[mapguide-commits] r4199 -
trunk/Tools/Maestro/Maestro/ResourceEditors
svn_mapguide at osgeo.org
Sun Aug 30 07:17:41 EDT 2009
Author: ksgeograf
Date: 2009-08-30 07:17:41 -0400 (Sun, 30 Aug 2009)
New Revision: 4199
trunk/Tools/Maestro/Maestro/ResourceEditors/ThemeCreator.cs
Maestro: Fixed an issue with null values and columns with no data in the ThemeCreator
Modified: trunk/Tools/Maestro/Maestro/ResourceEditors/ThemeCreator.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/ThemeCreator.cs 2009-08-28 17:27:28 UTC (rev 4198)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/ThemeCreator.cs 2009-08-30 11:17:41 UTC (rev 4199)
@@ -187,19 +187,52 @@
if (col == null)
throw new Exception("Invalid column name");
- //TODO: Try/catch
- using (MaestroAPI.FeatureSetReader rd = m_editor.CurrentConnection.QueryFeatureSource(m_layer.Item.ResourceId, m_schema.Fullname, null, new string[] { col.Name }))
- while (rd.Read() && m_values.Count < 100000) //No more than 100.000 records in memory
- if (!rd.Row.IsValueNull(col.Name))
+ string filter = null; //Attempt raw reading initially
+ Exception rawEx = null; //Original exception
+ bool retry = true;
+ while (retry)
+ retry = false;
+ try
+ using (MaestroAPI.FeatureSetReader rd = m_editor.CurrentConnection.QueryFeatureSource(m_layer.Item.ResourceId, m_schema.Fullname, filter, new string[] { col.Name }))
+ while (rd.Read() && m_values.Count < 100000) //No more than 100.000 records in memory
+ if (!rd.Row.IsValueNull(col.Name))
+ object value = rd.Row[col.Name];
+ if (!m_values.ContainsKey(value))
+ m_values.Add(value, 0);
+ m_values[value]++;
+ catch (Exception ex)
+ rawEx = ex;
+ if (filter == null && ex.Message.IndexOf("MgNullPropertyValueException") >= 0) //Known issue
- object value = rd.Row[col.Name];
- if (!m_values.ContainsKey(value))
- m_values.Add(value, 0);
- m_values[value]++;
+ retry = true;
+ filter = col.Name + " != NULL";
+ if (rawEx != null)
+ MessageBox.Show(this, string.Format("Unable to read data from the selected column: {0}", rawEx.Message), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Information);
+ ColumnCombo.SelectedIndex = 0;
+ return;
+ if (m_values.Count == 0)
+ MessageBox.Show(this,"The selected column had no non-null values and cannot be used.", Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Information);
+ return;
m_dataType = col.Type;
if (Array.IndexOf<Type>(NUMERIC_TYPES, col.Type) >= 0)
More information about the mapguide-commits
