[mapguide-commits] r4193 - in trunk/MgDev: Common/PlatformBase/Services Server/src/Services/Feature
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Thu Aug 27 05:36:19 EDT 2009
Author: leaf
Date: 2009-08-27 05:36:18 -0400 (Thu, 27 Aug 2009)
New Revision: 4193
   trunk/MgDev/Common/PlatformBase/Services/ParameterDirection.h
   trunk/MgDev/Server/src/Services/Feature/ServerFeatureUtil.cpp
Ticket #1073: Rename constant from 'MgParameterDirection::Return' to 'MgParameterDirection::Ret' because 'Return' conflicts with PHP keyword and it will result in PHP parse error.
Modified: trunk/MgDev/Common/PlatformBase/Services/ParameterDirection.h
--- trunk/MgDev/Common/PlatformBase/Services/ParameterDirection.h	2009-08-26 22:17:42 UTC (rev 4192)
+++ trunk/MgDev/Common/PlatformBase/Services/ParameterDirection.h	2009-08-27 09:36:18 UTC (rev 4193)
@@ -52,7 +52,7 @@
     /// \brief
     /// Specifies that the parameter is a return parameter.
-    static const INT32 Return = 3;
+    static const INT32 Ret = 3;
Modified: trunk/MgDev/Server/src/Services/Feature/ServerFeatureUtil.cpp
--- trunk/MgDev/Server/src/Services/Feature/ServerFeatureUtil.cpp	2009-08-26 22:17:42 UTC (rev 4192)
+++ trunk/MgDev/Server/src/Services/Feature/ServerFeatureUtil.cpp	2009-08-27 09:36:18 UTC (rev 4193)
@@ -2659,7 +2659,7 @@
             fdoParameterDirection = FdoParameterDirection_Output;
             break;
-        case MgParameterDirection::Return:
+        case MgParameterDirection::Ret:
             fdoParameterDirection = FdoParameterDirection_Return;
             break;
@@ -2704,7 +2704,7 @@
         case FdoParameterDirection_Return:
-            parameterDirection = MgParameterDirection::Return;
+            parameterDirection = MgParameterDirection::Ret;
             break;
         default:
More information about the mapguide-commits mailing list
