev 1373)
+++ trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.cpp	2007-03-26 09:42:53 UTC (rev 1374)
@@ -254,13 +254,13 @@
     if (extentScaleable.evaluate(cxt->exec))
-        ret->extent[0] = extent[0].evaluate(cxt->exec)*cxt->xform->x0;
-        ret->extent[1] = extent[1].evaluate(cxt->exec)*cxt->xform->y1;
+        ret->extent[0] = fabs(extent[0].evaluate(cxt->exec)*cxt->xform->x0);
+        ret->extent[1] = fabs(extent[1].evaluate(cxt->exec)*cxt->xform->y1);
     else
-        ret->extent[0] = extent[0].evaluate(cxt->exec)*cxt->mm2pxw;
-        ret->extent[1] = extent[1].evaluate(cxt->exec)*cxt->mm2pxw;
+        ret->extent[0] = fabs(extent[0].evaluate(cxt->exec)*cxt->mm2pxw);
+        ret->extent[1] = fabs(extent[1].evaluate(cxt->exec)*cxt->mm2pxw);
     ret->angle = angle.evaluate(cxt->exec) * M_PI180;
More information about the mapguide-commits mailing list
